M.H. Posted November 27, 2017 Share Posted November 27, 2017 9 minutes ago, cletus said: In your case 50% hp or torque increase would be the tipping point for needing a loop. I would say 2.5 to 3.9 td might be a hard sell that it is actually less than a 50% increase, especially if you have things like a larger exhaust etc Does it make any difference that the same running gear is used in later more powerful versions? The 4.6 v8 had 222hp and 400nm Quote Link to comment Share on other sites More sharing options...
cletus Posted November 27, 2017 Share Posted November 27, 2017 If you can legitimately prove that the shaft is the same between the higher hp one, then that may be enough to not have to fit a loop 2 Quote Link to comment Share on other sites More sharing options...
chasinthemirage Posted November 28, 2017 Share Posted November 28, 2017 Middy's car has failed a wof, one of the last things left to do is the wipers and washers. I've fixed the front but the pump for the rear reservoir has been sitting in water and is shagged. I don't really want to spend $93 on a new pump, can I just remove the rear wiper arm and washer nozzle? Quote Link to comment Share on other sites More sharing options...
AllTorque Posted November 28, 2017 Share Posted November 28, 2017 Rear wiper and washer doesn’t need the work for a wof. No need to remove them. 1 1 Quote Link to comment Share on other sites More sharing options...
kws Posted November 29, 2017 Share Posted November 29, 2017 Lol I wasn’t aware they didn’t need to work so I spent considerable effort making them work on the sd1 only for it not to be checked at wof time. Ah well. 1 Quote Link to comment Share on other sites More sharing options...
Furai Posted December 3, 2017 Share Posted December 3, 2017 Any forseable issues before I get a pro round to weld them in? Quote Link to comment Share on other sites More sharing options...
cletus Posted December 3, 2017 Share Posted December 3, 2017 looks ok from here 1 Quote Link to comment Share on other sites More sharing options...
kws Posted December 4, 2017 Share Posted December 4, 2017 I forget, on a car with reg on hold and no wof do I need to renew rego before wof, or wof before rego? Does it matter? also, taking off hold, do I just buy rego like normal? Quote Link to comment Share on other sites More sharing options...
Beaver Posted December 4, 2017 Share Posted December 4, 2017 6 minutes ago, kws said: I forget, on a car with reg on hold and no wof do I need to renew rego before wof, or wof before rego? Does it matter? also, taking off hold, do I just buy rego like normal? Wof before rego (cant get rego without wof) And yes, you just go buy rego like normal when you want to bring it off hold. 1 1 Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted December 5, 2017 Share Posted December 5, 2017 just getting back to the diff caliper mounts (on a to be certified car )....can they be made out of 10mm alloy? or is it best to use steel. thanks again for any and all help Quote Link to comment Share on other sites More sharing options...
Carsnz123 Posted December 10, 2017 Share Posted December 10, 2017 Whats the interpretation of the High stop light rules? to quote NZTA's VIRM "A class MA vehicle first registered or manufactured on or after 1 January 1990 must be fitted with one or two high-mounted stop lamps." I take that as pre 1990 vehicles don't need one. And welding new spring perches on a diff. Cert or nocert? Quote Link to comment Share on other sites More sharing options...
AllTorque Posted December 10, 2017 Share Posted December 10, 2017 No high stop needed for pre 1990. This rule has changed recently, so there may be some inspectors that need educating. 1 Quote Link to comment Share on other sites More sharing options...
Nominal Posted December 10, 2017 Share Posted December 10, 2017 8 hours ago, Carsnz123 said: And welding new spring perches on a diff. Cert or nocert? Are you swapping the diff to a different one? Quote Link to comment Share on other sites More sharing options...
Carsnz123 Posted December 10, 2017 Share Posted December 10, 2017 14 minutes ago, Nominal said: Are you swapping the diff to a different one? Yeah. Was planning on putting a Toyota F series diff in my cedric because they're dime a dozen and easier to get taller ratios. Quote Link to comment Share on other sites More sharing options...
Nominal Posted December 10, 2017 Share Posted December 10, 2017 17 minutes ago, Carsnz123 said: Yeah. Was planning on putting a Toyota F series diff in my cedric because they're dime a dozen and easier to get taller ratios. Yeah, that would need a cert for sure. Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted December 10, 2017 Share Posted December 10, 2017 Yip. With out a doubt. Custom drive shaft also means drive shaft loops. Quote Link to comment Share on other sites More sharing options...
Carsnz123 Posted December 11, 2017 Share Posted December 11, 2017 Forgot about the driveshaft. Yeah that will throw a spanner in the works. Need to find some tall h190 diffs. Quote Link to comment Share on other sites More sharing options...
brocky41 Posted December 11, 2017 Share Posted December 11, 2017 @Carsnz123 What ratio do you need, or do you just need 5 speeds? Quote Link to comment Share on other sites More sharing options...
Carsnz123 Posted December 11, 2017 Share Posted December 11, 2017 I kinda want to keep the 3 speed column box so taller the better. Standard 260c is 4.1. 5 speed box will make it go better but doesn't have that cool column factor. 1 Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted December 11, 2017 Share Posted December 11, 2017 You need to talk to the Barry known as @fletch He is a nissan gearbox magician. Is running a 5 speed column shift converted from Nissan and datsun lego in his datsun 240c wagon. 3 Quote Link to comment Share on other sites More sharing options...
