Everything posted by slacker.cam
It's a bit of a catch 22 regarding big bikes IMO. If everyone shows up on big bikes aside from a small handful then yeah, likely that's going to effect the spirit of the event. But, if it's a couple of lads who are on larger bikes because they wouldn't be there otherwise then I say 100% just come. The more guys there to have fun the better.
Te Urewera Undertaking, 2019 Nov 29th, 30th, Dec 1st.
slacker.cam replied to johnnyfive's topic in Upper North Island Region
We have 3 spare beds at waikaremoana due to a couple of drop outs. Send me a PM if you'd like one. $25 -
100% in on this. I just booked 2x 5 bunk rooms at Waikaremoana and currently there are a couple of beds free. $25/night. Cam Glen Neal Sentra Dave Peter Glens Brother Ned (probably maybe) Evan (probably maybe) Sparky Free Holla at me if you're keen to grab a bed. -
I've crossed off most of the major mechanical jobs on my bike. New seat thanks to @64valiant and new stickers thanks to @Archetype. Got another 130km under my belt over the last couple of days too. Learning something new each time I get out for a ride - mega windy yesterday and raining on the way to work this morning. Now I have to throw together a luggage system and pack my gear, spares and tools. -
Here you go -
Yeah it crusies nicely in top gear up gentle hills and pulls past the CVT scooters up steeper hills no problems. Top speed was downhill yesterday at 90something. The top end is getting a bit long in the tooth so I haven't pushed for Vmax on the flat. Yesterday was only the second time ever for me riding a bike with a clutch/gearbox. -
Sweet prep ride yesterday aside from a minor excursion into a ditch for me while riding on gravel. My A100 seems to get really good economy. 3L for 91km of riding. Choice.- 1724 replies
+1 for the two stroke club. My bike got delivered from Nelson yesterday so now I can make a start on preparation. First up is putting some miles on it and sorting some better storage than the crappy rack it has at the moment. I sense an engine rebuild coming on. -
I get about the same in my 4AGE. Oil temp consistently (slowly) rises throughout an 8 lap race up to a maximum of about 120C. I run a Mocal cooler also.
Mount your IR camera in the engine bay and do some laps? There are only 2 logical options right? - Fan is sucking air hotter than the oil temp and is turning it into an oil heater - Temp probes are not reading the true oil temp - Aliens/magnets I think putting a temp probe in the incoming air stream is a good idea.
Sounds like you need to add two more temp sensors to measure the air temperature before and after the cooler haha
Was your oil cooler fan on or off over the period shown on the graph?
Yeah my BT has had 3 old pulleys on it and they all rattle. Some worse than others. Definitely still a problem with the BT heads.
What oil and water temps are you seeing at the moment during a track session? I'm curious to see what they look like over a series of 100% laps. On my car I have huge issues with getting the heat out of the oil even with a decent Setrab cooler, but my China radiator easily keeps water temps in check. I don't run an oil thermostat and rely on warming the engine up before heading to the dummy grid to get some initial heat in the oil. Not ok on a car that still gets driven on the road but it seems to work for me. Have you done any calculations on how much thermal mass you want to shift out of the oil via the cooler? Do you need a big mother of a fan or will something small suffice?
It's 5/16" steel bundy tube
It doesn't even have to be cool stuff. Just do stuff. Learn new things and try things out. When things don't go your way don't let it get you so down either. Look at Denham, he failed his WOF the other day on a massive list of things he didn't know how to fix but he owned that shit and got on with it. Two days later and he's nearly got it sussed. Some help from the OS family and some hard work is all it took. And he's learnt something new! Another good example is Azzuros Fiat. He has done SOOOOO much work on that car and has gone backwards so many times but that's cool. He shares it with us and we like it because he's taking us along for the ride. I love reading his project updates.
You should read this Ed. http://waitbutwhy.com/2013/09/why-generation-y-yuppies-are-unhappy.html
I can't wait to see what this does when you head back to the dyno! What's your goto tool for cutting sheet ali?
Yeah for sure. They are coils with built in ignitors and this can be an issue but in this case the issue happens at the start of cranking, not at key on. I helped Pete to wire the EFI gear and I can't remember if we have the coils always on with the ignition or switched using the FP relay signal. Probably off the FP relay as that's how I normally like to do it. In that case the trigger lines are already at 5V when cranking begins but I wonder if there is an issue where the coils fire unexpectedly when you power them on even if the trigger line is pulled high. It's an easy test which is nice. Just temporarily replace the relay with a wire link and see if that fixes it.
Play with cranking ignition timing first and foremost. I never noticed any loss of sync when we first set it up but it may have developed an issue I guess. MS (as with pretty much all ECUs) fires a priming pulse at power on to make starting easier. You may want to decrease the priming pulse width to see if that has any effect too. Tom, unsure why you say MS fires the coils at key on but it shouldn't be doing that. Have you seen that happen on your Fiat?
You won't want to run a rising rate FPR with the standard ECU. You need a 1:1 ratio regulator.
You can go way more lean during low load cruise. 15-16 sort of range.
I'm sure that reducing the arming voltage will solve your problems, the zero crossing is still in the correct place. So long as you have good wiring (and low noise) then it will work with a very low arming voltage. I have noticed that the voltage produced by VR sensors is quite dependent on temperature also. Lower temps mean lower voltage produced so if you set it near the current minimum just beware that you may need to change it in winter time. What MAP sensor did you end up using?
slacker.cam replied to Roman's topic in Tech Talk
Ansys will be way better than the SW CFD module (like using sketchup vs SW for solid modelling) but it can be done. You should note that you're going straight to the big leagues with running CFD on intake manifolds. A project on optimising an intake manifold with CFD would easily be a year long project for a 4th year engineering student.
