si
On 2/3/2018 at 16:12, 63Ragtop said:
Numbers don't match,  questions asked.  Dun dun dun.
Stupid though,  can't be many 55 year old cars with og engines anymore.
I have no idea if VW blocks have numbers stamped on them, but could it be a case of remove engine numbers then = factory motor?
  • Replies 9k
6 hours ago, Nominal said:
Can't you get the engine number changed on the rego system?
Possibly,  but wouldn't that defeat the purpose of the cert system?
I did try to get the chassis number changed,  no dice! Lol.
Would have to be same for same in that case I would imagine.
except that engines are far more often changed than a chassis.
that said, i have been trying to get the colour of my car updated for about 6 years
45 minutes ago, cletus said:
Yep. Much better than the screw in stud option for mazdas IMO
And thoughts on the screw in stud option for BMW to replace the wheel bolts?
Would it be ok to put one stud in each wheel to locate the wheel and then factory bolts for the rest?
I'm sure most have seen this thing now it's great but so bloody illegal it's not funny.
If I were to pull off the V-twin and fit a 50cc engine and treaded tyres could it be street registered ? It's a sweet ride now brakes work mint and it's quite Chuckable as far as handling goes.
So im looking at purchasing a late model (2004) Toyota that the reg has lapsed on so il be looking to get it re registered.
What sorta stuff do they check over when doing a re reg inspection?
I will give the car a good going over when I view it next weekend but are there thing I should be paying particular attention too that Mr Inspector guy will be checking
I guess they apply the entry certification process?
https://vehicleinspection.nzta.govt.nz/virms/entry-certification
e.g. for brakes etc
Compliance with approved standards
4. A brake that is required to comply with an approved brake standard did not comply, or cannot be demonstrated to have complied, with at least one of the standards listed in Table 8-1-1 at the time the vehicle was manufactured.
5. A brake has brake friction material that is:
a) not identifiable by markings of the vehicle manufacturer or a recognised brake friction material manufacturer listed in Figure 8-2-1, or
B) not supplied by a recognised supplier and accompanied by a statement of compliance from that supplier.
Condition, performance and modification
6. Brake fluid in the master cylinder reservoir, or at remote locations, shows signs of dirt or contamination.
7. Brake friction material is:
a) worn below the limits shown in Table 8-2-1, or
B) separating from the brake pad backing plate or brake shoe, or
c) cracked or otherwise damaged, or
d) contaminated by brake fluid, oil or grease.
