Just had another read. I had gotten the names confused between doubler plates and underfloor mounting plates.
Doesn't matter as they have to be 3mm plate too i see.
Am i right in my understanding that if i make seat bracket that touches the floor 110x50mm (5,500mm³), that i can use an underfloor plate instead of doubler plates?
  • Replies 9.9k
Hey my fil is currently building a replica of this old thing (1928 studebaker special), straight 8 powered with a Toyota box and a 28 studebaker modified chassis and diff, he’s wondering if he can get it road legal? As he doesn’t want side intrusion bars (no doors), gards , roll bars, shoulder seat belts, windscreen wiper, sun visor etc. thanks
Yes if the top plate has the same minimum footprint as a doubler plate, then you don't need to fit top plates
Windscreen you can get away with not having sun visor or wipers if its a wind deflector ie if you look over the top of it not through it then it's a wind deflector
Roll bar is not compulsory, an open car it just has to have provision for one
Lap and diagonal belts are not avoidable on a scratch built vehicle (I'm assuming that's what this is going to be) OR you can fit harnesses but there are other requirements like 3 mirrors , head rests etc
No guards requires a fender exemption, has to be under a certain weight, pre 1935 body , and you have to belong to a nzhra hot rod club
Doors- it doesn't have to have doors but it does have to have enough height to keep the occupants inside the vehicle - the details are in the door standard on lvvta.org.nz
In short yes you can build a replica but it still has to meet the minimum safety requirements which, to be fair, are a very low bar for 2025/6
10 minutes ago, xsspeed said:
are you allowed to modify the calliper body at all? ie take 5mm its mounting surface
Not easily
Short answer no
Long answer possibly if you could supply proof that the material removed does not weaken it past a safe point,  this would probably require discussion with lvvta (a) to see if that would even be looked at and (b) what the loading requirements would be, to enable an engineer to do FEA to prove it is strong enough
Looking at it I don't think it would be a go, looks like quite a bit of material removed
thanks clint, that makes an "easy" option hard
what about this sort of thing, brackets to set the calipers further out from hub center to run a bigger disc
If it's on an original 1928 studebaker chassis he should be able to rego it as a 1928 studebaker with lvvta for the gearbox and rebody ?
Assuming it's a president motor and chassis . There should be no issue
Correct, if its a modified original car instead of a scratch built replica then it only has to meet the requirements of a 1928 vehicle
There's an info sheet on mod production vs scratch built definitions
https://lvvta.org.nz/documents/infosheets/LVVTA_Info_02-2018_Modified_Production_&_Scratch-built_Low_Volume_Vehicle_Definitions.pdf
Yep that type of bracket is common
Would need to be 6061 t6 (lvvta requires this as a minimum for most critical function parts) or equivalent strength if alloy and thick enough everywhere
This question is one probably better suited for Facebook as an anonymous post....
Is it possible to body swap on a monocoque chassis and be legal in NZ? Understand there is a fair bit of structural pitfalls there, would adding a roll cage and jumping thru those hoops make it work/easier?
Brennan's one here is on a Lexus  so it is definitely possible.
Dunno, depends on the situation
There are allowances for repair ie if you have a rusty car with a legitimate ID,  and you can buy a new replacement body ie a mustang, mini etc then that can be done
Repairs can be done ie quarter cut if it's done by a panel beater
Where it gets murky like "everything except my firewall was rusty so I replaced the rest" starts sounding like a plate and tag swap so you'd need to get nzta involved before you start so that it doesn't look dodgy
Edit;  my brain immediately assumed rusty subaru body swaps
What @Nominal said
  • Haha 2
@Nominal thanks, will go for a nosy when im on break.
@cletus yea rusty Subaru thoughts are right, the more we get into it the worse it gets, there was a wrecked wrx in the shop and the boys said be less work to effectively put the top part of the Leone on the bottom part of a WRX than fix the rust... which lead to a conversation... which lead to bad ideas over beers and now I'm here contemplating life and probably poor decisions (made doubly worse by being addicted to rusty Subarus)
  • Haha 1
