Gaz Posted April 8, 2006 Share Posted April 8, 2006 WTF is a rajay turbo and how big is it.? RB25 or 30 would be an awsome engine. Nissan is always going to be a good choice for the fact they have awsome aftermarket support. Quote Link to comment Share on other sites More sharing options...
Hemi Posted April 8, 2006 Share Posted April 8, 2006 ;ast few rajay turbos ive seen are oldskool looking truck turbos simliar size to evo turbs maybe bit bigger ...look wierd tho Quote Link to comment Share on other sites More sharing options...
Raizer Posted April 8, 2006 Share Posted April 8, 2006 2JZ-GTE!! With the ZX80 6 speed!! Quote Link to comment Share on other sites More sharing options...
Burntrubber Posted April 8, 2006 Share Posted April 8, 2006 Rajay were common in the 70's I have a book on forced induction has heaps of stuff about Rajay in it. They are still used in planes not sure if any cars use them anymore though. Quote Link to comment Share on other sites More sharing options...
Leebo3 Posted April 8, 2006 Share Posted April 8, 2006 A 302 would be a good option, they dont cost a hell of alot. I am considering putting one in the falcon at the moment, should be able to get one for around $500-600. Quote Link to comment Share on other sites More sharing options...
v3k Posted April 8, 2006 Share Posted April 8, 2006 Having said that, putting a 302 in a falcon is alot cheaper than into a capri. The gearbox wont bolt up. You need to strengthen the body (I believe, well the Perena's were strengthened) and Im not sure if the firewall needs recessing. Decide what you want... a fast street car, or something with stupid amounts of tarmac shredding hp? If you just want a fast streeter, find the car that is about as fast as you want. Work out its hp/kg, then find an engine that will give you a similar (slightly higher ) result. Put that puppy in and presto - what you wanted. Quote Link to comment Share on other sites More sharing options...
Gaz Posted April 9, 2006 Share Posted April 9, 2006 If you just want a fast streeter, find the car that is about as fast as you want. Work out its hp/kg, then find an engine that will give you a similar (slightly higher ) result. Put that puppy in and presto - what you wanted. This is a good idea. Quote Link to comment Share on other sites More sharing options...
Defective Posted April 9, 2006 Share Posted April 9, 2006 u can make a 3.9 a 4.0 by grinding off the lil ridge in the head that fukin simple as done it a few times now, if u gonna put in a 4ltr tho migbht as well make it own and xr6t it , just read up about a 1000hp street driven one (when i say street driven i mean no low rpm probs) eeeerrrr, how does that change the capacity? Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted April 9, 2006 Share Posted April 9, 2006 u can make a 3.9 a 4.0 by grinding off the lil ridge in the head that fukin simple as done it a few times now, if u gonna put in a 4ltr tho migbht as well make it own and xr6t it , just read up about a 1000hp street driven one (when i say street driven i mean no low rpm probs) nothing you do to the head will increase cubic capacity. if anything decrease compression. xr6t wud be cool tho, awsum engine. Quote Link to comment Share on other sites More sharing options...
Hemi Posted April 9, 2006 Share Posted April 9, 2006 are you sure there is a ridge in the combustin chamber part of head (between intake & exhuast valves) and by getting rid of that im sure it increases acapacity as there is more free space , i could be wrong tho im not a engine guru btw this is on a carbied engine Quote Link to comment Share on other sites More sharing options...
Gaz Posted April 9, 2006 Share Posted April 9, 2006 Doesnt change how far the psitons move tho or how big the bore is so doesnt change capacity. It will drop compression more than likely. To change the capacity you can either increase/decrease the bore size by boring it and use larger/smaller pistons. Or you can increase the stroke by using 1. a differant crank or 2. longer or shorter rods. Quote Link to comment Share on other sites More sharing options...
Hemi Posted April 9, 2006 Share Posted April 9, 2006 my mistake then sorry haha....then again the pistons were always changed couldve been higher comp?? iunno mang ill be wrong no doubt Quote Link to comment Share on other sites More sharing options...
Gaz Posted April 9, 2006 Share Posted April 9, 2006 yeah changing pistons or taking adding to head can change compression ratio. Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted April 9, 2006 Share Posted April 9, 2006 changing rod length alone wont change displacement, just compression ratio. altho rods are usually changed when different throw cranks are used to restore cr. ie shorter throw longer rod and vv. Quote Link to comment Share on other sites More sharing options...
Josh Posted April 9, 2006 Author Share Posted April 9, 2006 Fuck I come back from welly for 2 days and theres 3 pages! awesome. Got heaps 2h2h pics, badass oldschool rides there, will post pics later. Right...thanks for all the input..idea is a fast streeter, I want over 200hp, at least. Dont have time at the mo, but il actually make a decent reply to this tomorrow. Quote Link to comment Share on other sites More sharing options...
mutiny Posted April 9, 2006 Share Posted April 9, 2006 nice 12a jports good for 250 easy Quote Link to comment Share on other sites More sharing options...
Gaz Posted April 9, 2006 Share Posted April 9, 2006 Got heaps 2h2h pics, badass oldschool rides there, will post pics later. Didnt know you were down for that, Should have caught up there... Quote Link to comment Share on other sites More sharing options...
Josh Posted April 10, 2006 Author Share Posted April 10, 2006 Ah true, gutted, said in one of the earlier posts i was coming up for it, all good though. Bandit, not to keen on the idea of a rotary engine...just dont really like them to much, reliability etc.. gonna go down to chch and talk to a few places there and see what they have to say.. Quote Link to comment Share on other sites More sharing options...
shizzl Posted April 10, 2006 Share Posted April 10, 2006 how bout a gt starlet engine?maybe a k50/t50 box will fit aswell.. i had a 4age and k5o box in my escort,never got it finished though..fit nicely... ive lost all pics ive had of my escort...anyone got any? black mk2 coupe,had 4age,then had 2l turbo,all hpc'd..(SHIZZL) Quote Link to comment Share on other sites More sharing options...
lowlancer Posted April 10, 2006 Share Posted April 10, 2006 Bah, 1.3 turbs would be crack up Whoever said RB25DET is on the ball That would rule, 6 cylinders sound awesome Quote Link to comment Share on other sites More sharing options...
