Raizer Posted September 4, 2021 Share Posted September 4, 2021 4 hours ago, cletus said: This is a common problem with 1uz into hiaces, the throttle body hits the lid right under the drivers seat/ buckle anchorage. The best way to sort those out is move the throttle body to the other side. Or start with a Super Custom/possibly just use Super Custom engine covers Quote Link to comment Share on other sites More sharing options...
cletus Posted September 4, 2021 Share Posted September 4, 2021 Yeah was going to say that but I couldn't remember if the SC covers fit on a normal hiace, from memory the rear firewall has a bump in it that others dont as well? Theres a few advantages using a SC to start with I think 1 Quote Link to comment Share on other sites More sharing options...
Raizer Posted September 4, 2021 Share Posted September 4, 2021 17 minutes ago, cletus said: Yeah was going to say that but I couldn't remember if the SC covers fit on a normal hiace, from memory the rear firewall has a bump in it that others dont as well? Theres a few advantages using a SC to start with I think Yeah good point about the bell housing cover, unsure if it'll bolt into a a tradie Hiace without trimming the floor back a bit. Super Custom (1KZ at least) has the same engine bay and covers as the factory 1UZ ambulance. 1 1 Quote Link to comment Share on other sites More sharing options...
Jeffs_Emporium Posted September 4, 2021 Share Posted September 4, 2021 I did look into whether the engine covers differ for the different engine (y series stands straight up as opposed to the slanted 5k) but part numbers are the same for both chassis. Part number does differ for floor shift vs column however so could look into that to see if it bulges higher or not. Quote Link to comment Share on other sites More sharing options...
Abarth Posted September 5, 2021 Share Posted September 5, 2021 Is it true you can’t have a vented oil catch can? Has to be plumbed back in now? Quote Link to comment Share on other sites More sharing options...
cletus Posted September 6, 2021 Share Posted September 6, 2021 Depends If the car has had an engine swap= have to apply emissions standard https://lvvta.org.nz/documents/standards/LVVTA_STD_Exhaust_Gas_Emissions.pdf Emissions standard requires operational PCV system in a lot of cases If the car has a modified original engine= emissions standard not required to be checked Quote Link to comment Share on other sites More sharing options...
Abarth Posted September 6, 2021 Share Posted September 6, 2021 7 hours ago, cletus said: Depends If the car has had an engine swap= have to apply emissions standard https://lvvta.org.nz/documents/standards/LVVTA_STD_Exhaust_Gas_Emissions.pdf Emissions standard requires operational PCV system in a lot of cases If the car has a modified original engine= emissions standard not required to be checked Sweet cheers mate Quote Link to comment Share on other sites More sharing options...
Banga Posted September 6, 2021 Share Posted September 6, 2021 7 hours ago, cletus said: Depends If the car has had an engine swap= have to apply emissions standard https://lvvta.org.nz/documents/standards/LVVTA_STD_Exhaust_Gas_Emissions.pdf Emissions standard requires operational PCV system in a lot of cases If the car has a modified original engine= emissions standard not required to be checked Any tips for an operational PCV system when running ITBs? Can I run the recirculated gases into each trumpet (somehow) or do I have to drill the manifolds? Quote Link to comment Share on other sites More sharing options...
cletus Posted September 6, 2021 Share Posted September 6, 2021 Yeah that's a real prick to do One company that does a lot of cars with ITBs fits a pipercross filter, and puts a fitting on the back side of the filter assembly to vent into Otherwise I guess you would need to make a little manifold from all 4 intake runners into a pcv valve 1 Quote Link to comment Share on other sites More sharing options...
SOHC Posted September 6, 2021 Share Posted September 6, 2021 1 hour ago, Banga said: Any tips for an operational PCV system when running ITBs? Can I run the recirculated gases into each trumpet (somehow) or do I have to drill the manifolds? Some people use a vacuum pump Quote Link to comment Share on other sites More sharing options...
Banga Posted September 6, 2021 Share Posted September 6, 2021 9 hours ago, SOHC said: Some people use a vacuum pump Getting vacuum isn’t an issue, just how to get crankcase gases back into the engine after the air/oil separator? Quote Link to comment Share on other sites More sharing options...
SOHC Posted September 6, 2021 Share Posted September 6, 2021 9 minutes ago, Banga said: Getting vacuum isn’t an issue, just how to get crankcase gases back into the engine after the air/oil separator? With a pump you dont have to, just blow them into the air Quote Link to comment Share on other sites More sharing options...
Banga Posted September 6, 2021 Share Posted September 6, 2021 12 minutes ago, SOHC said: With a pump you dont have to, just blow them into the air Pretty sure it has to be recirculated into the engine to get a cert? Quote Link to comment Share on other sites More sharing options...
SOHC Posted September 6, 2021 Share Posted September 6, 2021 Pipe it into the ait filter Quote Link to comment Share on other sites More sharing options...
scooters Posted September 7, 2021 Share Posted September 7, 2021 Body lift = cert Diff drop kits are these a cert item? pushes the front diff down 1" after lifting a vehicle to correct C.V drive angles. IFS vehicles surf, 90 prado etc... Quote Link to comment Share on other sites More sharing options...
cletus Posted September 7, 2021 Share Posted September 7, 2021 Yes diff drop would need cert 1 Quote Link to comment Share on other sites More sharing options...
Banga Posted September 7, 2021 Share Posted September 7, 2021 19 hours ago, cletus said: Yeah that's a real prick to do One company that does a lot of cars with ITBs fits a pipercross filter, and puts a fitting on the back side of the filter assembly to vent into Otherwise I guess you would need to make a little manifold from all 4 intake runners into a pcv valve So venting into the enclosed filer assembly is good enough? I don’t necessarily have to tap into the manifold/runners? Quote Link to comment Share on other sites More sharing options...
cletus Posted September 7, 2021 Share Posted September 7, 2021 I think if its enclosed, that's good enough. I've passed quite a few cars with that setup 1 Quote Link to comment Share on other sites More sharing options...
Mark_Fleming Posted September 7, 2021 Share Posted September 7, 2021 Banga/Cletus can you confirm/expand the comment re circulating PCV gasses back in to the engine for a cert? Quote Link to comment Share on other sites More sharing options...
Banga Posted September 7, 2021 Share Posted September 7, 2021 5 minutes ago, Mark_Fleming said: Banga/Cletus can you confirm/expand the comment re circulating PCV gasses back in to the engine for a cert? The link Cletus posted on the previous page covers it pretty much - https://lvvta.org.nz/documents/standards/LVVTA_STD_Exhaust_Gas_Emissions.pdf 2.3(1) is the section to look into. Quote Link to comment Share on other sites More sharing options...
