Everything posted by kicker
More 3d shenanigans, this time a grille badge I was missing and rather than source one I could try and have one printed. First up was factory-ish style but a bit boring So next one was a bit more fun Back to the library Test fit Needs some paint but should do the job Less cool factory badge Another bracket ticked off is the forward shifter cable mount, just some mild steel folded up. Mounted in the coolant hose tunnel Lever installed with cable fitted and console in place. It was a bit of a fiddle but it all fits as long you follow a particular procedure.
- 27 replies
- 29
It was getting to the point where I really needed to sort some brackets for various things in order to progress. I normally don't like making them, they are like workshop admin but this time I used Fusion 360 and it made for a much more satisfying experience. First up was the ecu, a smooth thin box with no mounting features so it needed something to hold it securely. I'd heard a local library does 3d printing for the cost of the filament used so thought I'd give it a go. $10.90 later and I have this, black would be better but this is a good start. I just need to cut an ally strip to hold the ecu in place. This will attach to a larger bracket, still in the works, which will also hold the surge tank and oil cooler bracket. Next up were some brackets to hold the starter solenoid and bike fuse box, cad'd up then a template printed to scale and cut out of some mild steel sheet. Lastly is the gear lever bracket, rough cardboard templates first then drawn up in CAD then printed scale templates and test fitted then sent for laser cutting. Brackets
- 27 replies
- 41
WOF day! Not much happening at the mo but I now seem to be putting together 2 sets of road wheels now. One spoked and the other will be 90's style using wheels off a small capacity sportbike.
- 72 replies
- 22
Top info there mate, much appreciated! The rubbber wheel tip is a good one.
Anyone got any recommendations for a cheap linisher? I just want something to tidy up sheet metal cuts etc
Ah yup, an ESF, confusingly Suzuki had another model called the ES that was a different style. I've had a few EF/ESF/ESE/EFE/EFF/EFG over the years, in fact I have one in my garage that I have just sold as it was a bit more of a project than I wanted right now. End thread hijack
GSX1100EF, the grandfather of the Hayabusa
You gotta EF? Come on man, don't hold out
kicker replied to yoeddynz's topic in Project Discussion
Love these updates, always plenty of swarf and metal glue -
Something like the V-TACS pedal on the Honda Beat
kicker replied to KKtrips's topic in Lower North Island Region
Oh cool, I'm free thurs so will come along -
I'm deep in the head unit rabbit hole atm, not sure what one I'll get but I did a scan and I have an L revision canbus gateway so that helps.
This is relevant to my interests, I picked up a mk5 tonight, 2.0T wagon with stage 1 remap. It has induced a few grins so far. Your headunit looks good, might need to get something similar for some modern features.
Yo dogg, you need to regulate your regulator Good work though, perseverance (or $$) will get it done.
I am at work with not much to do but search the webz, does this help? The voltage regulator sends power out through the field terminal that goes to the generator and that’s how the generator comes to life. So for test purposes, what you want to do, is with the wires still in place on your voltage regulator, get a jumper lead connected to a power source. Wiggle that on in until making contact with the field terminal. Now we’re sending full field current to the generator. When we do that, we’re doing the voltage regulator’s job. When we do the voltage regulator’s job, if the generator comes to life, the voltage regulator is probably our problem. However, with the wires in place, if we put full current right here with that wire that goes from the field to the generator and she still won’t come to life, chances are strong the problem is in the wiring between here and the generator. https://mossmotors.com/how-to-test-voltage-regulator
Here you go, looks like it's still on special too https://nzairfilter.co.nz/davies-craig/8907.html
Didn't seem to be much room to spare inside, do you change the pump housing too? I had previously discounted an electric pump as the prices were high but found a seller recently who had them for $300 so decided to go for it, plus now I can see what is happening in the cooling system.
My new water pump controller arrived Saturday, props to Davies Craig for sorting it quickly. I plugged it in and everything looked good. I gave it a test today and ran it for about 30 mins. Temp limit was set to 85 degrees so when it hit 88 the fan came on and within 30 seconds the temp had come down to 85 again, pretty happy with that. I let it do this a few times and it seems to be working well. Only issue remaining is the time it takes to warmup, I suspect they'll recommend a thermostat with some extra bleed holes in it but I'll run it past the manufacturer and see what they recommend.
- 27 replies
- 19
9New direction, I was taking the fog lights off when I remembered I had a box of lights that might work. So now I have DRL's instead, dekatora running lamps. I have some spare if anyone is keen.
- 27 replies
- 30
About 9000rpm
- 1536 replies
- 16
The water pump got pulled out in preparation for the electric one. It's a bit teeny understandably, impellor was about 50mm dia. Nice block off plate Don't worry, I got a new output shaft seal to put in. Then got a larger boss welded to the thermostat housing for the temp sensor. I got the electric water pump wired in but the screen was dead out of the box so now I'm following it up under warranty, boo. With that on hold I thought I'd have a play with some other shit. Fuck yeah accessories, got some fog lights and air horns hooked up. I got the horns tucked in nicely behind the plate. Then I was reminded how small this car is, the damn plate sticks out over the lights. Need a plate narrower than 320mm to miss them or find another spot for the lights to go.
- 27 replies
- 23
kicker replied to h4nd's topic in Other Projects
I did the same during the first lockdown, matai weatherboards, cedar skirting for bargeboards and left over coloursteel from the house. Fucker never used it and would sit in the rain so I knocked it apart and took it to the tip. -
Yeah I'm out too, weather be trippin and my only transport is a 100kg 2 stroke -
If they Kilim, we'll eat 'em
