w'cked Posted September 15, 2003 Share Posted September 15, 2003 Noise, shakin', and leaky-ness, its stuffed. So tell me what to do yall, what are my options, what should i look for, should i upgrade, do i need lsd?, what about a locker where should i go to get the stuff, is this enuff questions already? oh yeah, my car- ke36 2dr wagn, sacked on its ass w/4k. cherrs -stu Quote Link to comment Share on other sites More sharing options...
zep Posted September 15, 2003 Share Posted September 15, 2003 I don't know of anything which bolts right up to an oldschool corolla, but if you want some strenght, use a hilux one, you could prolly get it cut down to fit. A detroit locker would prolly set you back a fair bit. Quote Link to comment Share on other sites More sharing options...
Guest savant Posted September 15, 2003 Share Posted September 15, 2003 If its just a 4k and you dont have much cash i'd just go for another stock diff i'm sure you could pick one up from a wrecker for fuck all. If you're keen on circle work then get it locked but you'll need to find a leniant wof place. LSD would be sweet but a bit harsh on the old pocket, as zep said hilux ones are pretty cheap and you could get it cut down to fit. i've heard lockers are unpredictable as, at least if its locked its locked all the time so you know you're going to be doing skids ;D Quote Link to comment Share on other sites More sharing options...
Jebus Posted September 15, 2003 Share Posted September 15, 2003 Yeh man an LSD from an AE86 will fit almost right in, just needs shortening a bit but cost alot, mine was gunna cost about $800 for the diff and brake setup, also with going that option you get disc rear brakes. Otherwise if youre made of coin as they said a Hilux diff but the chances of you breaking that are almost Nil with a 4K A locker is good fun, except when driving round corners, round hard corners at slow speeds it will probaly bounce in the wet it will carry on in a straight line when you drive round a corner, good only for a temporoary thing, but NEVER as good as an LSD. Quote Link to comment Share on other sites More sharing options...
w'cked Posted September 17, 2003 Author Share Posted September 17, 2003 one of my mates is sussing me a ae86 diff, think its a lsd? and hes guna hook me free labor too, hes got an old rolla too, rep'd oldschool.co.nz to him- yeeah. Ill probly get the whole brake setup at the back too, has neone done this befo? what do i need so i can run rear wheel discs that i wont get with the diff? ill keep yall updated as progress starts.. hopefully tmoro Quote Link to comment Share on other sites More sharing options...
ROTA NUT 13B Posted September 17, 2003 Share Posted September 17, 2003 Lockers are pretty crazy aye, had one in my sev, bit dicey in the wet - when they step out they step out big good for swingin tight o's but thats bout it, mine broke an axle just reversing out of my ex's drive so i took it out and put a stocker in, still steps out nicely Quote Link to comment Share on other sites More sharing options...
big tymer Posted September 17, 2003 Share Posted September 17, 2003 yea go the hilux............... good ratios too and it seems to hold out with a rota Quote Link to comment Share on other sites More sharing options...
w'cked Posted October 14, 2003 Author Share Posted October 14, 2003 chucked a ke70 dx diff in thur and the driveshaft too(the lil joint was f'd), went in all sweet, ill hav to get a bettr one soon (read: hilux lsd), this ones just a band aid till i got heeps of bling and time, did all the work myself pretty much so it wuz a gd learnin ex neways, jus gta put the sump on my engine and im bak on the road agn fore those that care i think the dx diff has a bit wider track than the dirty30 one, by like 5cm or summn, thats gd i supose for beta handlin and look, but hopefully the 17's that are in the pipeline arent guna scrape Quote Link to comment Share on other sites More sharing options...
alfalfa Posted October 14, 2003 Share Posted October 14, 2003 so does this mean no skids for a while? hilux diffs are tough as, with lsd to boot so thats all good. what motor you putting in there or is the 4k staying for a while? Quote Link to comment Share on other sites More sharing options...
Guest nuty|mike Posted October 14, 2003 Share Posted October 14, 2003 dont keep the 4k if ur goin hilux stick a 4age in it i happen to have one coming up for sale ill be pulling out the engine in a few weeks make me an offer and its urs itll bolt up to a k50 or t50 gb and then u have 76.8 kw dyno proven with so many more mods to go Quote Link to comment Share on other sites More sharing options...
w'cked Posted October 15, 2003 Author Share Posted October 15, 2003 no skidz till the wknd (oh pleez cargods), na sory buddy i cant get ur engine cos its got pistons... yep. the upgrade/transplants guna be wankel pwrd! dont you even know... if its not a rotor its not a motor but theres other things to do befo that. paintjob cuz the one on there at the mo is thin as, and only looks good from like 8 metres(actuallymeasured) away lol. i think im guna have to lift my engine bout 5cm up to be able to get the sump off/sump on so im getn a endless chain tnite and m gona see if i can do the slack ass job of changing it- undo the mount things and hope for sum flex somewhere c how it goes tnite? Quote Link to comment Share on other sites More sharing options...
alfalfa Posted October 15, 2003 Share Posted October 15, 2003 kepp us posted on how it goes, what sort of rotor u got lined up for this badboy? Quote Link to comment Share on other sites More sharing options...
w'cked Posted October 17, 2003 Author Share Posted October 17, 2003 six port bridge port or summin, thats the plan neways, itll def be a 13b. iv got it all plannd! but its a secret... cos i cant be stuffd writing it out nw. Quote Link to comment Share on other sites More sharing options...
big tymer Posted October 18, 2003 Share Posted October 18, 2003 def the 13b aye nothing wrong with a 12a why not a 12a??????? doesnt anyone trust the old 12a aye thats it im out to kick some 13b ass Quote Link to comment Share on other sites More sharing options...
w'cked Posted October 19, 2003 Author Share Posted October 19, 2003 no subtitute fo cc's, lol seems weird sayn that bout a rotor, nah i jus like 13b beta than 12a for my car, no reasons why, its jus what i decided for sum reason, 13(killer)b's are wicked engines i rekon, mint power if u do it all right, gota do it right tho- fatty port Quote Link to comment Share on other sites More sharing options...
