excort Posted January 6, 2006 Author Share Posted January 6, 2006 well i got stuck in to the rear end of my car last couple days im quite happy with how it looks for now Quote Link to comment Share on other sites More sharing options...
excort Posted January 10, 2006 Author Share Posted January 10, 2006 well i just finished the body work on the front off and primerd the car im quite happy with how its turned out tho my gun keepd spitting shit all over it so it was abit of a hassle need a gravity feed gun to get it done properly i have a video of it going down the road but i do not know how to upload that to any sites etc if anyone knows of any ill put it on there cheers. Quote Link to comment Share on other sites More sharing options...
excort Posted January 12, 2006 Author Share Posted January 12, 2006 well heres alittle video its pretty dark but you get the idea http://www.dropshots.com/daymainframe.p ... imageNum=0 Quote Link to comment Share on other sites More sharing options...
excort Posted June 19, 2006 Author Share Posted June 19, 2006 Well its been awhile since ive updated everyone on my progress ive recently purchased a turbo inlet manifold (polished alloy) and im slowly purchaseing all the plumbing going to do a carbed set up first would like to do blow threw but not sure on how i can adapt the set up i have brought to do it with might just do suck threw for starters heres some pics Ive allso purchased a set of Bf good rich tires two 13inch 215's and two 235's all have 8mm of tread hardly used . Ive allso done quite abit of tidying up in the engine bay and the front and back of the car repainted the engine bay in black and clear lackerd it came up really nice brought a msd hvc coil and new water pump two times 13inch fans new cambelt and waterpump belt put all the chrome engine parts on engine mounts,cam wheels,etc brought a kn filter. planing on buying modgies to go with the tires soon that will do for now Quote Link to comment Share on other sites More sharing options...
excort Posted September 1, 2006 Author Share Posted September 1, 2006 well i just brought a Esslinger Flywheel 4kgs Quote Link to comment Share on other sites More sharing options...
excort Posted September 13, 2006 Author Share Posted September 13, 2006 my lattest purchase Esslinger-Mikuni Carburetors this is what i know about em. Carb Slides 39.5mm OD Choke Size 38.2mm ID Choke Outlet 38.mm ID Choke Outlet 43.5mm OD Inlet Size 56mm ID Inlet Size 62mm OD Overall Quote Link to comment Share on other sites More sharing options...
excort Posted September 13, 2006 Author Share Posted September 13, 2006 Just a thought Quote Link to comment Share on other sites More sharing options...
excort Posted September 15, 2006 Author Share Posted September 15, 2006 well ive got the carbs all hooked up now found out the vacume hose's are actually a breather hose and a overflow hose no vacume hose's lol they run really well got a really nice tone to them just need to tune them now not much clearance had to unbolt the carbs from the manifold to get the airfilters on. Quote Link to comment Share on other sites More sharing options...
excort Posted October 15, 2006 Author Share Posted October 15, 2006 startd reconditioning the front suspension/brakes etc brought new bearings and control arms and have stripd the struts etc bak and etcher primerd them then paintd them came up really good . Quote Link to comment Share on other sites More sharing options...
excort Posted November 16, 2006 Author Share Posted November 16, 2006 got me a new sway bar 24mm Quote Link to comment Share on other sites More sharing options...
excort Posted December 22, 2006 Author Share Posted December 22, 2006 well brought me a new head HARDEND SEATS, LAZER 300 CAM AND ROCKERS H/P SINGLE VAVLE SPRING MANLEY STAINLESS VALVES CRACK TESTED SURFACE GRIND FLOW BENCHED PORT WORK aparently the valves are larger 1.500 ex - 1.750 anyone know the standard size they dont look bigger :S allso started sound dampnering the floor with something i beilive will work same kinda stuf as that really exspensive dynamat just alittle bit thiner is used on building sites thermal seal around the windows etc seems to work quite well Quote Link to comment Share on other sites More sharing options...
