cletus Posted October 15, 2020 Share Posted October 15, 2020 On 14/10/2020 at 09:31, sheepers said: hey whats the go with brake calipers without dust boots. is this verboten? 7 hours ago, NickJ said: Possible to clarify piston or slide? Could be very pertinent to us as piston boots are NLA for a vehicle we're about to re-reg It's never been an issue before, willwood and many other aftermarket calipers dont have dust boots on the pistons However if the caliper is an oem one and was designed to have dust boots or slide boots then it is likely it would fail, I've never had that come up before 1 Quote Link to comment Share on other sites More sharing options...
sheepers Posted October 15, 2020 Share Posted October 15, 2020 cool cool. cheers for that. 1 Quote Link to comment Share on other sites More sharing options...
MRWEST Posted October 16, 2020 Share Posted October 16, 2020 Hey @cletus Are the storys regarding re drilling of brake rotors for stud pattern change no longer being legal correct? Car in question will need both a vin and LVVTA cert Eg 4 Pot S4/5 RX7 Calipers and rotors redrilled for 4x110 or 4x114.3 PCD. Just want to confirm before i get rid of my brake setup iv got an go find something else too use... Cheers Quote Link to comment Share on other sites More sharing options...
cletus Posted October 16, 2020 Share Posted October 16, 2020 Sometimes legal, sometimes not. 3 Quote Link to comment Share on other sites More sharing options...
MRWEST Posted October 19, 2020 Share Posted October 19, 2020 Thanks @cletus Now to decide if i want to go 4 or 5 stud then.... Cheers Quote Link to comment Share on other sites More sharing options...
Evan Posted October 19, 2020 Share Posted October 19, 2020 FYI @MRWEST Povo spec US model FCs had 4 stud brakes - not sure what diameter the rotors were vs 5 stud but rockauto might be your friend here... Quote Link to comment Share on other sites More sharing options...
MRWEST Posted October 19, 2020 Share Posted October 19, 2020 3 hours ago, Evan said: FYI @MRWEST Povo spec US model FCs had 4 stud brakes - not sure what diameter the rotors were vs 5 stud but rockauto might be your friend here... huh thats good too know! will do some looking Quote Link to comment Share on other sites More sharing options...
kyteler Posted October 19, 2020 Share Posted October 19, 2020 Quick Cert query. I saw something pop up recently that they're changing to RFID discs? @cletus @KKtrips Quote Link to comment Share on other sites More sharing options...
Beaver Posted October 19, 2020 Share Posted October 19, 2020 On 06/08/2020 at 12:02, cletus said: Last training session we had, there was a plan to get rid of plates and replace them with a small plastic disc with a chip in it, that you could scan and it would take you to a website or app or something with photos of the vehicle as certified, and much greater detail on vehicle mods than can be fitted on the plate @kyteler do you even read this thread brah? Page 357 and 358 has some yarns from Clint and KK. xoxo 1 Quote Link to comment Share on other sites More sharing options...
kyteler Posted October 19, 2020 Share Posted October 19, 2020 1 minute ago, Beaver said: @kyteler do you even read this thread brah? Page 357 and 358 has some yarns from Clint and KK. xoxo Ah yep. Cheers Beav. That's pretty neat. I assume police will be able to scan too then. Circumventing people's changes post cert. I imagine if it plays out well enough it'll transition to warrant checks too. Quote Link to comment Share on other sites More sharing options...
Bling Posted October 19, 2020 Share Posted October 19, 2020 Here you go: https://www.lvvta.org.nz/documents/newsletters_pub/LVVTA_Newsletter_2020_January-July.pdf Got that via their mailing list, interesting read about the RFID stuff. 2 Quote Link to comment Share on other sites More sharing options...
tortron Posted October 19, 2020 Share Posted October 19, 2020 do you think an engine with zero radio suppression will fuck it? i can measure 12v on a multimeter without touching anything under minors bonnet 1 4 Quote Link to comment Share on other sites More sharing options...
kyteler Posted October 19, 2020 Share Posted October 19, 2020 Good wee read. Makes a lot of sense but I'm sure there'll be complaints about change. Certifiers will also have to ensure their photographs are entirely representative of the vehicle and all its modified states so no doubt whilst there is some time to be saved vs. the engraved plates I'm sure it'll be gobbled up by the other tasks. Quote Link to comment Share on other sites More sharing options...
Bling Posted October 19, 2020 Share Posted October 19, 2020 No perfect solution I guess. But nine times out of ten i'd say the changes people have made post cert will be obvious. Chopped out another 50mm, wheels now @ -5 degrees. Gotta be better than hoping for the best. If WOF man has a concern about a modification they can check photos pretty easily. I don't recall the last car I saw with a cert that was still passable. RFID is in all sorts and doesn't seem to care about 240v running and the likes. So probably no issue? 1 Quote Link to comment Share on other sites More sharing options...
cletus Posted October 19, 2020 Share Posted October 19, 2020 The best thing is we can fit it at time of inspection and dont have to wait for the plate to come back then get the vehicle back again to fit the plate. For some reason people are happy to bring a car for inspection but get a lot of people complaining about having to come back for the plate to be fitted, it always seems to be a hassle to organize a time, tell people I'm at the shop from 8 till 5pm and 3 of them will turn up at 4.57PM , etc 7 Quote Link to comment Share on other sites More sharing options...
KKtrips Posted October 19, 2020 Share Posted October 19, 2020 1 hour ago, kyteler said: Quick Cert query. I saw something pop up recently that they're changing to RFID discs? @cletus @KKtrips Yep, should make it easier for certifiers because they won't need to get the vehicle back to fit the plate. The tag will be fitted at the time of inspection and livened up once the cert has been processed as OK. 2 Quote Link to comment Share on other sites More sharing options...
KKtrips Posted October 19, 2020 Share Posted October 19, 2020 /what Clint said. Also it should stop the guys who borrow a set of wheels/insert name of part from their mate to pass cert and then switch them back as soon as the plate is riveted to the vehicle. 2 1 Quote Link to comment Share on other sites More sharing options...
kyteler Posted October 19, 2020 Share Posted October 19, 2020 9 minutes ago, KKtrips said: Yep, should make it easier for certifiers because they won't need to get the vehicle back to fit the plate. The tag will be fitted at the time of inspection and livened up once the cert has been processed as OK. Does it also mean that you can put the tag in more places or will there be a set collection of places where the tag can go. It would be nice to be able to to put it up underneath the parcel tray, for instance. Out of sight but still easily accessible for an RFID reader Quote Link to comment Share on other sites More sharing options...
KKtrips Posted October 20, 2020 Share Posted October 20, 2020 No, they will be mounted inside the door frame unless there is an incredibly compelling reason not to. 1 Quote Link to comment Share on other sites More sharing options...
Nominal Posted October 20, 2020 Share Posted October 20, 2020 10 minutes ago, KKtrips said: No, they will be mounted inside the door frame unless there is an incredibly compelling reason not to. Like, inside the inner door trim out of sight? Quote Link to comment Share on other sites More sharing options...
