Everything posted by Adoom
Has anyone tried using dry ice to remove spray on underseal? I've used it on the sheet stuff with great success, but Triumph used a spray on product on the floor of my car. This is inside the car, not underneath.
Just try reversing your 1973 mini estate with no reversing lights down an unlit winding driveway after delivering pizza to the address at night time. Is that bit of dark darker than the other dark? Yes, it's a post and you have just run into it. #oddlyspecific
Made my jig rejigging jig. The big box section has two sets of holes for the studs, the original location and the narrower location. Once I bolted it to the studs, I welded some random bits of scrap to join the two jogs together. Then I could cut the mounting studs of the first jig, move them to the new position holes, weld them to the jig again, then cut the rejigging jig off. It not very exciting to look at... I got the subframe positioned in the car and bolted up to the repositioned front mounting studs. I need to think of a way to temporarily attach the strut towers and box section to the car. But it needs to be removable so I can put it in the other car and have it in exactly the same place. I'm going to guess that the position of most of the bolt holes is "close enough" and won't be the same between the two cars I'm definitely going to need a custom fuel tank.
Yesterday.... Precariously balanced really heavy thing done become unbalanced and had an oopsie. I don't have a less precarious system for lifting it ~700mm into position. Scissor jacks are required for levelling. Sigheth. Well, I did need to get back in there to relocate the two front mounting studs. They need to be 50mm closer together. Fortunately, they are attached only to a bolt-in jig. I'm gonna make another jig, with holes for the old and new stud locations, that will align on the existing studs, then attached to the body, that will allow me to detach the studs from the bolt-in jig, move them to the new holes, then reattach them to a modified bolt-in jig. JIGS!
- 188 replies
The Fabricator youtube welder guy.... On one of his rollcage videos he did all the scraping, then used a small blowtorch to burn out all the little scraps left.
Finally at the back again. Made cross member MK2. Used some 1.6mm steel for the sides, 2mm for the top. The vertical metal bandsaw is right up there in the favourite tool list, it makes cutting this stuff up a piece of cake. Zip zap welded it together. Blurry photos. I really hope I worked the heights out correctly. This should give me ~70mm bump and droop from ride height.
- 188 replies
Hotrod yacht please. Install a stealthy jet boat jet thing for yacht drags at the boat traffic lights.
- 66 replies
- 9
- noelex
- trailer sailor
- (and 7 more)
I bought mine from these guys. https://panelstore.co.nz/products/408-epotec-primer-kit-4l-1l-white
Made a fan shroud. Also made some clearance around the radiator cap, the radiator needed to move forward a little more.
There should be a plastic cover over the lens that you replace. The std rectangle ones are only a few $ at Mitre10. I bought one of these Optrels two years ago, it may be an old model now. It was pretty expensive for me, $800. But the clarity in dark and not dark mode is fantastic, a massive improvement over my previous one! It also has a big viewing angle, not like the typical letterbox view. https://www.prolineindustrial.co.nz/product/optrel-panoramaxx-auto-darkening-welding-helmet-204544 I'd definitely recommend it if your budget can accommodate it. Note: My previous experience has been with a cheap non-auto darkening helmet. Then a ~$200 auto darkening helmet. Now with the expensive optrel.
EDIT: In the discussion thread... I solved the leaky clamps by spraying silicone spray between the hose and clamp allowing it to be tightened without pinching the hose. I found the oil leak eventually. When I welded on the AN fittings to my remote filter adapter plate, I had to machine a relief into the weld for bolt clearance. Doing this had created a tiny little pin hole, I could barely see it but when I removed the bolt and ran the engine I could see a weep of oil coming out of apparently nowhere. So I bathed it in acetone, stripped off all the paint, spot blasted the weld area with the sand blaster then bathed it in acetone again. Then dried it with the heat gun. Luck seemed to be with me and I managed to get a puddle going without it turning to a pile of slag. The weld on the left didn't obviously leak, but it had a suspicious looking dot, so I remelted it just in case. Forgive the welding, I am still a tig novice. This fix is probably only the 3rd time I've welded aluminium. The engine bay part of the loom wrapping is basically done, I used that expanding sleeve stuff. I wouldn't say I'm ecstatic with the result, but I suppose it's acceptable. I also sorted out the wiring for the alternator so the charging circuit works now.
- 188 replies
- 15
I must get some stainless rod and try this! I assume that unless you are welding safety critical parts for NDT, it won't matter using a bit of stainless?
