Everything posted by 63Ragtop
Still going. After being a daily driver for the last three years, the clutch had reaaalllly had enough, I adjusted it one more time, and it was working sweet. I drove over to qualitat to grab a couple last parts, thought I'd pop in and see a mate at his work down the road, pulled up a couple blocks away and bang. No more clutch cable. Old mate helped me push it inside, dropped me off home, picked me up in the morning, took me back over to qualitat, and helped me sort the cable. Good cunt. Guess I had it cranked the cable a bit much and stressed it out. Anyway four hours later, I got the little loop on the little hook. Fuck.
Another thing I've never gotten around to is polishing the paint. After I smashed the front fender I had intended on doing it after painting. After sitting out in the sun all day at work for the last couple years the paint was pretty rinsed. Spent a couple evenings worth of elbow grease, paint is actually cracking in places. Wish I'd done it years ago, but whatever, looked so nice after a shower of rain, water all beading off.
- 254 replies
The other thing that likes to die is the wiper motor. It works fine until you really need them, like a thunderstorm in heavy Auckland traffic. Then they cook themselves and fuck out. Opening the motor for possible the first time in sixty years reveled grease with the texture of smashed prunes.
Hello oldschool. The bug got a new wof a couple months back. Just needed new front tyres and the front bearings adjusted to pass. Was looking pretty hard for a wider tyre as technically the 145s are too small for the 5.5in wheels. No 155s or 165s in the profile in wanted, to chicken it try a 175, so bought another set of 145/65/15r. Balanced and aligned together with the sorted front bearings and the high speed shakes have greatly reduced. Drives really nice now. Except for the slow death of my clutch.
- 254 replies
- 16
Looks better on those ryms.
Least it wasn't the back one.
Amazing as usual man, so cool to watch your work.
63Ragtop replied to h4nd's topic in Other Projects
Needs to be painted red. -
Thanks, had stainless allen head bolts, which rusted. Only had to drill one out. -
Bought this cheap outdoor furniture at the red shed several years ago. Thought the kids would have stuck their feet through the plastic basket stuff by now. But it still looks mint! The frame however must have been made from old vws and morris minors. Most people would chuck it away, but I'm making a stand on single use furniture. They all weirdly had rusted out in the same spot, so chop chop, zap zap, grindy grindy, and... Done. Still need to do the two seater.- 1282 replies
- 24
Made some Xmas presents for my family. Old man is dutch and this is our surname, learned a few new tricks on the esko cad machine. Dad was chuffed.- 1282 replies
- 254 replies
- 17
Had a play with the sunroof the other night, things been a bitch to open and close since the resto, put some of it down to not having a headliner to help pull the second bow forward, but it also a dickhole going the other way. Had a good look and tried the second set of hole in the end of the wheel holder thing. Much better! Why the fuck hans drilled the second set I do not know. The only other instructions I've been able to find say bend the outer runner to fit? Was never sure how. After some careful prodding with a screwdriver and little progress, I found the use of the round hole in the runner. The two small rollers inside need to be even so the bow moves smoothly, by putting a screwdriver in the hole in the opposite side you can easily and gently bend the steel to just the right tension. Clever hans. These are castor shims, and longer beam bolts. These improve the road manners of a lowered vw at highway speeds. I already had a set installed but on very low cars, another is needed. As the shims space the bottom beam away from the pan longer bolts are required. Managed to install them without dropping the beam out. Easily the best 40-50 bucks I've ever spent on the car, it will sit on 60-70mph, one hand on the wheel, relax. Before you needed to keep your wits about you as it was very twitchy and unsettled. Now, just need to sort the vibration at and after 70mph, the deafening noise and smell of hot engine fumes and we're sweet. An't she cute dough?
- 254 replies
- 21
Please be careful yo, a friend of mine died rolling a paddock hack just like that.
Yeah, I'm gonna blame the different welder and materials for that, and the massive gap I had to bridge. Also helps to turn the gas back on ! Haha.
