Beaver Posted September 9 Posted September 9 More cc means cert. Most of these questions take 30 seconds of googling and reading the VIRM to answer. Leave clint alone so he can make more top tech tip videos please 9 Quote
Bearded Baldy Posted September 10 Posted September 10 1 hour ago, cletus said: Your catch can is fine to dribble back into the sump The emissions standard is only applied to vehicles with an engine swap , for example if you put a 3.8 Commodore v6 into your gtr, then the pcv system has to operate, ie the crankcase gases have to go into the intake manifold You are free to operate your vehicle emitting crankcase vapors with no regard for hectors dolphins, Has he upgraded from spoon engines? Quote
cletus Posted September 10 Posted September 10 42 minutes ago, xsspeed said: is the same engine family but bigger capacity block and head considered a swap? is there a granddads axe scenario. Its the same crankshaft the rest is just modified. or do i need to concern myself with trojan sea horses ah yes now we are getting into technicalities if you put a different engine in ie a rb25 where a 20 was, thats an engine swap as its not the same engine, emission standard must be applied however if you put a later rb20 in, imo thats the same engine as it had, so emissions stuff not required if you did some magic and put a 25 crank in the original 20 block and it made 11 thousand horsepower, no emission stuff either side note , complying with emissions standard for lvv is not particularly difficult. most cars only need to be running right, pcv system is the most common failure, engine check light to work if using an oem ecu, cats are not usually required 7 Quote
Hemi Posted September 10 Posted September 10 23 minutes ago, Beaver said: More cc means cert. Most of these questions take 30 seconds of googling and reading the VIRM to answer. Leave clint alone so he can make more top tech tip videos please Nah, because then you can go "but Clint says it would be ok, he said exactly that it would be good and to call him if there's any problems and he will sort it personally" 1 5 Quote
xsspeed Posted September 10 Posted September 10 Clint loves RBs Beaver they're his favorite demographic Quote
440bbm Posted September 10 Posted September 10 18 hours ago, xsspeed said: Clint loves RBs, but Beaver is his favorite demographic fixed. 8 Quote
RUNAMUCK Posted September 12 Posted September 12 On 25/08/2026 at 20:03, cletus said: it can be welded lvvta has rules around mounting things to sides of chassis rails, that involve making sure the bracket spans the full height of the rail, to prevent oil canning so i would suggest a bracket that achieves that, if youre making one anyway Revisiting this fun factoid, Fucking around with my shitheap today, will this surge tank mounting bracket require a full height doubler plate? Quote
cletus Posted September 12 Posted September 12 Probably not as its usually applied to engine, suspension or steering type items , But If you're going to weld it on it wouldn't be hard to add a couple of small gussets to achieve that 1 Quote
Bearded Baldy Posted September 13 Posted September 13 Hey mr Cletus, me again. The seat retention hooks have 2 bolts holding them on. On the backing plates i drilled a hole in each corner thinking all bases covered that way. But i have an issue! Can i run with just 3 rivets? If not, the purple line is roughly where the back piece of plate stops. Will buttwelding a plate the same thickness as the back where the yellow lines are be ok with some plugwelds holding them to the front side? Cheers. Quote
cletus Posted September 13 Posted September 13 Are you bolting the seat hook brackets straight to the car, or are you using doubler plates to mount them to the car, I don't really get what you are doing there Quote
Popular Post Nominal Posted September 13 Popular Post Posted September 13 2 hours ago, Bearded Baldy said: Hey mr Cletus, me again. The seat retention hooks have 2 bolts holding them on. On the backing plates i drilled a hole in each corner thinking all bases covered that way. But i have an issue! Can i run with just 3 rivets? If not, the purple line is roughly where the back piece of plate stops. Will buttwelding a plate the same thickness as the back where the yellow lines are be ok with some plugwelds holding them to the front side? Cheers. Are you sure you aren't overthinking this? 1 11 Quote
Bearded Baldy Posted September 13 Posted September 13 My kids will be riding in the back. Not me. Quote
Bearded Baldy Posted September 13 Posted September 13 Granted they will probably be adults by the time the car is finished. 2 Quote
Bearded Baldy Posted September 13 Posted September 13 You shut your mouth! And yes. I just refuse to acknowledge she is now old enough to vote. 2 Quote
Bearded Baldy Posted September 13 Posted September 13 1 hour ago, cletus said: Are you bolting the seat hook brackets straight to the car, or are you using doubler plates to mount them to the car, I don't really get what you are doing there Ah crap sorry @cletus, i thought i had added those pics too. Have these 3mm plates to go in behind, nuts still to be welded on. So yeah the cars panelling will have the plate riveted to the back side of it, and the actual bracket will be bolted on from the front side. But one the rh side of the car, only 3 of the rivet holes line up with steel, one is free floating. Do i need to fill in the missing area to use rivet #4 or can i ignore it? Or just move that rivet up 10mm? Quote
nzstato Posted September 15 Posted September 15 Posting this here because it may help others out, though its a very narrow case... As in my LandRover thread, this vehicle had been modified under the old declaration system (pre cert plates) AND has had a consistently live rego since the declaration was made. There is no old 'declaration plate', literally a piece of paper which goes with the car. In the event (like me) you want to completely revert the vehicle to original you can easily do so with very little admin cost. All I've needed to do is: a) full out an M16a form, with the correct changes (mine was just an update to body colour and engine) https://nzta.govt.nz/assets/resources/Application-to-change-motor-vehicle-details-MR16/Docs/MR16-Application-to-change-motor-vehicle-details.pdf b) have a WOF garage sight the vehicle and write a short letter stating what has been reverted to original and that the vehicle is so(this should satisfy all items on the declaration paper which indicates modification). I got a WOF too but you possibly don't even need to. c) send all the documentation to NZTA. Just got a friendly ph call from NZTA to clarify a point I needed to do under b), but other than that they say this is a very straight forward case. NB: This case is detailed in the M16a form under: Modified back to original If an LVV plate has been issued for the previous modification, the LVV plate can only be removed by an authorised LVV certifier who must also confirm modification back to original as-manufactured condition. If no LVV plate has been issued for the previous modification, any authorised Waka Kotahi NZ Transport Agency inspector for that class of vehicle must confirm modification back to original as-manufactured condition. I 1 2 Quote
cletus Posted September 16 Posted September 16 On 13/09/2026 at 17:18, Bearded Baldy said: Ah crap sorry @cletus, i thought i had added those pics too. Have these 3mm plates to go in behind, nuts still to be welded on. So yeah the cars panelling will have the plate riveted to the back side of it, and the actual bracket will be bolted on from the front side. But one the rh side of the car, only 3 of the rivet holes line up with steel, one is free floating. Do i need to fill in the missing area to use rivet #4 or can i ignore it? Or just move that rivet up 10mm? id just cut an angle on the plate so its not overhanging the edge, and put the rivet up a bit, or leave it out as you only really need 2 id do the same to the other side but only because i have ocd and it would haunt my dreams knowing they didnt match 1 1 Quote
dmulally Posted September 16 Posted September 16 On 10/09/2026 at 11:24, xsspeed said: is the same engine family but bigger capacity block and head considered a swap? is there a granddads axe scenario. Its the same crankshaft the rest is just modified. or do i need to concern myself with trojan sea horses 3.6 to 4.0? Quote
Adoom Posted September 16 Posted September 16 Can I cut and weld the 'CV axles' in my IRS suspension myself? Or does it have to be done by a 'professional'? Is there testing required? Quote
