si
  • Replies 9k
22 hours ago, cletus said:
yep anything adjustable that wasn't originally, needs cert.
have not seen anyone cut down the cones, only seen people use adjustable ones. if the cone is solid, and you keep the "spring" captive, probably no reason you couldn't shorten it
Many thanks, I figure this would be the case.  Wasnt terribly fussed on using them, onto TM they go....
Seat mounting question
mounting some non original buckies onto stock rails. If I attach a bit of 25x25 box to the factory rails, then affix the captive nuts in the seat mounting point,
does that box section need to be the heavy wall variety?   I'm not sure that those press in plastic bungs you can buy will fit the thicker wall box.
alternatively, what wall thickness would that box need to be?
And at the front,  the two sets of mounting points are 43mm and 72mm  away from one another, as well as 25mm wider each side. Since I can't use the box section running across due to the front to back variation,
would a slab or 8mm steel plate with 17mm spacers between the plate and the seat (to make the seat Base parallel to the rails because 25mm Box at the back) be sufficient?  The studs sticking up from the rails are m8. And the seat has six m6 capscrews. Two at the back,  and two pairs at the front)
probably need a pic to try and understand this better
On ‎25‎/‎11‎/‎2018 at 17:20, BlownCorona said:
Can I have my hand brake cable running through the driveshaft hoop? As it sits it naturally goes through the hoop.
I assume this is a no no, but before I go and modify other things to move the cable I figured I'd ask the question
no, cable should be outside the loop
You can. Page 14 in here has the requirements
https://lvvta.org.nz/documents/standards/LVVTA_STD_Braking_Systems.pdf
One of the requirements seems to be it has to be an automatic for some reason?
The only one ive seen that operates the cable are aftermarket units that look like a linear actuator , otherwise the oe ones I've ever seen have been in the caliper.
That's not to say they don't exist, just I haven't seen one
