Removing airbag system.
Car is a 98 so should fall under the being more than 14 yrs
I will remove the drivers and passenger airbags, and as its all apart I may as well take out the computer and wiring.
There's no side airbags or rear airbags, but it'll looks like the front seat belts are the explosive charged types.
Is it a requirement to replace these with non charged types?
edit* i found the section i think and it looks like i need to change any affected seating positions with new belts
also it says any cavities from removing the airbags need to be filled with some kind of foam. any recomendations on that? i assume it would just be for the passenger dash one (i wanted to turn that into a hinged door and hide stuff in it lol, i could probably even grab a non airbag dash)
  • Replies 10.1k
airbag removal- for each seating position where a bag has been removed, a new belt must be fitted- its meant to be a web clamp belt but these are getting hard to find
so if a web clamp belt is not available, supply a letter from a seatbelt supplier saying the web clamp belt is not available, and fit a new dual sensitive belt and matching buckle
dash one- you can leave the bag in the dash, just unplug it
fitting non airbag dash is fine
funny fact about air bag removal- theres a form to fill out, its a legal document basically saying i told you not to remove the bag and if you die its your fault not mine
it must be signed and dated, and a witness sign and date as well. i always put an arrow pointing to the bits that have to be signed and info filled in, and tell the customer to read and understand the document
every.
single.
time.
its either not signed, or the witness hasnt signed it, or theres no address etc
generally, people who remove air bags to fit an aliexpress fake OMP racing car wheel, are mentally deficient
every.
single.
time.
something like these securon intertia reels?
https://classiccarparts.co.nz/index.php?route=product/search&search=Securon &description=true
they are actually on clearance at repco for 10borks which would be nice lol, letter from securon or local supplier? (im not set on those, but to get an idea who to bother)
Basic question for the pros on here I hope.
I have a 1996 Fraser (Lotus 7 replica) matching the original cert plate.  If I was to make a change, say from carbs to EFI which requires certification what is the scope of that process?  Is it just the changes to the EFI or is the whole thing up for debate again, noise, ground clearance etc?
I am comfortable that the car currently matches the cert plate but not so comfortable that if it was presented for certification today it would be ok.
Pretty sure everything is checked to be safe but old stuff doesn't have to be changed to meet new rules. No idea on the noise side of things though.
From their FAQ's
Quote
Can I modify a vehicle which already has already been LVV Certified?
Yes, but the vehicle will need to be re-inspected by an LVV Certifier who will issue a new LVV plate covering all the car's modifications. Most modifications that fall within the Certification Thresholds do not need re-certification.
^ correct. if everything matches then we only have to inspect the things that have changed since last cert- apart from a basic safety check to make sure everything is in a safe condition
sometimes there are issues with cars that shouldnt have been certed in the first place, or theres something that should have been on the cert that isnt, then we have to figure out if it was done at the first cert , or if its been done since.
many scratch built certs are light on details- as the thinking back in the 90s- if its modified, needs cert. so if it has cert plate= its certed
this is actually a big headache now, as the years pass and the expectation of what has to be on the plate has changed, now people have problems at wof time
for example i had a customer ring today who had a certed vehicle fail on tyre size being over 5%bigger than oe. certed for bigger wheels.
with the new data discs the tyre size is listed
the old plates did not have that.
now the wof inspector wants proof it was certed with the tyres it has fitted
Shouldn't the logic with that be, do the tyres rub? If no then...
Are the tyres correct for rim size as per lvv spec sheet? If yes then
Are tyres the correct load rating? If yes then whats the issue.
Wof guys obviously trying to safeguard himself, but if tyre size isn't on old cert plate, then his request of proof is a bit outside his paygrade and common sense should kick in.
This is a constant pain I have, bigger wheels were dealer fitted way back before rules were made so the cert plate just says OE, now with all the commotion over mud tyres the wof man fails me on the same size as fitted the day of cert.
Have a few other inconsistencies on the cert plate but I doubt there are many wof inspectors left who can correctly identify Fiat/lada gearbox housings, the original inspector couldn’t!
ha
wof guy was actually right
it was a car i certed, it had 37s on it but wouldnt pass the brake test so it had 35s fitted for final check, i still had photos of it
I'm just gonna dump my rant here - it's stupid that a car that gets certed for something completely unrelated to suspension or wheels gets locked into whatever wheels it had at time of cert.
Example: Starlet has cert for EFI, now requires OE wheels.
The hunter got certed with escort steels.
if I put the hotwires on it requires a recert right?
but a stock hunter can run them with no issue.
bit fkd tbh.
wheels should be free providing they fit within the complying guidelines and tyre sizing and no rub etc.
We are lucky to have the cert system. The rules are set out before you start the process. So to me its either you accept them and deal with it. Or modify the car to stay outside of the rules that require LVVTA attention. It's good that here that you can modify cars, changing wheels miles away from OEM spec and get away with it. Plenty of places don't allow it. Clint just posted a perfect example of why changing wheels post cert can be bad. The car can't even pass a simple brake test with the wheels it's rolling on. Plenty of ways changing wheels can be detrimental to a car IMO. I tried to keep my car out of cert territory, but all the fun stuff is there, so I couldn't.
Plenty of people swap wheels and then on sell the car making it quite the fun time for the next owner. See it on Facebook all the time. If they post enough info you can check the cert photos and see how far from passing a legit WOF the overpriced car they are selling is.
Who is going to check the swapped on wheels meet all of the requirements they needed to pass cert? Certainly not car owners as too many are 100% retarded. So things like not made of cheese, aren't cracked, don't rub, can pass brake test, if a spring brakes they will provide enough ground clearance to not plow the road, just so many things. Normal road cars just get away with a LOT, when you step in to cert territory you get someone that has a clue actually check the car is still safe.
I don't think i'd bother certing a car for one change, due to the fact it locks the car to a spec. And also due to the cost and process of cert.
/rant
/stuck with my wheels but they are shiny so don't care
I agree with you, and seeing the terrifying shite that Clint gets presented with, I'm glad some of that can be taken off the road and/or fixed.
But it does still suck that you're locked into everything at the time of cert, even for something like a manual conversion. Changed pedal box, nope, can't use lowering springs or different wheels now.
Yeah there are certainly situations where a modification that is certed doesn't really change the car that other mods would be affected.
Must be quite a few manual swaps on the road with no cert too. I get why it needs a cert too as even if using factory bits, any numpity can do it and do it badly. My latest car was manual swapped before I got it. Nice and easy to add it to the cert list.
Certainly something everyone will have a different take on. I have zero interest in further modifying my car so the cert restricting modifications isn't a problem for me. For people that like to change things up a lot then it's not so ideal.
Whats the minimum distance between P-clips/mounts for fuel lines+hoses?
Nephew is building his first car and converted a carb car to efi, and mounted external pump behind the tank, It has rubber lines going over the top of the tank ~500mm each, so thinking these will need clips added to make sure they can't move. (while still moving enough to drop and raise tank, haha)
