Posts posted by Evan
I think that last line is a bit misleading, I’m reading it as they’ve removed the other 3 wheels at a cost of $42.50 ea (totalling $127.50 of the $236) balanced all four wheels ($10ea?) then done an alignment which would be the $80 or whatever remainder.
but just ask them to clarify
Popup headlight conversion pls.
1 hour ago, dabuzz said:
People will pay 3g just for the manifold
Or a grand ex japan
https://buyee.jp/item/yahoo/auction/559431550?conversionType=search_yac_browsing_hisotry_list
Now that you’ve sorted the cooling thing can you now fit a PTO so you can run a mower/log splitter/saw mill/wood chipper.
- 5
Recently picked up one of those generic 220l freestanding blasting cabinets, so I could set to work blasting/primering/painting the rear suspension/bag mounts etc in several batches. Such a time consuming task but super satisfying seeing once scummy parts come out looking new. Need to replace the window and do an LED light upgrade to the blasting cabinet before I can do anymore (the front suspension bits). Can't see shit in it anymore.
Ended up cutting the wheel bearings off the half shalfs so I could paint the drum brake backing plate. Don't have a press so might try the axle in freezer, bearing in oven trick for fitting the new bearings I have before I go door knocking around the neighbourhood trying to find someone with a press I can borrow. Then I can finally get the diff back together in one piece. The whole diff hangs from a rubber bush that sits in the boot floor, I've got a new one of these bushes on its way from Germany as the original is suitably flogged but it seems the replacement one is on the slow boat so who knows when that will get here, but I need it to refit the diff so bit of a stalemate there.
Also picked up a 722.6 trans out of an early 2000s W203 that suffered a timing chain failure (like most of them do). these don't bolt up to the M180/M130 family of engines so I need to make up an adapter plate, which is my next job will also need a controller for it but that can wait. I've gone the complicated route of gaining a lock up torque convertor and a 5th gear, but a man wants what a man wants.
Until next time.
- 27
Anyone else following this guy on YouTube? He built the Draco bush plane that he later crashed, this is his latest build, it is off-the-chart for DIY Carbon Fibre work
5 hours ago, Truenotch said:
New seat mounts are on my to do list already. It's solidly mounted to 50x3mm strap that's welded to the floor, but either the floor, mounts or the seat itself must be getting a bit of flex. It's pretty tiring to drive, so a more solid mount will likely take some of that load off too.
I've definitely got a few jobs to do before the next outing though.......
Where did you get your DOT push to connect bulkhead fittings?
Have you considered making an extra LWB version?
- 5
Have a question on retrofitting rear seatbelts, my Merc ('65 Fintail) would of originally had fixed diagonal seatbelts for the rear seats - there's an OEM mount in the top of the parcel shelf and in the bottom rear bulkhead/firewall towards the centre, but no mounts in the rear wheel tub area so can't have been 3 pointers, just a two point diagonal. Id like to upgrade this by poking a hole into the rear wheel arch to add a 3rd point and fit retractable unit to the factory mount on the rear parcel shelf and maintain the factory centre mount for the receiver. however I see there is this in the standards factsheet:
"2.5 Attachment requirements for all seatbelt anchorages 2.5(1) A seatbelt anchorage, other than a complete anchorage system where all components of the anchorage are provided, positioned, and installed by the vehicle manufacturer, including all associated hardware, fasteners, and reinforcements, must: (a) attach to a permanent part of the vehicle structure such as a pillar, floor section, or inner wheel arch; and (b) incorporate doubler plates, and where applicable a crush-tube, tubular spacer, or solid packer, which are designed and attached as specified in 2.6 and 2.7; and....."
Should I be interpreting that in a way that, because my complete system of anchorage points are not OEM - only 2 of the 3 would be, I need to double plate the OEM mounts as well as the one I'm installing in the wheel arch?
You’re just going to have to wrap you block in carbon and shoot for 600hp then.
- 5
They just look the same from 15 feet away.
/Gizz that Merc
Compound charging the 3L would be way cooler.
/ling
Howdy, been awhile. Life got in the way there for a bit; moved out of Auckland (subsequently moved house a couple of times with the Merc spending a bit of time in storage), had a baby etc. but Xmas holiday period has allowed me to make some progress.
I wasn’t happy with the tabs I had welded on the upper rear airbag mounts, so ages ago I drew up some flange things and had them laser cut, finally got around to cutting the old tabs off and welding on the new flanges so thats all much tidier.
Drilled some holes in the car so the aforementioned mounts have some way of attaching to the car, front two bolts come through from underneath the rear seat; the rearmost hole had a captive nut welded on the topside as it’s inside an enclosed box section of the car (welding upside down can suck a pineapple) Gave it a prime and a paint to match the rest of the underside
The engine I mentioned is in no hurry to rotate, I spent some time trying to free it up with various liquids and heat but nah, Piston 1 isn’t budging. Was scrolling Facebook marketplace one evening looking for a transmission and stumbled across a guy selling another engine for cheap approx 800m from Sentra Daves place in sunny Onehunga so bought that.
This motor is an M130 out of a W108, the last variation of the M180 engine family. Displaces 2.8 litres (vs 2.2l), make 160ish hp when new with improvements including larger valves in the head and 7 main bearings vs 4 in the smaller displacement versions. This one runs (although the cam has seen better days). An added bonus was that it came with a power steering pump attached and the power steering box from the W108 it came from - which bolts into a W111 as they’re the same chassis, So I need to source a shorter steering column from a W108 to suit and then I’ll gain power steering. (KY if you see this I still want that V8 so don’t panic)
Spent the last couple of months leading up to Xmas buying various supplies to put some paint on things, including a couple of spray guns based on YouTube recommendations. Got a chance to give the boot floor a sand up then smooched some seam sealer around the place and waited for it to stop raining. Got a chance to mask it up, wipe it down and blow over a fresh layer of epoxy primer followed by some 2k satin black
For my first foray into spraying paint it came up not bad.jpeg, couple of rookie balls ups mainly consisting of me dropping the air hose on the boot floor whilst trying to reach under the parcel shelf etc which has left a couple marks but it’ll all end up hidden under a rubber mat/carpet so I’m happy as with it. Rear tail light panel will end up body colour (which isn’t black). I’ll probably need to go back and brush on a couple bits that I couldn’t get the gun too.
Progress feels good though.
- 23
11 hours ago, Dolan said:
T659 8x4
specifically designed by a group of logging company owners for Nz only.
Pretty weird looking with the sloped and short bonnet and high sling cab but they are great trucks on logs.
Cabs are tiny! Currently have one in my showroom and people think it’s a miniature lol
I cant get over 8x4 bonneted trucks eh they look so whacko.
What do they gain using a conventional over a cab over/K200? Other than it being easier to climb in/out of 16 times a day compared to a K200.
55 minutes ago, Yowzer said:
RE003s on everything
I saw RE003s on a flat deck hilux the other day.
What the old man is trying to say is, JC > FD
Why no petrol? It’s not like you’ll be moving it every day
FYI @MRWEST Povo spec US model FCs had 4 stud brakes - not sure what diameter the rotors were vs 5 stud but rockauto might be your friend here...
oldrx7's 1985 Mazda Cosmo
in Project Discussion
Looking forward to this making an appearance in Titan Tuesday’s
