Dell'orto Posted September 25, 2012 Share Posted September 25, 2012 Eagerly awaiting some drive by videos, bet it sounds so good from the outside. Quote Link to comment Share on other sites More sharing options...
rxsumo Posted September 25, 2012 Share Posted September 25, 2012 Eagerly awaiting some drive by videos, bet it sounds so good from the outside. first 20 seconds of this has the drive by Quote Link to comment Share on other sites More sharing options...
rxsumo Posted September 25, 2012 Share Posted September 25, 2012 Good video. Gutted my car is not ready yet.What class are you running in? In the Intermarque series we have a cc based, and modified/stock class system The 10A runs in the M2 class - modified between 1301 and 1800cc class, the 10A with the rotary multiplier comes out at 1796cc Quote Link to comment Share on other sites More sharing options...
SlyOne Posted September 25, 2012 Share Posted September 25, 2012 Watched this at intermarque and very impressed with. Speed..even mprr impressed when you told me its a 10a! Welldone! Quote Link to comment Share on other sites More sharing options...
yoeddynz Posted September 30, 2012 Share Posted September 30, 2012 Wow- sounds really sweet in that last video and good to see it being driven to its full. nice steering wheel twitching going on. My engine has pretty loose side seal to corner seal clearences. I think they were only just within tolerance- just. In fact they had worn tiny grooves into corner seals as usual which gave them more room to slide backwards and forwards adding to clearence. I flipped the corner seals over so the grooves are now on trailing side- another scottish aspect to my $100 motor. I often wonder how much gas is escaping past through those little gaps. How much did you get new side seals for? When will you next get it on a dyno- it'll be interesting to see the difference. Quote Link to comment Share on other sites More sharing options...
rxsumo Posted October 1, 2012 Share Posted October 1, 2012 The side seals didnt really cost me as such, I have been accumulating 10A engine bits over the years, so have enough bits to rebuild around 3ish motors. We only had to buy the casement o-rings and springs. The engine has been back on the dyno 2 weeks ago, and is developing around 160 hp at the rear wheels - at 9000 rpm. The factory 10A PP were estimated at 200 hp at the flywheel, with better exhaust ports, and a better exhaust system than what we are running...so I'm pretty happy with the result. The dyno was a worthwile exercise, as the engine was now running a little lean at the top end, so we ended up changing the emulsion tubes, enlarging the main jets and reducing the airs The last figures - with the misfire, where probably reading a little high, due to the ramp up speed selected when the guys were diagnosing the misfire, on the dynapacks - apparently if you slow the ramp up speed - ie labour the engine, you can artificially raise the HP figures. Quote Link to comment Share on other sites More sharing options...
Truenotch Posted October 3, 2012 Share Posted October 3, 2012 Looks good, sounds good, goes good. Well done! Tempted to get into the winter series classic racing next year? Quote Link to comment Share on other sites More sharing options...
yoeddynz Posted October 4, 2012 Share Posted October 4, 2012 Pretty good HP from such a little engine. Does it feel robust or does it feel highly strung. Regards my engine- I think at some point I'll take along to local Mazda dealer and get a proper compression test done. See how it fairs. Quote Link to comment Share on other sites More sharing options...
yeah yeah na Posted October 4, 2012 Share Posted October 4, 2012 Nice effort Darryl, its great when development dollars and time reflect in lower lap times eh..... Quote Link to comment Share on other sites More sharing options...
sr1600 Posted October 7, 2012 Share Posted October 7, 2012 Whens your next race at taupo? Im coming up for a look That noise is just horny, you wait for the gear change while the revs just keep climbing and climbing. Quote Link to comment Share on other sites More sharing options...
Truenotch Posted December 24, 2012 Share Posted December 24, 2012 I see you were spied on over the weekend! http://bwarp.blogspot.co.nz/2012/12/blue-mazda-rx3.html Quote Link to comment Share on other sites More sharing options...
Evan Posted April 27, 2013 Share Posted April 27, 2013 Thats a bit unfortunate, any pics of the damage? Quote Link to comment Share on other sites More sharing options...
rxsumo Posted April 27, 2013 Share Posted April 27, 2013 No pics as yet - engine components were still in assemblies, waiting for cleanup to confirm the thinking to why the engine broke like it did. Quote Link to comment Share on other sites More sharing options...
morkster Posted July 28, 2013 Share Posted July 28, 2013 12a is a good idea if I may say.. Â Is that an NGK plug? Quote Link to comment Share on other sites More sharing options...
mjrstar Posted July 28, 2013 Share Posted July 28, 2013 not great luck on the engine side of things - oddly enough My brother in laws old R100 with the glen munro built 10A PPÂ took a severe beating with no dramas - apparently they are pretty picky with fuelling, his had a 48mm IDA on it / i know nothing about rotaries.. I think he still has the spare P plate 10A PP.. Quote Link to comment Share on other sites More sharing options...
rxsumo Posted July 29, 2013 Share Posted July 29, 2013 12a is a good idea if I may say.. Â Is that an NGK plug? Yep, a NGK Plug - but not with a build number on the faulty plug list.... Quote Link to comment Share on other sites More sharing options...
sr1600 Posted July 29, 2013 Share Posted July 29, 2013 Couldnt take mine back ether they were the plug but not the right part number. Â Shame about the 10a but bits are hard to find now let alone new ones, shall go well with a 12app , nice green brothers one for sale at the moment. Quote Link to comment Share on other sites More sharing options...
rxsumo Posted July 29, 2013 Share Posted July 29, 2013 not great luck on the engine side of things - oddly enough My brother in laws old R100 with the glen munro built 10A PPÂ took a severe beating with no dramas - apparently they are pretty picky with fuelling, his had a 48mm IDA on it / i know nothing about rotaries.. I think he still has the spare P plate 10A PP.. The big issue with the fueling that we found, was actually finding main jets small enough for the 10A/IDA combination. The standard weber sets are too big, which generally leads to fueling issues because the jets are to big, or inconsistancies because the jets are "filled and drilled". By hunting around you can find the tiny main jets, which is what we have fitted. Quote Link to comment Share on other sites More sharing options...
Evan Posted July 29, 2013 Share Posted July 29, 2013 I dont know if this would be of any interest to you, I saw this ad a week or 2 ago http://www.racingjunk.com/Street/181895187/1971-mazda-rotary-engine.html Quote Link to comment Share on other sites More sharing options...
Furai Posted September 4, 2013 Share Posted September 4, 2013 Man this things cool. Good luck with the engine! Quote Link to comment Share on other sites More sharing options...
