Everything posted by azzurro
Love these, mate had a 2 door one in high school with blue interior and ive wanted one ever since. Looks awesome, but i think i can smell it from here. Whats living/dead under those seat covers? Cane toads all the way down?
Its a Fiat one, they have such lush hand drawn illustrations. I only have the 'Specifications and Features' one for my 125 its about 120 pages, and doesn't go into much detail. i have a couple of 'Service Manuals' (2x 1500/1800/2300 ones S1 and S3, and a 124 Spider one) they are over 700 pages each and have ALL of the procedures including pics of the special tools. The trick is to remove the split-pin and unscrew the nut holding 8 to 13, and the pin holding 11 to 12 then the stick/changing mech can stay in the car, as the gearbox is disconnected from it
re the guibo, i use a chain wrench to compress it a smidge so you can actually remove the bolts The only thing i remember about the 4 speed linkage is it was a pain to get out, but i think you only need to remove it at one or two more accessible points on the side maybe? and leave most of it attached to the tunnel
Yes, Finally!
RE engine and box out together. It can be done, but its tight. as you say a short engine bay, and the radiator/slam panel is a key part of the front end structure so no cutty cutty. The 4 speed/1608 combo is the easiest as the block is a wee bit smaller and shorter and on the 4 speed the end of the box is both smaller and the lever bits gets left attached to the tunnel. It needs to come out nearly vertically so need the car up high and a engine crane with a load adjuster thingee. I found it easier to take the engine out first, but put them back in together. need to remove the starter tho.... best way is all of the extensions and a couple of universal joints with tape around them to get those mummajumma starter bolts from the back of the gearbox. Also if you disconnect the propshaft and tilt the engine back there's a bit more room/visibility. I need to update my 125 thread too!
Mjne had td27 engines but likley to be either Fuel or electrics Fuel: filter or leaks or water or bug? Try empty the water filter thing Leccy: i had some intemittent electrical issues on my e24s, these things reduced the return period. try swapping out the fuses, and check and clean the relays and connections including the big ones like fuel pump etc under the seat hatches where it gets pretty manky. I think the water trap or fuel filter is under there too Ecu is under the seats, and wire loom goes under the drivers floor mat. Ill give you $5 if there isnt spilt sticky coffee, some gib screws, a battery, a broken pen, rust, and vampire taps under the carpet and in the ECU hole
Yetchh's "more problems than I expected" bay kombi
azzurro replied to yetchh's topic in Project Discussion
yay, came for the ACVW problems, stayed for the ACWV problems. -
@nzstatoDo you have an engine crane? Could use my van to collect and store wherever. Keen to check out your setup. @DoBro Jesus whats old mate with the engine's timeframe? Going to invegiggle tomorrow so could do sunday or a weekday
I can definitely transport and store it no worries but will need a hand to pick up from sellers and move into the shed at my end as i dont have an engine crane down here yet and diesel engines usually weigh more than the moon. I hope its for lada wag. Ps giz lada wag.
azzurro replied to h4nd's topic in Other Projects
If its birdnesting like that it could be tension on the roller too high as well. Its supposed to slip on the wire if you pinch it in your fingers as it pushes out the end. As the liner gets dirty from use it gets sticky so it might be cranked tight to push through, but on occasion of a new one need everthing readjusting again. More knobs to twiddle! -
yeah, and they get effectively larger as they wear as well. Gasless wire has that rough as coating on it (which when burns creates a gas shield) so can both wear liners quick and cover them in gack as well. This site (first one on my goog) has 4 diameters: https://www.arcweld.co.nz/itemdetails/Binzel-(Style)-Liner/3623.aspx -
Loom room for more zoom zoom?
Is pretty good, i got heaps of 2300 parts from there i couldn't find anywhere else. (or where way cheaper than other places that did have stuff) i think he does all sorts of 'foreign' makes out of a big warehouse in the middle of nowhere Georgia under the "mr<make>" tagline - they are on ebay as well so you can use their purchase protection thing if you wanted. Flipping carbs man! Definitely worth spending your time with the Weber over the Solex, just better all round, even if they are both 50 years old now,.
Probably the liner needs replacing. If it came with a roll of gasless wire it may be a bit big ID for 0.6 to start with. -
Fiat factory manifold already flows pretty good? Port matching the manifold to the head and a better flowing (ie slightly bigger) exhaust can do a lot to open her up. Extractors look blooming cool tho!
Lovely work on all the components and plating. I dont think i would have the patience! Air cleaner mod is A++
youshop is great for this. Shipping in US is cheap or even free, but for some reason outside of US is $$$ crazy. On lots of forums even Canadian dudes reckon its worth the savings to cross the border to pick up from a drop ship place.
Weber & dellorto carbs like low pressure high flow, assume the mitsi carb will be the same? 2 to 4Psi max otherwise the needle valve has trouble controlling the fuel level in the float bowl, resulting in running issues. A 6psi pump with a 1-4psi reg will be fine i reckon
I have no complaints about Ladapower.com , but beware the cheap versions are usually *really* shitty Shipping vs price ratio always makes adding extra bits worthwhile. Plus sometimes get a lada calendar, pen and ukraine chocolates. Ive also used Mrfiat.com Mal euro-italian in albany There is a lot of crossover between lada and 125 as well, so start in the 2101 section
Sweet so far! Cars are still up norrrth, planned collection mission for this weekend cancelled got all the time and space now, just no projects to work on.
The last blurry photo looks like the elecrtomagnetic fan power supply thing. The spring presses a carbon bush aganst the back of the fan and when the temp sensor comes on it locks the fan on. I have a few of those points style regulators, on my lockup. i think @Testament is still rocking his? The solid state lada ones are a plugin replacement. I hid mine in a gutted points box so looks are the same
Yep, can leave at mine no worries.
i use these https://www.torpedo7.co.nz/products/-0S8AN6SE/title/ear-plugs-2-0 for surfing as i have bad surfers ear. They cut out the wind but still let you hear, and come with various bits to let you size them to your earholes - recommended They have come out with a v3.0 now, so wait till T7 puts the v2 on special (the price is more than i paid from a proper surf shop a couple years ago, just first link i found)
