ok im not thinking of doing this but i saw it today and thought quite loudly in my head 'WTF!'
hilman avenger with cutties up front, shocks not captive so there was a long bolt welded to the top spring cap running through the bottom cap/plate/base/whateverwhocares and bolted captive,so when the shock compresses the bolt slides though the lower cap and the nut stops it from rasing past its captive point.
seems a bit iffy squiffy to me
Thats fantastic.
Back in the day we used seatbelt webbing from one end of the shock to the other to limit shock expansion and keep spring captive.
  • Replies 9.9k
To keep the rear seats in my coupe I'm not able to run fixed back buckets right? If I used a standard flip forward passenger seat and a fixed back for drivers would it be sweet?
I think its pre 1980 that doesn't need them, but as tortron said if there there they have to work, so get rid of any trace of them.
nah pretty sure it has to be both sides. could tak to a cert man about setting up a flip forward fixedback setup sorta like minis have
Not sure how hard that would be, pretty sure seats with 2 mounting points are illegal, yet mini's have them standard. I think maybe beetles do too. But either way i don't think flip forward would work very well with a fixed bucket seat because they are tall? Hit the roof etc.
im sure you could setup a sweet parallelogram linkage thing so it effectivly pivots from further back on the seat. but yea youd want to talk to a cert guy about it first.
Na beetles don't.
I have seen a couple of hatches certed with non flip fixed back seats, so it might pay to talk to your certifier, I think it might have somthing to do with how far you can slide the seat forwards on the rails.
regarding shaved rear doorhandles on my 78 lancer, do they thve to be certed if i have no back seats or seatbelts? does it even need seatbelts in the rear since its 78?
pretty sure the wof guy told me you dont need seat belts if you dont have seats, and dont need internal door handles either since nobody needs to get out so i would assume the outside would be the same
Unless, you buy another set of the same and switch them. There is a company that make plates, so you could maybe get a set and keep your original ones in the boot. I got pulled up for having my black plate up front, cop said to change it back and I was off. Still forgotten to tho...
what about with making new white number plates black like the older ones?
i've been pulled over for black plates (mines a 3-letter plate, pretty obvious..) the cop told me off/said theyre illegal but didnt mention any rule in particular.
