Last one I saw, with those arms I failed it due to the way the threaded joints are loaded under accel or braking , the threaded parts are put under a bending load , which lvvta does not allow
But then recently I was part of a discussion where it was decided they were OK
But there hasn't been any official answer
So I dunno
Maybe save your $ for some pies
I've been meaning to make some spacers to take up the slack in nissan lower arm bushes as they deflect a lot and I have a theory I'd like to test
I drove a 800ish hp gtr a few months ago and the owner told me to give it some beans, so I did, and it did odd things under power , looking at how much the arms can move, I theorise that the alignment is all up the wazoo under heavy acceleration
  • Replies 10.1k
So I dunno
The engine made so much torque, the chassis twisted off the line.....
Weird question, but what's the legality of mounting a rotor on the front of a hub (secured by the wheel being bolted on, like modern brakes) that previously had it bolted to the back?
Obviously stud length is a consideration, and whatever the deal with the caliper is, but I guess as long as the rotor is hub or stud centric it should be fine?
I never certed it, but I did that when I put S13 brakes on my old 1200.
I showed the conversion to the local cert guy at the time, and he said it looked fine.
