Everything posted by felixx
I will come if I can get a babysitter
I used to have a legacy that sounded like a small machine gun. Poured it in, fixed in 5km However I was rear ended a couple of months later in that car... ... wrote it off so unsure how long it was good for
Going strong, starts on 4th pull ad runs sooo smoothly. Has become my #1 mower
Lawns done twice with this New air filter reduced hunting at lower revs Also it starts on 4th pull now with no WD40 My mower man was out of sparkplugs , but I will get a new one next week!
Good tips there @Dolan
Thanks Pete. I have a catcher but would love an intact mesh for the vents on the top if you have one. Happy to pay
Will try it tomorrow!! Thanks!!!
Why might it need ether or fuel added to carb on starting??
Bloody thing wouldnt start today. Chucked acap of fuel down its neck and it went first pull then did myfront lawn and the other neighbours jungle. We are now a 2 mower family
Goeshard. Air filter is currently 2 pieces of news paper. It goes real well after a carb strip. New fuel lines Maximum power thru ankle deep wet grass. Thanks for the advice
Hmmm ok. Will check throttle lever linkage as when I move it, nothing on the carb linkages moves,
I forgot to print yhe manwell today. Here was the state of the outside of it. So it has throttle and choke butterflies? How do you engage choke??
Thank you so.much
Thinking the pulsing is an air flow issue.. I did notice throttle did not affect the carb butterfly,so will check if the throttle linkage is not broken too. What have I missed? Interestingly the mower needed starting fluid each time, so could I expect a blocked jet..
Found this on the side of the road. Threw it in the truck and gave it a clean up. Its swallowed half the air filter. I cleaned the filter housing and threw some fresh fuel in.. pull pull nothing Sparkplug was dry Threw some start ya bastard in its neck 2nd pull it ran for 5 sec Tried again, reved hard then began sucking fuel and ran like the vid.. At inlaws for dinner so will look at carb clean and reattaching throttle linkage after work this week.
Good question. I will look at that in the morn Cheers @Bling
So I have some footage from a few trips with my lad. Would like to edit into a video or 3 Ehats some good basic free video editing software ? Is there any online as my laptop is not too modern? Cheers
felixx replied to h4nd's topic in Other Projects
- 1268 replies
- 22
Roger. I will pm you now Thankyou
He might have a beam. Will ask him
Thank you
Hey guys a pal in invercargill needs help.liftin an engine out of a hilman hunter .. Anyone able to.help with a hoist?? He is a gc who will help eith beers or another form of koha
Hmmm might do a bit more reading. thanks for the insights
