lowlancer Posted May 30, 2004 Share Posted May 30, 2004 Are spacers illegal? I got some new wheels, but the tyres rub on the strut that holds the spring, only the front wheels though, so I was thinkin I need some 15mill spacers to stop it from happening, but apparently they're illegal.... Could I dent or grind the strut a bit as well, will it make the car dangerous or un roadworthy? Quote Link to comment Share on other sites More sharing options...
datsunboy Posted May 31, 2004 Share Posted May 31, 2004 DO NOT dent/hack up the strut! I think spacers are illegal....but not sure...if they are proper spacers that bolt to the hub, then maybe....but 15mm is a fair bit. go ask a warrent man. Quote Link to comment Share on other sites More sharing options...
zep Posted May 31, 2004 Share Posted May 31, 2004 Yea, they are illigal. Sounds like you got the wrong offset wheels, man. Quote Link to comment Share on other sites More sharing options...
si Posted May 31, 2004 Share Posted May 31, 2004 Fitting of or modification to: Aftermarket wheel fitments LVV certification is not required provided that: THE WHEELS - are a known and reputable brand non-OE item, and - would be considered an appropriate fitment for the vehicle type by the wheel manufacturer and - are not modified,and - spacers or adaptors are not fitted, and - do not cause the vehicle’s track to be increased by more than 25 mm, and - do not foul any other vehicle components. THE TYRES: - have an outer rolling circumference that is not more than 5% greater than OE, and - are an appropriate selection for rim width, and - do not rub on suspension components, body structure or outer panels during normal vehicle operation, and - tyre tread does not extend beyond the original body panels and - tyres do not foul on any other vehicle components. Quote Link to comment Share on other sites More sharing options...
lowlancer Posted May 31, 2004 Author Share Posted May 31, 2004 The back ones are sweet, but the front ones scrub, so i might just get 15mm spacers and get it certed. Quote Link to comment Share on other sites More sharing options...
