Mof Posted December 14, 2020 Share Posted December 14, 2020 He might be able to change the load cert, I believe once you lower it you can never go back. More likely change the vehicle to Motorhome, still cof but cheaper? Quote Link to comment Share on other sites More sharing options...
Ranter Posted December 14, 2020 Share Posted December 14, 2020 On 13/12/2020 at 20:20, gibbon said: This doesn't really belong here but not worth starting a new thread over: I was wondering what the weights listed on the dataplate relate to? (Mine is 400113 and for years I thought it weighed as much as a Falcon at 1665kg lol) 1665kg is Gross weight (kerb weight is 1230/1325kg) I'm guessing the 2865 is combined towing or load or max weight?? The others - don't know guessing axle loads 2 Quote Link to comment Share on other sites More sharing options...
igor Posted December 14, 2020 Share Posted December 14, 2020 25 minutes ago, Ranter said: The others - don't know guessing axle loads This would make sense, 1 being front and 2 being rear. Quote Link to comment Share on other sites More sharing options...
_Matt Posted December 19, 2020 Share Posted December 19, 2020 I’m mostly finished prepping the engine bay in my starlet for paint and the stamped chassis number on the firewall has pretty much disappeared from all the coats of primer, is that going to be an issue or should I strip that area right back and just put some lighter coats on it? Cheers Quote Link to comment Share on other sites More sharing options...
tortron Posted December 19, 2020 Share Posted December 19, 2020 Rub you dirty finger over it so the imprint goes darker ? 1 Quote Link to comment Share on other sites More sharing options...
_Matt Posted December 20, 2020 Share Posted December 20, 2020 16 hours ago, tortron said: Rub you dirty finger over it so the imprint goes darker ? There’s a 3 and a few dots haha Quote Link to comment Share on other sites More sharing options...
AllTorque Posted December 20, 2020 Share Posted December 20, 2020 Do you have a VIN plate as well or just the chassis number? Here are the WOF rules https://vehicleinspection.nzta.govt.nz/virms/in-service-wof-and-cof/general/vehicle-identification/vin-and-chassis-number 1 Quote Link to comment Share on other sites More sharing options...
tortron Posted December 20, 2020 Share Posted December 20, 2020 5 minutes ago, _Matt said: There’s a 3 and a few dots haha Lol Says in the rules the inspector can remove that paint with chemicals if you agree, otherwise "have to find another way" Quote Link to comment Share on other sites More sharing options...
_Matt Posted December 20, 2020 Share Posted December 20, 2020 17 minutes ago, AllTorque said: Do you have a VIN plate as well or just the chassis number? Here are the WOF rules https://vehicleinspection.nzta.govt.nz/virms/in-service-wof-and-cof/general/vehicle-identification/vin-and-chassis-number Yeah has the original vin plate with all the info; model, engine, frame number, colour etc. The frame number is what’s stamped on the firewall and barely visible. Might just wire wheel it back and light coat it to save any issues 1 Quote Link to comment Share on other sites More sharing options...
GuyWithAviators Posted December 20, 2020 Share Posted December 20, 2020 39 minutes ago, _Matt said: Yeah has the original vin plate with all the info; model, engine, frame number, colour etc. The frame number is what’s stamped on the firewall and barely visible. Might just wire wheel it back and light coat it to save any issues If it helps when I (rattle can) painted a bike frame recently I painted one coat, waited for it to dry, put a strip of masking tape over the stamped number and then continued painting. At end took off tape and it was right colour and easy to read. 2 Quote Link to comment Share on other sites More sharing options...
Bling Posted December 20, 2020 Share Posted December 20, 2020 Pretty quick job to stop it screaming dodgy. I also did the above on my car, as they aren't the deepest from factory. Quote Link to comment Share on other sites More sharing options...
bmxnz11 Posted January 5, 2021 Share Posted January 5, 2021 On 14/10/2016 at 20:38, cletus said: anything other than bolting it in as per this http://lvvta.org.nz/documents/suplementary_information/LVVTA_LVV_Cert_Threshold.pdf needs cert, and then you would have to comply with this http://lvvta.org.nz/documents/standards/LVVTA_STD_Seats_&_Seat_Anchorages.pdf If you adapt the seat to bolt to the original anchorages in the floor, the cert requirements are fairly easy If you drill holes etc in the body, you will need to make new anchorages, which depending on your skill level, can be quite challenging. I'm putting mx5 seats in my escort and my question is, certwise, is it easier/cleaner to modify the original escort seat rails to suit the mx5 seats or the mx5 seat rails? I will be keeping the original mounting positions and holes, and wont be changing the original floor mounted belts. Quote Link to comment Share on other sites More sharing options...
cletus Posted January 5, 2021 Share Posted January 5, 2021 As far as cert goes , if you can mount to the original anchorages in the floor that makes things easier. As far as which ones to use, I'd use the mazda runners if you can because they will be nicer than escort ones 1 Quote Link to comment Share on other sites More sharing options...
bmxnz11 Posted January 6, 2021 Share Posted January 6, 2021 Last one from me. I'm fitting a rear seat in my escort van (original estate seat) which flips down when not in use. I need to make two supporting towers which hold the back rest in place when the seat is set up to be used, so it doesn't swing back or forth. There are two bars welded on the back of the seat above the wheel tub to work with. Do I need a locking latch on each tower? Or can I have a locking latch on one, and a plastic block to rest on, on the other? Quote Link to comment Share on other sites More sharing options...
cletus Posted January 10, 2021 Share Posted January 10, 2021 I would say fit a latch on both sides. What did the wagon version have from factory? Quote Link to comment Share on other sites More sharing options...
CUL8R Posted January 11, 2021 Share Posted January 11, 2021 @ Clint, getting closer to some yearly progress on the car - in preparation for Cert/finishing it off. Have driveshaft loop doubler plate inside, but would like to put the carpet in and do some other interior jobs, is photo's sufficient of the mounts - without/without a rule beside them. Or am I best to leave the carpet out? Quote Link to comment Share on other sites More sharing options...
cletus Posted January 11, 2021 Share Posted January 11, 2021 You might want to talk to your certifier, but I would accept a photo with a ruler next to it, might help if you take a pic of the plates before you fit them to show the rounded edges as well 1 Quote Link to comment Share on other sites More sharing options...
Muncie Posted January 11, 2021 Share Posted January 11, 2021 How complicated is fitting airbag seats in a different car when doing the cert? Liking the idea of some Audi seats up front in my vy commodore so i can have heat for my bad back in winter. Providing i can get the equipment talking correctly and not fire myself through the windscreen has been considered. 1 Quote Link to comment Share on other sites More sharing options...
cletus Posted January 11, 2021 Share Posted January 11, 2021 Dunno, only ones I've been involved with have been removal due to putting aftermarket seats in, or fitting late model seats in old cars where you leave it disconnected Might be easier to fit the heat pads into your seat? Quote Link to comment Share on other sites More sharing options...
Early jap nuter Posted January 11, 2021 Share Posted January 11, 2021 You can take the bags out of the seats and repack where it is with foam. They just bolt in. Commodore seats tend to shit themselves when you pull the apart to fix as the backing falls of the fabric Quote Link to comment Share on other sites More sharing options...
