si
  • Replies 9k
On ‎27‎/‎10‎/‎2017 at 20:57, nickrock said:
That a bigger cause I got a 304 and trans sitting under the bench
It comes with a fully rebuilt auto that works like a AMT would a injected Chevy be ok with out a re cert
On ‎27‎/‎10‎/‎2017 at 21:00, cletus said:
Basically if anything doesn't match whats on the cert plate, it will need re certification.
having to recert isn't the end of the world. I think people are more scared of it than they should be. but maybe selling your 304 and buying a chev would not be all that different cost wise and less work to do.
if you want to tweak things more later I would definitely be considering chev, more stuff available etc.
but maybe you prefer the sound of the holden motor, or just would like to have a holden with a holden motor?
basically you just have to decide what you want, neither is right or wrong.
4 hours ago, Testament said:
3 hours ago, Firetruck said:
If the car's already been certified with a big engine, and as long as your engine mounts and g-box cross member aren't garbage it should fly through cert with no issues.
It w's more a case of I got the bits , I really don't need another project just a bolt in and go plus no where to park it but outside and its super tidy
Would I need to supply drawings if I was going to weld brackets like this for the engine mounts?
It has no effect on any suspension geometry but just wondering if it would need anything more than to be well constructed for cert
Nah no drawings needed
Just make them strong enough and you'll be fine
Depending on the thickness and position of the mount tabs you may need to weld them to a flat plate then to the x member
Ie
|____|   instead of   |        |
3 minutes ago, Archetype said:
How is braking ability evaluated for a cert when a vehicle with terrible factory brakes receives an engine transplant with a significant increase in power (percentage wise)?
Up to 50% increase over oe output- 3x 100- 0kph stops under 4.4 seconds each in a total of 2 minutes
Over 50% - 5x 100-0kph stops under 4.4 seconds each in a total of 3 minutes
Beauty, that makes it pretty easy then, as I can leave the brake upgrade to last and see how bad the stock brakes are before I start upgrading them. I’m taking about a factory 31hp to 100ish hp upgrade, so the 2nd option you mentioned will apply to me.
I doubt I could even get the thing to 100km/h 5x in less than 3 minutes at the moment. :)
hi all.
this may have been asked before and im sorry if its been asked 100s of times.
but is it legal to have a hydraulic handbrake .?
and i dont mean a sweet as fuck drifter drifter jobby i mean for instance an escort with a factory handbrake in the factory position with the factory CLICK CLICK CLICK CLICK
but instead of hand brake cables a master cylinder and hoses ..
cheers
20 hours ago, cletus said:
You can but you have to have a motorsport authority card
Ie it has to be a proper competition vehicle. Not really practical if it isnt one
cletus.....whats the go with welding a bracket to the diff housing to bolt the caliper to.
21 hours ago, d.p.n.s said:
hi all.
Be prepared to chock and leave your car in gear. I saw a hydro handbrake race car take off at an event a couple of months ago.  Luckily next to a bunch of people that were keen enough to try and stop it.
i wont be doing it mate...its just for a road car.
