kyteler Posted August 9, 2021 Share Posted August 9, 2021 Seems to be another case of grey areas. The documentation allows for interpretation in both directions and as such, certifiers will do exactly that, typically erring on the side of caution/least chance of them being held responsible. That's not a fault of the certifiers, they're just trying to protect their livelihood. Equally, these grey areas allow for the slop of components between a magnitude of vehicles thus giving us more ability to modify for an OK cost. The step above would be if we had to be like Germany and have TUV cert on every component otherwise you can't use it, then modifications and cars as a hobby would stretch beyond the budget of your average punter. It's a fine line of nonsense tightrope that we and the legislators walk. Also, why is that person not using Clint? They probably have a stack of other terrible mods and the suspension arms one just got added to the list. 2 2 Quote Link to comment Share on other sites More sharing options...
cletus Posted August 9, 2021 Share Posted August 9, 2021 26 minutes ago, Nominal said: This might be the thing Clint was referring to? https://www.lvvta.org.nz/documents/safety_alerts/LVVTA_Safety_Alert_04-2020_Sub-standard_Suspension_Arms.pdf That is different to the info I was thinking of, but that is more relevant as it mentions having serrations to locate the joint , when there is a single nut holding the joint in place so the certifier may be reading it wrong or as KY said, ass covering I've certed a few of that style arms from various manufacturers, if they fail it's usually for other reasons, like Car is low, has too much camber Camber arms fitted to correct camber Camber arm is longer to allow top ball joint to come out further Body does not allow space for full travel of the ball joint when its further out Ball joint hits body Have to raise suspension to remedy fouling Dont need camber arms now because camber isn't a problem any more =A circle of money spending and fucking around is complete 3 1 Quote Link to comment Share on other sites More sharing options...
chris r Posted August 9, 2021 Share Posted August 9, 2021 I'll be using Clint if I ever get finished enough to need his services <3. Customer is based in palmy so it's a bit of a drive for them to come up here Quote Link to comment Share on other sites More sharing options...
slopez Posted August 11, 2021 Share Posted August 11, 2021 Hi guys, question about body mods, I know a chap who has modified a wagon by fitting the tray, b-pillar and roof off of a ute (thereby making his wagon a ute). Its an old valiant so it came out with both wagons and ute on the same platform, I can't see anything about this sort of thing in the hobby car manual, is it possible to do this and then cert it? ie. hes done most of the work but its never seen a certifier, will it all need redoing if it were to be certed? Cheers Quote Link to comment Share on other sites More sharing options...
Nominal Posted August 11, 2021 Share Posted August 11, 2021 Is it reg on hold? 1 Quote Link to comment Share on other sites More sharing options...
slopez Posted August 11, 2021 Share Posted August 11, 2021 Nope, I bet is probably not even in the system anymore, its been in his shed for 25 yrs probably. Quote Link to comment Share on other sites More sharing options...
tortron Posted August 13, 2021 Share Posted August 13, 2021 How many replacement plates do you think I can get in 1 go without arousing suspicion. Got 3 vehicles that have lost them (legitimately, well one was on a stolen bike and didn't come back, but that was years ago and I don't know the police report) Quote Link to comment Share on other sites More sharing options...
GuyWithAviators Posted August 13, 2021 Share Posted August 13, 2021 10 minutes ago, tortron said: How many replacement plates do you think I can get in 1 go without arousing suspicion. Got 3 vehicles that have lost them (legitimately, well one was on a stolen bike and didn't come back, but that was years ago and I don't know the police report) I’m also interested in this. I have 2 bikes (one unregistered but will be Mr2b form) that I want consecutive plates on. They’re both exactly the same model / colour. Quote Link to comment Share on other sites More sharing options...
tortron Posted August 13, 2021 Share Posted August 13, 2021 Oh that's easy, expecially if it's a slow day (as they don't always grab from top of the pile) I just got 1 plate, might leave the others till next time lol Quote Link to comment Share on other sites More sharing options...
gibbon Posted August 13, 2021 Share Posted August 13, 2021 My dataplate is missing, how can I go about getting another one? Car has no VIN number, chassis code is visible on the firewall, car has live plates and is on hold, the dataplate was removed for rust repair on firewall by PO and subsequently lost Quote Link to comment Share on other sites More sharing options...
tortron Posted August 13, 2021 Share Posted August 13, 2021 Data plate as in the factory one with deets about trim, box, engine? Blank one from Ebay and fill it out Quote Link to comment Share on other sites More sharing options...
gibbon Posted August 13, 2021 Share Posted August 13, 2021 Just has chassis number and vehicle weights on it... I can just make out a manufacturers part number on the bottom. So buy blank, fill it out, gotcha ....best way to fill them out nicely? It looks to be very lightly etched, not stamped Quote Link to comment Share on other sites More sharing options...
tortron Posted August 13, 2021 Share Posted August 13, 2021 Laser etch/engrave would be good Quote Link to comment Share on other sites More sharing options...
cletus Posted August 14, 2021 Share Posted August 14, 2021 On 11/08/2021 at 14:42, slopez said: Hi guys, question about body mods, I know a chap who has modified a wagon by fitting the tray, b-pillar and roof off of a ute (thereby making his wagon a ute). Its an old valiant so it came out with both wagons and ute on the same platform, I can't see anything about this sort of thing in the hobby car manual, is it possible to do this and then cert it? ie. hes done most of the work but its never seen a certifier, will it all need redoing if it were to be certed? Cheers Its do able, whether it needs redoing or not will depend on how well it was done in the first place, will need a certifier to have a look at it to see if it needs any further strengthening 1 Quote Link to comment Share on other sites More sharing options...
tortron Posted August 14, 2021 Share Posted August 14, 2021 does this imply that someone bought a scooter new in nz, then exported it, then brought it back? RTW on a 50cc? Quote Link to comment Share on other sites More sharing options...
87creepin Posted August 14, 2021 Share Posted August 14, 2021 What's the rules surrounding repair certs when rust is involved? Does it have to be from a panel shop, or could it be from someone who has qualifications/tickets? I've only ever had to get one before, the panelbeaters simply wrote that the repair had been properly done with welded in steel plate etc. Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted August 15, 2021 Share Posted August 15, 2021 If it's for a revin, then it needs to be signed off by an approved repair certifyer. Kiss $500 good bye. (At least) 1 Quote Link to comment Share on other sites More sharing options...
Nominal Posted August 15, 2021 Share Posted August 15, 2021 On 14/08/2021 at 19:51, 87creepin said: What's the rules surrounding repair certs when rust is involved? Does it have to be from a panel shop, or could it be from someone who has qualifications/tickets? I've only ever had to get one before, the panelbeaters simply wrote that the repair had been properly done with welded in steel plate etc. For a WOF, or for revin as per Runamuck? Quote Link to comment Share on other sites More sharing options...
87creepin Posted August 16, 2021 Share Posted August 16, 2021 @Nominal just warrants, cars already registered here. Quote Link to comment Share on other sites More sharing options...
Nominal Posted August 16, 2021 Share Posted August 16, 2021 8 minutes ago, 87creepin said: @Nominal just warrants, cars already registered here. Shouldn't need an official repair certification then as I understand things, just what ever your wof place is satisfied with. If not, they have this option https://vehicleinspection.nzta.govt.nz/virms/in-service-wof-and-cof/general/vehicle-structure/structure-incl2.-frontal-impact#note3 Quote Link to comment Share on other sites More sharing options...