excort Posted July 16, 2007 Author Share Posted July 16, 2007 i found abit of rust so decided to get rid of the bubble in the engine bay not to bad for a gasselis mig fron super cheap i feel allso i decided to make a new parcel tray with sound dampner underneath so will hopefully stop any rattles. allso i just recently put my engine in to get worked rods getting balanced,polished,lightend,shot peened,oversized arp rod bolts.Crank getting a slight grind,lightend,polished,balanced,flywheel dowled to crank.Block getting bored 60 thou out,top being decked,block fully cleaned out,new frost plugs oh and allso flywheel being balanced. all up costing ruffly 2k which im happy with will spend more on engine depending on funds. Quote Link to comment Share on other sites More sharing options...
excort Posted July 22, 2007 Author Share Posted July 22, 2007 well i finished welding the plate in the engine bay instead of the bubble had to tack weld the hole thing in which was gay but got there eventually allso had to weld a little strip below it which i think came up quite gud just cleaning up all the inperfections in the engine bay and then i can move on to the rest of the rust in the body woo. Quote Link to comment Share on other sites More sharing options...
excort Posted August 18, 2007 Author Share Posted August 18, 2007 Well i got my engine back from Hpe auto all up cost me $2500 which isnt to bad i guess wasnt exstremly impressed with there proffesionalism on the hole thing forgot to do several things even tho i reminded them like 5 times but its all be sorted now. Put the crank in and pistons used crc engine lube which should do the trick quite well was abit touch and go when i had to do the piston ring gaps but hellrazier gave me some info/advice on how and i got it sorted. Quote Link to comment Share on other sites More sharing options...
excort Posted August 19, 2007 Author Share Posted August 19, 2007 well i painted the engine up today quite happy with the colour scheme need to get some more chrome bolts tho heres acouple more pics . Quote Link to comment Share on other sites More sharing options...
excort Posted August 28, 2007 Author Share Posted August 28, 2007 more pics Quote Link to comment Share on other sites More sharing options...
excort Posted February 8, 2008 Author Share Posted February 8, 2008 well thought it was time to put something up havent in ages completely striped the engine bay and reboged everything took a good couple weekends to get it to how i wanted i feel it came up rather good got rid of all the holes in the engine bay etc weilded my clutch cable mount in properly now not just a hole in the fire wall lol sprayed it in etcher primer just got to mod the crossmember now then its paint engine bay put engine in get abit of wireing done and its all go prettymuch... couple other things ive brought since i last updated quafile quick shifter,adjustable cam gear high touque/light weight starter motor some other things but i carnt rember them all Quote Link to comment Share on other sites More sharing options...
excort Posted June 16, 2008 Author Share Posted June 16, 2008 well i finaly done some more to the esky engines fully in exhaust all hooked back up brakes hookd up removed brake booster modded one of the old linkages so the mastercylinder sits in the firewall was advised to do this by Hellrazier workd mint earthd my coil properly now so should have more luck with my electronic ignition so prettymuch all there is left to do is get the engine set up to be run in gets some new seats pannel and paint cert . Quote Link to comment Share on other sites More sharing options...
excort Posted August 3, 2008 Author Share Posted August 3, 2008 Well its finaly burst in to life makeing some intersting noise's but they are gradually going awway as it runs more got 110 psi b4 start up then 140 after about 10 mins of running noticed abig diference in how it ran after letting it cool down then start it up again 2ltr pinto first start Quote Link to comment Share on other sites More sharing options...
excort Posted September 13, 2009 Author Share Posted September 13, 2009 Well finaly the engine has been pulled down and put back togeather properly thanks to Nismo. The car is painted thanks to D.P.N.S and its all comeing along quite well took it out for its first drive today and it went really well only thing that let me down was not haveing a spring on the idle control screw which i didnt realise till i got home and the fiberglas bonnet flexing when i went over a 100 k but i will strengthin that some how running the bottem end in on a head supplied by Nismo with the standard 32/36 and once we feel its run in anuf will be upgradeing to a bigger head with the cam rockers and valves out of the head i previously brought turned out the port job wasnt so gud on it at one point it actually flowed worse than a standard pinto in the exhaust side. Nismo is building me a up a special head so should be very interesting heres a couple pictures. Quote Link to comment Share on other sites More sharing options...
