I've got this turbo manifold.. and I want it heat treated. I was going to wrap it but have heard that wrap corodes the metal eventually.
so I was going to chrome it but I don't think the chrome would last long.
what about HPC heat treatment? anyone know where to get that done??
FYI - I had the Exhaust housing and wastegate HPC coated. The Turbo lasted about 4 months before the seals failed and now Alltech are blaming the HPC coating for a failure saying that it didn't let the heat out and that the turbo couldn't be cooled correctly.......
They have advise me to remove the coating.....They also claim they have had similar issues with a turbo racing car that kept having the same failure until the HPC coating was removed.
yeah.. but the turbo headers would be ok wouldn't it?
I gotta do something.. 1 it looks naff..2 it gets really hot under the bonnet.
Yeah that was the same problem I had, hence the HPC
Yes I figure the headers will be ok so I am leaving them..
I know what you mean about heat!! Have to admit the HPC coating didn't seem to make any sort of noticeable difference....apart from killing the Turbo! It was still as hot a buggery!
Whats wrong the exhaust wrap? Wouldnt it only rot the pipes if it was wet under it? And even then itd take ages id think.
nah it's the oxidisation apparently.. confused with rust.. the metal needs to breath or something when it gets hot and cold etc.
Mates old man has some sorta paint then heat wrap then paint again thats on a 4AGE in a race car you can touch it after a thrash. It will eventually feck the inside of the runners because it keeps all the heat in it also depends on the wall thickness of the tube used. Thin exhaugst tube will tend to scale and fracture thick tube like 3-4mm steam tube will last a lot longer. My mate made turbo headers for his S13 he made them out of exhaugst tube they lasted about a month with wrap on them they were paper thin around the collector. He's made them out of steam tube I think last I heard. I looked at HPC coating for my headers but I'm to tight to pay I got a quote of $350 so I went yeah they can just stay like that.
Isnt oxidation a type of corrosion. How certain types of metal react with o2 etc?
Id just wrap them. Mates evo has been wraped for a year now and no probs at the mo. thats under similar boost to you.
For that it's worth I've just been on the phone to HPC over the issues with my Turbo, awesome help! They are (as expected) quite defensive of there product. But claim to have hundreds of Turbos with the Hyper coat extreme coating with a very small failure rate. Numerous race and rally vehicles....without issue.
In there experience most failure have been caused by other issues, high crank pressure, oil pressure etc.
I am not sure that to believe now, but I think HPC response has been by far the most professional so I am going to leave the coating on and see how I get on....
i had a big heat problem wif my turbo cortina, i made a heat sheild out ov that ally coated crinckle shit that xr6 turbos have. bolts to the top 4 exhaust studs and protects the leads. used to melt leads in half b4 i did that. acl makes it in sheets. any auto place cud get it frm them. hpc does look trick tho
i got the headers on the corty 'pro coated' in chrome ally coating it reduced the engine bay heat heaps they reckon it increases hp by keepin heat in the exhaust =better flow go figure was about 250 for v6 headers looked flash too