Had a busy week with the bug, changing gears was be coming rather hit and miss, by Wednesday I was having to start it in gear if I wanted to use reverse. One thing I'd meant to do during the rebuild was to replace the plastic bushing that holds the shifter rod in place inside the tunnel. I even bought the part, but, meh I had a whole car to build and it worked okay before, also it's a cunt of a job. The problem is to change the bush you need to completely remove the three foot long shifter rod. And this is the only access. You gotta take the spare tyre out, the front bumper, two access plates and as it turns out both front beam adjustment bolts, and poke the shifter rod out the front. Fuck me. Old thing new thing. Didn't end up taking to long, an hour or so. Gears still fucked, adjust clutch. Ah, much better. these two things have made the car so much nicer to drive it has reinvigorated my enthusiasm for the car. So on Friday I cut the muffler off. Old shit. New shit. Some shit welding and a lick of paint. And a short five hours later. Tried to kick The tail up at the end. Sounds so good, very happy with it, I'd had the old one nearly twenty years so not bad. Makes prober vroom vroom sounds now! Also cut a hole out of a large trapezoid of mdf. For the jbl to sit in, speaker only just fits. Sub doesn't have the same punch of the when it was in the box, bit more boomie, but heaps of volume and is fine with a few twiddles of the eq. Was going to cover it but it's fun watching it move in the rear view mirror.  Random photo of small mount on can I had to jigger. Note self clearance flange.
- 254 replies
So on the vw started making a weird fluttering sound. I checked the basic things like oil and removed the fan belt to see if the fan was rubbing on the housing. Guessing it was a massive exhaust leak I finally admitted that I'll never have a working heater system, I went and bought these. Which replace these old shitters. Volkswagen heater boxes, which are air heat exchangers, the hot exhaust goes in those ports at the back, turn 180 under the heads and connects to rest of the system, whilst the engine fan pumps cold fresh air (hahahah) though the large holes over the alloy fins that incase the exhaust and into the cabin. Fair to say these things have done their dash and weigh about 5kgs each. Now factory vws have these annoying slip joints were the heater boxes attach to the muffler. As mine a bit low and the aftermarket exhaust flange is the first thing that hits the road pulling into a driveway (which can be seen in the last pic of the last post) it would crack the seal and would start leaking again. So I was able to reuse the flanges off the boxes and weld them in place thanks to my brother in law's weld as mine decided to die. Ugly welds but strong. So much better using gas! I told what I was doing and mentioned that the muffler was also on its last legs and he pulls this out from under his house. The openings are a little bigger as it's off his V8 prem, but the can looks to be exactly the same size as the bugpack muffler I have tucked up under the bugs fender. Next project sorted. Here is are J pipes in place. Please ignore the oil slick under the engine. So after fucking around all day, I start it up and bugger me if it was still making the fluttering sound! Me and Darrel spent a couple beers trying to suss what was making the noise, getting pretty gassed in the process, carbs need a tune, running very rich. So I go down the road to turn around, give it the old italian tune-up, and waa hey, problem solved! Still not sure what it was but I'll take the win.
- 254 replies
- 15
Lord Gruntfuttock's 1971 XY Fairmont Big Grunty Discussion
63Ragtop replied to morkster's topic in Project Discussion
Well done Lordy, bet that beer was sweet! -
63Ragtop replied to yoeddynz's topic in Other Projects
Dude. I think you two might have a problem! -
Well, after a small break over winter, I got a new wof for summer Feels good to be back on the road, been thinking about the subwoofer, I bought that box with the shitty lightning audio 12 inch, for 10bucks at the dump shop, It's super well built, better than the cheap repco ones and a lot better what I could build. The old sub is stuffed but I have always wanted some doffdoff! I have own this JBL12 for nearly 20 years! But the old vw genny has never had enough juice to run one. Time to see if this thing still works! Bridged the mighty 222watts and stuck it on the back seat for now. Gets ya right in the kidneys. Fuck yeah.
- 254 replies
- 18
This, looks like fun.
Finished this bench to sit over the ugly whiteware and provide some extra bench space. I started it last lockdown, so I'm glad to finish it! Except for the screws to hold the ply on its all recycled materials. Sanded the old ply down and coated in boiled linseed oil. Silky smooth. And black zinc it for the frame. Turned out better than I expected, the plan was to mount a bench grinder to it but the wife thinks it's nice enough to be extra outdoor furniture!- 1282 replies
- 19
That factory Bright Green they came in? Was hoping this new project would show up here soon! Keep the updates coming!
No problem. I nicked it off someone else on the internet. -
Cut up my first failed version of the switch plate today and turned it into a chuck key holder. Ye olde drill press had this weird half brass screw already, so I made use of it.- 1282 replies
