Everything posted by rb drifter
This is interesting seeing this ute thread! My boss was telling me about the original yellow rx3 ute and i had heard from others about it too. I'll have to show him the pics we were all wondering where it got to
Whangarei Monthly Meet. Tuesday 13 Feb. Burgerfuel 7pm
rb drifter replied to bigfoot's topic in Upper North Island Region
The local Boys keen on a winter meet? Been awhile due to covid, etc @bigfoot @gibbon @WhangareiKE70 @WhangareiKE70 @MACKAZ anyone else i missed? Somewhere with a fireplace maybe? Frings, butterfactory, lonestar open to suggestions -
Picked up a pair of 14x7 zed compes off Dave, gave them a trial fit and polished one quickly. Quite stoked with the fitment of them just gotta get tyres on them asap. Also attended a local car show, and did some casual cruising with the boys
Rb drifters' neglected 82 ex lancer
rb drifter replied to rb drifter's topic in Projects and Build Ups
As always been neglecting this car but I did do something to it by chance. Found a cyborg in my mates paddock so purchased it to strip for parts. Wasn't much worth saving but the motor will be of good use. 1600 dohc turbo 4g61t. Decided to mate it to my sigma gearbox using a sigma flywheel and cluch and drop it in the hole. Flipped the td04 on the stock manifold for a laugh, it won't work as it's touching steering box but kept me entertained. And purchased a modified rwd intake manifold off Bigfoot -
Failed wof inspection on some rust, front left shock knocking, brakes too soft and handbrake to improve. Had the privilege of using a mates hoist and his labour, he made a start on the rust while I sorted the brakes. New rear wheel cylinders courtesy of @bigfoot , also noticed some bent stuff inside the drum which explains why handbrake wouldn't self adjust. Note the bent over edge stopping handbrake from working properly. We straightened both items out and happy days. after removing the front strut It was apparent there was a spacer missing allowing the insert to move within the strut housing causing the noise so we made a spacer from some steel. Problem solved
Next on the list of things to do was the exhaust, it's had a hard time since the last wof with all the speedbumps it bottoms out on. had to grind out some of the weld for nut to turn. Threw some new brake pads in the front too so hopefully wof man likes my efforts.
One thing that wasn't necessary but bugs the shit out of me was the spacer in lower radiator pipe. Was there because of the power steering bracket that was originally on this motor (l200/sigma engine) And also the pulley for power steering and fan hub is actually different. Someone had put bolts in the pulley too so I swapped that out for studs, how it should be... And the finished result. Doesn't look like much difference but makes me extremely satisfied!
Wof time is overdue so back to working on this car again. I had purchased some original front struts with bilstein inserts and lowering springs off a mate I Auckland but borders in place meant I couldn't retrieve them. Now that's over I can actually get this legal. So the starion struts are now leaky shocks and the cut springs are no good, hence the swap. Plus i want to run standard wheels for a wof which they didn't fit on starion struts. Also I'm changing the front crossmember as some cuzzy had redrilled where the lower arms mount and welded washers on. (To give more camber/wider wheel track) Surprised it wasn't picked up on previous wofs. Even the old owner was unaware of this mod.
Will be there -
I'll be absent if it's early next month most likely. Would be interested in maybe a change up for summer. Fish n chip by the tide even? Need to acquire a wof shortly too -
I'll make the effort to be there this time -
Scored some monsoon clips of this extremely tidy one lady owner l200 my mate has in their padock. So now I could finally fit my passengers side monsoon to the lancer, these are the finer things in life for sure!
Don't worry I did exactly the same. Must be old man too -
Stumbled upon this haul of parts today on Facebook. Dude was local and had a good yarn with him. Potentially may have more parts for me to purchase once he empties his storage unit. Got a 1600 crossmember, some suspension parts, there was also new tierods, castor bushes, pitman arm etc (not in pics) and these sweet manifolds. They're a little cuzzy custom spec but will still function no doubt. Will install/swap the crossmember when I get a chance as the one In the car has been redrilled for wider wheel track but Im not too impressed with it.
Mr.mk1's Mopar or No Car '70 Dodge Coronet
rb drifter replied to RUNAMUCK's topic in Project Discussion
Absolutely blown away at the work your putting into it dude! I myself struggle with a short attention span, so to see someone so consistent on progress and keeping the thread updated for our viewing pleasure really helps the motivation -
Do we just order burger and eat In carpark on our bonnets like the sophisticated Bogans we really are ? -
Now that we know it's level 2 this week do we re organize a meet date? -
Pulled the gearbox out of my other car and will use it for this car behind the 4g63t until I can afford something better like maybe a r154. I've had this gearbox since I was 15 (now 27) so it's had a fair amount of abuse and has started a crunch into 3rd gear but it still works so I'll keep sending it. But decided it at the very minimum deserves a good clean after its years of good behavior That was after the first waterblast and oven cleaner soak, gave It one more soak with oven cleaner and it came out better. Will give it some more another day just because now I'm eager to get it as clean as possible Note there was no scrubbing just waterblaster and oven cleaner.
Got my front crossmember and the body mounts for rear diff dipped in acid to clean off the rust. Quite happy with the results gave them a coating in this product called ripo aswell. First time using this method but been advised I works well, next is paint once everything has dried up -
That brake fluid on the sprayed interior looks like it works well! Will have to try that myself
Decided to drop the motor and box during lockdown. Didn't have an engine crane so just dropped it using a trolley jack where it was until I get my hands on one off the boys. Wasn't to bad doing it that way -
Bought 3 more wheels to match the pair i had. Cheers to dave for those. They need a good clean up, some wider lips would be ideal once funds allow. And having 5 wheels so the spare matches too will be epic -
Decided to document some of this build on YouTube for those that are interested. I'm a rookie at this so excuse the shitty filming and editing, I'll attempt to get better one day...
