bigfoot Posted September 24 Posted September 24 8 hours ago, oldrx said: Is the requirement for drive shaft hoops horsepower dependent? I am only going from 12A (120 ish hp) to 13B extend port guessing around 150-160 hp (factory carb) Wouldn't that come under increased capacity and need hoops anyway? 2 Quote
Bearded Baldy Posted September 24 Posted September 24 1 hour ago, cletus said: Had someone try that once, then argue that I had failed it for a rear tyre, not a front one, and couldn't fail it again.... guess what, motherfucker #metoo Also have pulled the 'yeah you have fixed your lights, but now your bumper is hanging off i still can't pass it' 'Aww come on man don't be a cunt.' 'If i was any more of a cunt i would taste like fish, go get a ya bumper sorted.' 1 8 Quote
oldrx Posted September 24 Posted September 24 15 hours ago, bigfoot said: Wouldn't that come under increased capacity and need hoops anyway? Don't think so, there's no mention of increased capacity in the drive shaft loop section of the car construction manual anyway (did my own home work for a change). Only the significant (50%) power increase applies. Quote
oldrx Posted September 25 Posted September 25 Trying to work out if Mig welding gearbox x-member and engine mount bracket goes hard for what they are? Kinda feel critical but the manual indicates critical is components that affect steering/braking. Pretty sure Mig is all good. Quote
Nominal Posted September 25 Posted September 25 20 minutes ago, oldrx said: Trying to work out if Mig welding gearbox x-member and engine mount bracket goes hard for what they are? Kinda feel critical but the manual indicates critical is components that affect steering/braking. Pretty sure Mig is all good. Yes, mig away. 1 1 Quote
tortron Posted September 26 Posted September 26 54 minutes ago, SOHC said: What about atomic hydrogen welding? Good enough to hold the p51 Mustangs propeller together Quote
sheepers Posted September 26 Posted September 26 can i get some clarification on drveshaft loop rules. this says, a drive-shaft where a drive-shaft hanger bearing is positioned directly behind a drive-shaft universal, and the hanger bearing is designed in such a way that it will effectively contain a failed or disengaged drive-shaft; my question is, is the r32 GTR center bearing carrier deemed sufficient to comply with the above? also, the wording of the manual is a bit vague as it says "each section of the driveshaft" at one point then it says "behind the universal joint" my driveshaft only has one universal and two CV joints, do i only need one loop?? Quote
RUNAMUCK Posted September 27 Posted September 27 On 24/09/2026 at 18:25, cletus said: i have been given them where they were running 2psi boost or something, so it has to be believable Oh my God, that's disgusting! What kind of unscrupulous rule breaker would even dream of attempting to perpetrate such a heinous act of trechery??!!! 1 6 Quote
tortron Posted September 27 Posted September 27 20 minutes ago, RUNAMUCK said: Oh my God, that's disgusting! What kind of unscrupulous rule breaker would even dream of attempting to perpetrate such a heinous act of trechery??!!! Nascar rules 1 1 Quote
Stu Posted September 28 Posted September 28 A mate of mine would like to relocate the batteries in his SWB safari into the back behind the rear seats. Am I right thinking they need to be in an enclosed box with vent to outside of the vehicle? Quote
cletus Posted September 28 Posted September 28 correct, and secured firmly so they do not become a danger to occupants in event of a mishap Quote
cletus Posted September 29 Posted September 29 Doesn't have to be in a box but it is a good idea It has to be vented outside the cabin If it's not in a box the positive terminal has to be covered If it's in a box then either the box has to be sealed with a vent tube outside if it's not a sealed box then a tube straight from the battery to outside The only time the battery has to be in a box is when it's in the same compartment as the fuel system, then it has to be in a non conductive box I don't know why but it's in the fuel system chapter of the CCM 1 Quote
ul9601 Posted September 29 Posted September 29 6 hours ago, cletus said: ...The only time the battery has to be in a box is when it's in the same compartment as the fuel system, then it has to be in a non conductive box... Like if a fuel tank is in the boot and battery goes in the boot too? Quote
igor Posted September 29 Posted September 29 2 hours ago, ul9601 said: Like if a fuel tank is in the boot and battery goes in the boot too? Like all classic Minis? Quote
cletus Posted September 29 Posted September 29 2 hours ago, ul9601 said: Like if a fuel tank is in the boot and battery goes in the boot too? yes 1 Quote
cletus Posted September 29 Posted September 29 12 minutes ago, igor said: Like all classic Minis? does not apply if its not modified so if its factory, the battery doesnt have to be in a box if it wasnt originally 4 1 Quote
sheepers Posted October 2 Posted October 2 what does the LVVTA say about these lower arms? https://thrashgaragenz.com/products/gktech-v2-adjustable-rear-lower-control-arms?_pos=30&_sid=cf82a476a&_ss=r Quote
