si
I've just had a certifier tell me he isn't even going to start the certification process on my MX5 due to the position of its welded in rollbar.   Its made by a guy thats done at least 30 for mx5s, and is a MSNZ approved design.  The issue is the A interior impact zone.  The LVVTA standard (see attachment) and the cagemaker measure the seat from the middle of its fore & aft movement, where as the certifier has measured it from the seat right back.
Is there any reason why the certifier is measuring it differently to the standards?
  • Replies 9k
Yeah I mentioned it.  He just said that in his opinion it should be measured as far back & reclined as possible, because the full range of the seat should be 900mm from the rollbar.
I understand where he's coming from since he's putting his name on the safety of the occupants so to speak. Its just frustrating that due to a lack of space for the web-clamp seatbelts, the only option is a fixed back seat for both driver and passenger.  Considering the roll-bar itself doesn't meet the certification thresholds it seems rough that its enough to fail a cert.
If it's written in black and white, and someone has modified a car as per the rules, then I think if would be unreasonable and probably not legal, to require something different to what the rule says.
I personally would agree with the logic behind his reasoning,  but that's not what the rule says...
hi there have put a newer engine in my old van but have had to drop the engine crossmember down 24mm, (1980 L300) have machined up some alloy blocks for the job, is this okay? or should i modify my crossmember with the mig?
engine x member is seperate to the front end x member.
Yep sounds ok if it's just an engine x member with no steering or suspension attached, bolts are long enough and have lock washers, and driveshaft angles are still good
3 hours ago, beachlander said:
What's the deal around making new metal guards/overs?
Thinking of reshaping my rear guards, by cutting off the arch and shaping a new one.
I'm guessing all that needs to be done is for the inner to be fully sealed to the new piece?
If you cut the original guard line higher,  and remove the spot welds, you have to weld the two skins back together,  it also has to be sealed and painted etc.
I've since had a few calls with Ken at LVVTA.  He has confirmed that it should be measured from the centrepoint and will discuss it with the certifier when he's back from a holiday.
However when I asked about the vagueness of the "seatback in a normal driving position" for the passenger side, he wasnt able to provide any real answer.  The only solution he gave was to stop the seat from reclining, which the certifier already ruled out because its reversible as well as a potential point of failure.
Again the difference the A zone contacting the roll bar or not relies on how far back the seat is reclined.   Considering the cert process hasnt technically started, is it worth me finding another certifier who isnt currently on holiday to go with who can discuss it with LVVTA?
I'm investigating front brake upgrade options for my Triumph 2500...
It uses a disc bolted to the rear of the hub using 4 bolts with a pcd of approximately 85mm.
If I wanted to replicate this mounting arrangement by drilling new holes in some appropriate larger diameter vented discs, what would be the minimum acceptable distance for the holes to be to the center location hole? If that makes sense.
As an example, I found some renault discs that look like a possibility. If I drilled 4 new ~13mm holes at a 85mm pcd, that would leave about 5mm of metal between the edge of the 61mm hole and my new 13mm holes. Would that be okay, or too close?
Why not fit fixed back / position seats to rule out any issue?
Probably ok
Does the center hole match with the hub? Or is it bigger?
17 minutes ago, cletus said:
Probably ok
I haven't taken it apart yet, so I don't know. I just did some quick and dirty measurements last night while it was assembled. Hopefully the hole is the same size(unlikely), or larger. If it's larger I expect I would be able to get a 'sleeve' machined and pressed on.
Yeah thats what I'll be doing now.  I'm in touch with a couple of people that have Lotus Elise seats they might want to get rid of.  They fit perfectly into an MX5.
I didn't want to go for a Sparco or what have you for the passenger side as its not exactly girlfriend friendly.
At this stage its a hypothetical question as deal isn't done but a mate wants to sell me his registered and warranted Holden less the 500 hp chev in it , if I brought it and threw in a bogs standard 304 Holden (originally a 6) will I need to get it re certified
What he's asking for it is less than a panel shop would charge for the mint paint job on it , he's in process of acquiring a restored Camaro that is now less the motor
