davidian Posted April 4, 2006 Share Posted April 4, 2006 saw this last time at the museum SUPAclean mini there man... lovin' it Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted April 4, 2006 Share Posted April 4, 2006 hot! Quote Link to comment Share on other sites More sharing options...
thminiman Posted April 5, 2006 Share Posted April 5, 2006 thanks guys, does anyone know of a good place for sandblasting in Aucks? i need to get the subframe sanblasted down so i can repaint it. thanks Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted April 18, 2006 Share Posted April 18, 2006 lookin mean man that thingyme you're asking is an engine breather, yup try clean it out, and perhaps run a rocker cover with breather as well. also some caem out with a breather saem as that on the timing case...... mini's can't have too much breathing. hence why they often have oil leaks, is due to pressure building in the crankcase etc..... just happens lol but yuh. lookin top notch. what are you running carb wise? didn't pay much attention Quote Link to comment Share on other sites More sharing options...
thminiman Posted April 18, 2006 Share Posted April 18, 2006 cheers mate, i think ill put a little breather filter on that thingame coming from the block, and yea, a newer roker cover is on its way hopefully well the carbs at the moment are just the standard twin SU's. i want to run a dellorto or weber, but thats easier said than done, as most sideys and maniflods you need to cut into the bulkhead which i am reluctant to do as i want to keep the centre dash, so im looking for a down draught to fit on and maybe open it up a bit. Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted April 18, 2006 Share Posted April 18, 2006 yuh the downdraughts are itches. I used to rock one on my clubman.... still got it kickin round somewhere if you're keen..... hunt down some genuine 1.5" s.u's. not easy to find.... I've got a set but yuh. as good, if not better than sidedrafts Quote Link to comment Share on other sites More sharing options...
thminiman Posted April 18, 2006 Share Posted April 18, 2006 yea the ones that it came with seemed to cope with the head, valves and cam that had been upgraded quite well, how would i find out what sizing SU's they are, i dont really know what size they are because the guy i baught it off was somewhat clueless, so i may have stumbled across the 1.5's without knowing. Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted April 18, 2006 Share Posted April 18, 2006 measure the throats.... or post a pic. i can tell from just looking @ them Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted April 23, 2006 Share Posted April 23, 2006 primo mang, oilcooler stz.... Quote Link to comment Share on other sites More sharing options...
thminiman Posted April 23, 2006 Share Posted April 23, 2006 hey, just one thing about the 1.5 SU's, can i get 2 single 1.5's and use the linkages from the 1.25's to make twin 1.5's? thaught it might be a cheaper option as i already have one 1.5 and buying another single is pretty cheap. cheers for the help cam Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted April 23, 2006 Share Posted April 23, 2006 nope manifolds are different, and cant change the side of the carb which float chamber etc is on... if you get what i mena really need cam and head etc to make use of them. esp on a 998. will make a bit of difference but not really worth it for work involved and cost of getting 1.5s I've a 12g295 head which needs valves, apart from that is perfect. cams are easy to get reground in a decent profile.... do it Quote Link to comment Share on other sites More sharing options...
thminiman Posted April 23, 2006 Share Posted April 23, 2006 lol, nah the engine ive got is a pretty good set up, 1340 head and a fairly lumpy mild race cam, lightened race valves and springs... im thinking ill just leave the carb set up as it is until a bit later on as its something i can do when the engine is in, that way i wont have to skimp out anywhere and give the engine the petrol it deserves thanks anyway man Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted April 23, 2006 Share Posted April 23, 2006 yuh fully get the 1.25s set up properly for it etc. single 1.5 is too small Quote Link to comment Share on other sites More sharing options...
thminiman Posted April 30, 2006 Share Posted April 30, 2006 ok, does ANYONE in auckland have a mint condition road sign lying around they dont want... dont really wana use my mums car to get one from somewhere lol Quote Link to comment Share on other sites More sharing options...
peteretep Posted April 30, 2006 Share Posted April 30, 2006 like a 'Manukau Road' sign? I have a bicycle sign, give way, big blue one with an arrow and a no entry one but none with road names Quote Link to comment Share on other sites More sharing options...
thminiman Posted April 30, 2006 Share Posted April 30, 2006 nah it needs to be relatively large, like one of those ones with the guy with a spade. if anyones wondering, i want it to make a mounting plate up for my oil cooler, hence the question being in my project discussion Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted April 30, 2006 Share Posted April 30, 2006 get some aluminium panel from soemwhere, or some panel steel form a panelbeater fuck gettin pwnd $2000 fine for getting caught with a roadsign plus they're expensive a fuck for contractors to replace. dont be a rotten cunt Quote Link to comment Share on other sites More sharing options...
thminiman Posted April 30, 2006 Share Posted April 30, 2006 lol i know, thats why im asking around... Quote Link to comment Share on other sites More sharing options...
peteretep Posted April 30, 2006 Share Posted April 30, 2006 ullrich aluminium has all that stuff out at otahu Quote Link to comment Share on other sites More sharing options...
mikuni Posted May 5, 2006 Share Posted May 5, 2006 Looking good man. Luving the oil cooler boso mini stz! haha Where did you score that from and how much? Quote Link to comment Share on other sites More sharing options...
