Ogre's 1981 Mitsubishi EX Lancer
Ogre
  • Replies 130
True, just went thru the threads looking for caboons lancer. Should have read title properly. Cos it certainly wasn't an EX i saw, twas the green LA. Oh well, its the thought that counts :lol:
And it still looks tuff
  • 6 years later...
No, its not. There are very few around, if knew of any they would be on my current engine with IDAs.
GSR supporo is the only ones i know of.
Also, read the rules in regards to posting in build thread.
  • 9 months later...
Considering it was about 7 years ago i had this, ill try remember.
GSR Sopporo is the only engines i have found the twin downdraft mani on here in NZ.
TBH i really wouldnt bother unless  you happened to have a mani lying around ( no one will coz there aint any) and then put some IDAs or somthing on it. The standard carbs are crap house. Twin downdraft webers might be better but i found a single weber 32/36 DGAV way better than twins.
On a pretty much standard SOHC the 32/36 is a real nice upgrade. Cheap and easy to do with the standard single manifold. Will support about 150hp. If its from a 2000cc capri or somthing it will be jetted pretty much right, may just need to go up one or two sizes in the idle jets.
Anything over that i would go quad bike carbs or twin sidedrafts.
The best way to upgrade a mitsi is get a FORD.
