Nominal Posted February 14 Posted February 14 35 minutes ago, JamesWalker said: Just replaced all my rear leaf bushes for wof and they were all still mint just some weathering/cracking on the exposed part of the edges. They were done about 2 years ago so I figured this would be the case. Do they test play on these or is there a guideline on the aesthetic look of the outer edge/some safety issue im missing here? They can be failed if cracked. Find a new WOF shop? Quote
JamesWalker Posted February 14 Posted February 14 14 minutes ago, Nominal said: They can be failed if cracked. Find a new WOF shop? Think I'll have to. New area and it flew through last wof with them. I guess its a bit of a hard one as its the only bit they can see but the cracking goes about 1mm in if im generous. Its done now, think I'll let them know, in a friendly way, on the recheck, and shop elsewhere. 3 Quote
Crispy Posted February 23 Posted February 23 What are the rules around replacing wheels with another oem wheel from another car? Backstory is I have 20 inch wheels on my 2wd Hilux and they are probably over the 5% rule. My wof guy mentioned it last wof and I think he was hinting if I don’t get new wheels next time he will fail me. Seen heaps of oem new Rav 4 and Highlander wheels which should do the trick and look ok for a good price. And the weight of the vehicles should be around the same (but will double check). If I get the right sized tyres to be under the 5% threshold and wheels of a vehicle the same weight or heavier it all should be ok? Quote
Bearded Baldy Posted February 24 Posted February 24 Just get a set of standard hilux rims and tyres? If you are only using them for a wof then hit up the 4x4 section on marketplace. Always people selling factory gear. Quote
Crispy Posted February 24 Posted February 24 I’m thinking about making it a permanent change. And 2wd Hilux (mine is an n70) are 5 stud. Quote
igor Posted February 24 Posted February 24 Pretty sure Falcon and Valiant rims fit Toyota five stud. That'd give you a few more options. Quote
Crispy Posted February 24 Posted February 24 16 minutes ago, igor said: Pretty sure Falcon and Valiant rims fit Toyota five stud. That'd give you a few more options. Yea ofc. Later model falcon wheels may work. But. I was just wondering if there are any rules referring to vehicle weights and wheels. I know there is something in there for cert. But what about normal wof? Quote
xsspeed Posted February 24 Posted February 24 Iirc the issue with cert is factory wheels don't seem to have a weight rating published or cast on them. I've never encountered swapping wheels as a wof issue and I'd expect you'd be pretty safe using something more or less equivalent (factory wheels are likely to have shitloads of safety factor built into them). Can't answer if there's specific wof rules for this case. If you're not wanting to just send it, could you ask the garage/joker in advance of purchasing if they'd accept that Quote
Nominal Posted February 24 Posted February 24 1 hour ago, Crispy said: I’m thinking about making it a permanent change. And 2wd Hilux (mine is an n70) are 5 stud. If you are within these rules you should be all good. it's not the wheel size that matters for the 5%, it is the tyre sizing. 1 2 Quote
Bearded Baldy Posted February 24 Posted February 24 9 hours ago, Crispy said: I’m thinking about making it a permanent change. And 2wd Hilux (mine is an n70) are 5 stud. Ah sweet as. If you find some factory wheels off another toyota similar size you will be sweet. Eye appeal is 90% of rhe fight. Quote
smokin'joe Posted February 24 Posted February 24 falcon have a larger centrebore , so will need hubcentric rings 1 Quote
cletus Posted February 25 Posted February 25 cert= cant use a OEM wheel from a vehicle with a lower GVM, which is a common issue with commercial vehicles, as they often have a higher gvm than a passenger car 1 Quote
xsspeed Posted February 25 Posted February 25 4 hours ago, smokin'joe said: falcon have a larger centrebore , so will need hubcentric rings dont think this is a must for wof, but inspector might require - technically if wheel is centred through lug-centric attachement i understand its considered attached properly 2 Quote
Crispy Posted February 25 Posted February 25 7 hours ago, cletus said: cert= cant use a OEM wheel from a vehicle with a lower GVM, which is a common issue with commercial vehicles, as they often have a higher gvm than a passenger car This is what I was meaning. I assume it’s not a wof issue though…. Quote
xsspeed Posted February 27 Posted February 27 Wheel question thats been bugging me, what's the no BS eyes of the law/insurance perspective on road use of rebuild 3pc wheels like using pine, or what I have seen more of lately starting in nz, custom cnc centres Is there even a route to get them legal? Quote
Beaver Posted February 28 Posted February 28 But also this. If Pine is saying not for on road use then arguably it can't meet this requirement. 1 Quote
Truenotch Posted March 3 Posted March 3 Two questions: 1. On a car with a significantly modified floor pan, does the certifier need to see the work before and primer or paint is laid down? Or can it be put in primer before it gets inspected? 2. Can these bumper mount/boot floor stiffeners be chopped off or tapered down? They are unsightly and they won't be used for the rear bumper mount anymore: Quote
cletus Posted March 3 Posted March 3 19 hours ago, Truenotch said: Two questions: 1. On a car with a significantly modified floor pan, does the certifier need to see the work before and primer or paint is laid down? Or can it be put in primer before it gets inspected? 2. Can these bumper mount/boot floor stiffeners be chopped off or tapered down? They are unsightly and they won't be used for the rear bumper mount anymore: might be a depends on the certifier thing, but if the welds are clearly visible through the primer and not ground or covered in bog/sealer etc i would accept that could chop the boot floor supports down or taper them, i wouldnt remove them fully though 1 Quote