I got my tig stuff from these guys, just because it's all online. https://www.prolineindustrial.co.nz/cat/welding-equipment/tig-welding/tig-filler-wires I am still a novice, but I used 1.6mm for my mild steel exhaust. It went okay, you have to be really crazy with cleaning the weld area, any trace of oil or dirt and the weld fills with bubbles then you have to grind out and start again.
Lubricating the hose under the clamp with silicone spray so they don't pinch when tightening appears to have fixed the leaks. Now I'm trying to identify the cause of an oil leak at the adapter plate for the remote mount oil filter. I'm hoping it's just the figure 8 o-ring that needs replacing, not a pin hole in the weld.
Internet has suggested a lubricant between the silicone hose and the clamp allowing it to slip and not pinch the hose. I'll try that before I abandon $60 of clamps.
Damn, I got the cool looking clamps because there were going to be so many of them and right in your face. I did put a bead on the aluminium tube, using the modified vice grip method. Maybe it will help if I move the clamp right on top of the bead, rather than beside it?
Pieced together the radiator pipes. SO. MANY. CLAMPS! It was actually slightly cheaper this way than buying some random rubber pipes with the right bends and cutting them up. It was still far more than I was expecting. I have cranked the clamps up as tight as I can but I still have leaks when the engine warms up. A bunch of leaks. It seems to be sealing okay at the engine and radiator connections. I'm thinking that since the joints where it is leaking are almost never going to need taking apart, I'll squirt some silicone sealer between the pipe and hose, then put the clamps on again.
- 188 replies
In theory, yes. But I don't think it's advised because the mounts are single shear when most pivoting alternators are double shear. In my scenario, I don't have the clearance to move it anywhere. Some people make a bracket to mount an adjustable idler pulley. But this "stretch fit" belt is by far the easiest option. I just don't want to find that it is possible to be too tight and damage the alternator bearing. I tried looking up multi-v belt tension specs, but they required specialist measuring tools.
Can a 5 rib poly-v belt be too tight and damage the alternator bearings or something? Or are the bearings stronger than the belt? I am running an alternator only setup on my 1UZFE, so there is no tensioner. An internet person recommended a gates stretch-fit belt of a particular size that fits. I looked up the special tool used to install the stretch-fit belts then made do with random stuff that was the appropriate shape. I got the belt on, but it's pretty dang tight. Should I be concerned for my alternator?
Pretty sure I read somewhere that Aeroflow recommend clamps on their pushlock fittings if it's over X degrees hotness. EDIT: LOL just noticed I have basically just said the same as Cletus
Is this stuff all good for EFI hose? It does say unleaded gasoline and 290PSI, so I'm thinking 'Yes'... https://aeroflowperformance.com/af500-08-3mblk-8-1-2-black-push-lock-hose
There were indeed two sticky injectors. I ran the injector test again, and two of them were real quiet. I tapped them with the socket extension a bit and they freed up. So now it runs way better. I took a video of me fumbling with the ignition one handed to start it and make vrooming noises. I also installed the 'rest' of the exhaust, so now it reaches about halfway down the gearbox. https://youtu.be/K9sr3xajSOE I thought about using the original copper radiator, but when I had a better look, I found that the fins were disintegrating. So I've ordered a radiator from Fenix. Ouch, my wallet. After lots of looking at radiators for specific cars and having no luck, it turns out their universal medium radiator is within 5mm of the oem radiator. It also has the same type of mounting flange down the sides, I just need to trim it and drill the holes, then I can use the factory mounts.
- 188 replies
Thanks, it feels like I passed a milestone. I should probably move on to wrapping the loom with the expanding mesh sleeve stuff I bought yonks ago.
I revisited some of CarTuneNZ's videos. Extremely fortunately for me, he has a series of videos on wiring and configuring the ECU for exactly my setup. The issue was the base timing, it needs to be changed for the COP setup. I also hadn't configured the idle control So now it runs! Quite loud because it's only got headers. I can't really run it till it warm because I've got no cooling system. It sounds like it's running a bit rough. Maybe some of the injectors are sticky? It has been sitting for several years...
- 188 replies
Sayf Tea No leaks. Didn't die. No fire. Didn't want to start though. It would just do a random cough every 2 or 3 seconds. I assume it should run, the tune is from Sheepers 1UZ when it was still standard. All I've done is modify the config for COP. I guess it's the timing??? Maybe... But I don't have a timing light. I didn't leave the fuel in the bowl.
- 188 replies
