Whats the deal with a 57 Fairlane that has the original factory optional lap belts but needs to go thrugh the vin prosess as it has been imported. They didn't have any seat belts from factory unless orded
  • Replies 10.1k
Should be ok with lap belts. May need to reweb them
If you want 3 points they'll need lvvta cert
The B pillars would need serious work to be able to take a upper seat belt anchor as I can flex it with one hand
We did a 58 Fairlane at work recently.
It's doable
It's doable
What design proof do you have to provide?
We just delt with the certifier and came up with a solution that was sensible.
I also did a cloud 3 rolls same kinda deal just came up with a sensible mount and lvvta were ok with what our certifier was ok with
Did you have to make reinforcement for the piller?
Yeah not to much though
The fairlane they were happy with a crush tube welded into the pillar with the head of the bolt protruding externally.
And the cloud 3 rolls royce I had to add a brace internally and use an approved seat belt thread plate thing .. initially lvvta wanted us to add extra structure into the roof rail and tie the 2 pillars together through the roof with extra support etc which was nuts. But the certifier we use pretty much told them to pull their heads in and we came to a more sensible solution
anything post 55 needs lap +diagonal belts for the front
there are some exemptions for cars with no b pillar or anywhere to put an upper anch but usually a car that has a b pillar has to have anchorages fitted, as there are a few recipes for how to do this in the CCM on lvvta.org.nz
it usually pisses people off as it often requires welding to the pillar
  • Confused 1
I know of lots of imported 60's American cars which have gone through the VIN process with only the original front lap belts.
Is lap/diagonal for the front an LVVTA requirement or a general NZTA import requirement?
I think if you have the original lap belts you are ok but if you replace them you need to upgrade to 3 point mostly.
I still have the original lap belts in the 64 Mercury.
I seem to remember hearing something a long time ago to the effect that if you changed anything on an import car and it needed a cert for that change then it became a requirement to upgrade the seatbelts to current standards also. Might have been bullshit too.
correct.
if the original lap belts are still fitted and are in good condition, they may remain
50s american cars mostly did not have any belts at all, they were only optional in some cars- so they often need cert for seat belt anchs at compliance , which means upper anchs have to be fitted most of the time, as lvvta has recipies in the CCM to do so
1968 there was a rule introduced that all seating positions had to have belts fitted so you tend to see lap belts in the front fitted from the mid 60s onwards which is why you see mustangs etc with lap only belts , legally
as for lvvta vs nzta requirements this is where it gets murky
ive seen quite a few cars with new repro lap belts go thru compliance which is incorrect.
lvvta has also said there was a rule change in 1968 that mandated lap and diagonal belts in the front so they wont accept say a 69 camaro with lap belts as it should have had upper anchs for lap diag belts, i have had cars knocked back for certs for other things but only having original lap belts
however ive seen multiple 68-on cars that have never had an upper anchorage at all
my 68 plymouth had the option of lap only, the diagonal belt was seperate and could be clipped into a clip up under the sunvisor
there was a bit of fuckery with seat belts for a while until everything got kind of standardised
may be the wrong place but it is something i've often wondered regarding the seat belts.
on these older vee hickles, that are lap belts, and only had them fitted to the outer 4 positions. but are bench seats, front and rear. is it legal or unlegal to have a 5th and 6th person in the middle as theres no belts fitted.
Depends on the age
So short answer is, its not illegal. But can u get fined for it if over 14?
Appears to be quite a grey area. Something feels like thay data isnt all there is to the subject?
On 06/09/2026 at 13:57, cletus said:
Tein= good
Cusco= usually ok although the welding can be a bit poos sometimes
Ikeya formula have not seen a new set of those for years , only ones ive seen have been 20+ years old on Japanese imports
Spherical bearings/heim joints/pillow balls etc can be ok if Teflon lined good quality and appropriate load rating
I usually recommend hardrace for a street car as the bushes are a longer lasting choice
Gktek is another good choice, if I was buying arms and wanted spherical joints thats what id use
ALL adjustable arm manufacturers have issues occasionally so be aware of that, usually around clearances at full travel, weld quality or side loading threaded joints
Personally id avoid aftermarket arms if you dont need them . 4wd skylines handle better a bit higher , usually only need arms if slammed, but then they drive shitty imo
Camber max .5 deg over factory spec, or 1.5 deg negative, whichever is more
i ended up getting some Gktech parts. their front upper link is a really well thought out part and will allow fixing of some of the rubbish geometry in the front of the GTR.
also i didnt want spherical bearings, its just that everything comes with them now so you have no choice if you want some good adjustable parts.
and also also, i dont want to slam the gtr, i only want to lower the front by about 5 - 10mm. The struts in the car are the original ones and are 35 years old so they cant be far off fucked.
i have to cert it, so why wouldn't i put a set of coilovers in it while im about it.
any who,
Question for clarity that has probably been asked before,
can the oil catch can return into the sump of does it have to go into a PCV in the intake? the LVVTA manual isnt clear, it just says "return into the engine"
many,
many thanks.
is the same engine family but bigger capacity block and head considered a swap? is there a granddads axe scenario. Its the same crankshaft the rest is just modified. or do i need to concern myself with trojan sea horses
