si Posted June 21, 2004 Share Posted June 21, 2004 went to change gears, hand holding the gear stick ended up punching the center console............. nana drive it home using the remaining portion of the shifter .... (my broken stick on the right, the stick out of my old 4spd on the left, silly 4spd stick wouldnt fit ) as you can see its ripped off from here got home, unscrewed the center console and etc stuffs, took the shifter out, the 4spd one is way way diff mounting to the 5spd, so went n got the shaft welded back on (only cost me 6beers for the welding) Now 'tina is all fixed, gear sticks on a better angle now too so if you own a cort or esky, and give your car a beating or two, i suggest you throw a few welds on to strenghten it up! si Quote Link to comment Share on other sites More sharing options...
zep Posted June 21, 2004 Share Posted June 21, 2004 Man, that must've been a bit of a shock, have the gear stick break in your hand! Good thing you got it fixed tho. Quote Link to comment Share on other sites More sharing options...
big tymer Posted June 23, 2004 Share Posted June 23, 2004 geez how hard do you change gears Quote Link to comment Share on other sites More sharing options...
mex Posted June 23, 2004 Share Posted June 23, 2004 haha, my mate just did the same thing in his RS Legacy, he also has no 1st, not sure if the two breakages are conected or not tho Quote Link to comment Share on other sites More sharing options...
