cletus Posted July 21, 2025 Posted July 21, 2025 seat belt bolt should be 7/16 unf, or 12mm to meet cert reqs however, sometimes with van stuff, there is things that dont meet LVV rules, but have engineering paperwork to cover it via calcs or testing ive never heard of a 8mm bolt being ok for a belt anch though there are some less than 100%scrupulous van fit out companies around so it would not surprise me one bit if someone hasnt looked at it properly is that one where the floor that attaches the seats is glued in? done by a company in south auckland? 1 Quote
GARDRB Posted July 21, 2025 Posted July 21, 2025 @cletus, if you have a vehicle like a DC5 or EP3 that is certified with welded coilovers and you modify it further and require a new cert, do you have to throw the previously certified welded coilovers out for the re-cert? As far as I understand there is no way to legally weld the base on in the Honda steering setups? Quote
cletus Posted July 21, 2025 Posted July 21, 2025 it may depend on the situation i certed one once that went through an approval process, it had teins in it from memory that was prior to the info sheet covering this situation there will no doubt be some that sneaked through, on the old plate system it would just say adj platform, so another way of getting them certed was to get some adjustable platforms fitted to the factory shocks, get cert, then put BC ones in so not all of them are legitimately certified the problem is, info was not always accurately recorded so it often results in emails to lvvta to sort out what can stay and what cant be re certed under the new system with photos. if i was presented with one, i would get lvvta involved to cover my ass 3 Quote
MRT1TRD Posted July 21, 2025 Posted July 21, 2025 18 hours ago, cletus said: there are some less than 100%scrupulous van fit out companies around so it would not surprise me one bit if someone hasnt looked at it properly is that one where the floor that attaches the seats is glued in? done by a company in south auckland? Yes The transformative automotive establishment is located in south Auckland. the floor attachment is hard to see and there is new floor covering and a large battery obstructing vision but the 3rd row floor bolts look questionable with glue and no nuts I have previously had to fail a wof on a new hiace that they did a conversion on due to the belts chafing on metal. I have also experienced a lot of damage to under dash wiring with companies installing bird’s nests to allow for disabled controls 3 1 Quote
Bearded Baldy Posted July 30, 2025 Posted July 30, 2025 Yup. So long as they are behind the rear of the cab. Not set up in a way that could hurt pedestrians, set anything on fire etc etc. Quote
Honda Ass Dragger Posted August 2, 2025 Posted August 2, 2025 AM I cooked for cutting the bumper support? (Car is Oct 95) Quote
Bearded Baldy Posted August 2, 2025 Posted August 2, 2025 What year was it first regoed? Can you see the support bar when the bumper is on? Quote
Honda Ass Dragger Posted August 3, 2025 Posted August 3, 2025 7 hours ago, Bearded Baldy said: What year was it first regoed? Can you see the support bar when the bumper is on? Car was first rego'd in AU in Oct 95 - but i'm planning to bring it back to NZ with me next year Quote
Bearded Baldy Posted August 3, 2025 Posted August 3, 2025 No frontal impact requirements for yours, but note 10 could be argued that too much has been taken away for it to remain structurally sound. This is from a wof veiw. Entry certification is a whole other ballgame i have no interest in. Quote
ThePog Posted August 28, 2025 Posted August 28, 2025 Kindof relevant to the above ^ If I were to cut out the floor of the X1/9 and weld a new lower floorpan in, I am assuming that would need a cert? Quote
Nominal Posted August 28, 2025 Posted August 28, 2025 1 hour ago, ThePog said: Kindof relevant to the above ^ If I were to cut out the floor of the X1/9 and weld a new lower floorpan in, I am assuming that would need a cert? A rust repair type of thing, or a modified floorpan? Quote
ThePog Posted August 28, 2025 Posted August 28, 2025 17 minutes ago, Nominal said: A rust repair type of thing, or a modified floorpan? I like your thinking, but this would be a mod. Quote
Popular Post cletus Posted August 28, 2025 Popular Post Posted August 28, 2025 2 hours ago, ThePog said: Kindof relevant to the above ^ If I were to cut out the floor of the X1/9 and weld a new lower floorpan in, I am assuming that would need a cert? Yes. Does need cert. An outlaw could do 'rust repairs' both sides, making a measurement mistake whilst doing so and put factory looking swages and things in the floor panels so it looks factory, and due to the rarity of the vehicle I'd wager that most inspectors would not pick it up, if it's not obvious But that would be illegal , and should be certified of course heavens, I can't imagine someone breaking the law to avoid certification 7 2 3 Quote
ThePog Posted August 28, 2025 Posted August 28, 2025 2 minutes ago, cletus said: Yes. Does need cert. An outlaw could do 'rust repairs' both sides, making a measurement mistake whilst doing so and put factory looking swages and things in the floor panels so it looks factory, and due to the rarity of the vehicle I'd wager that most inspectors would not pick it up, if it's not obvious But that would be illegal , and should be certified of course heavens, I can't imagine someone breaking the law to avoid certification Lols I am thinking of it because technically if I put the Uno Turbo brakes on it needs cert, although again it is all factory bolt on and who would know nowadays anyway. So if there was enough stuff I would just get the cert and get everything covered off along with some other improvements, ie floor/K20 turbo swap etc. Plus I am a generally law abiding chap and tend to get edgy when driving uncerted/unwof'd/unreged vehicles. 3 Quote
anglia4 Posted August 30, 2025 Posted August 30, 2025 Is this engine mount likely to fail a VIN inspection? Quote
anglia4 Posted August 31, 2025 Posted August 31, 2025 Well I guess I’m lifting an engine today not just dropping the trans 😂 Quote
Popular Post AllTorque Posted August 31, 2025 Popular Post Posted August 31, 2025 and the snowball begins 7 6 Quote
