Everything posted by Alfasprinter
Alfasprinter replied to Hyperblade's topic in Project Discussion
whats the make/model of tablet you use? looking for a good dash for my racecar. Awesome car looks like a bunch of fun! -
definatly black bumpers mate, ive got a v14 linkplus if your interested? has flat shift, launch control and all that jazz
there was one nicked from outside my mates house in the hutt last week too, keeping mine locked up hundy at the moment.
that sud came into my old work 2+ years ago had been sitting by the sea for a while, lady who owned at had no idea, real shame not many left now =(
just finished working on a racecar one of these, nice as cars, deceptivly tiny! ill put up some pics if your keen? the owner also has the matt black slammed one but its now red/restored
yo, im putting an old linkplus onto my alfa which factory runs bosch motoronic (same as bmw etc) i want to keep factory loom so need to make an adaptor board or similar, whos keen to build me one? will hook up cash/beers/swap for mechanical work on your car let me know!
Toyota 1KZ-T Engines Electronic vs manual Injector pumps?
Alfasprinter replied to Seedy Al's topic in Tech Talk
$50 for the bellhousing grab it when u pick up oldnathans gearbox from me -
Hi all ive just wired up a linkplus v14 into my racecar with its new motor, trying to tie up the loose ends/wires. it says it runs a low level tacho of the tacho output, i hav an autometer tacho in it now which i ran with the old engine with a single coil and dizzy, now it has subaru coilpack running wasted spark so i cant just run of coil negative. how do people get around this or where can i buy a low level tacho? Cheers
crank angle sensor
KY and Lowlancer- when i was building it all the other ones were red so i thought id do something a bit different. and when i was 4 my dad had one the same in yellow and it was the coolest thing around when you 4. Testament- next post is gonna be suspension and brakes, they are pretty trick. just gotta get some pics of it. TDS- yup all the same car, dodgy drag queen outfit was a piss take of a very dodgy may madness a while ago haha. it got removed after a couple of seasons because it was deemed too offensive by one of the race organisers haha
a guy i know whos putting a 3.0 alfa v6 in the back of a alfasud like mine, all he did was remove the cage and balls form the original fwd cvs and machined most of the meat off the sides of the cv thats not needed anymore. You need this part because it holds the wheel bearing together and stops the hub flying off when the wheel bearing collapses, ive seen this happen haha
so when the car was back from being caged i sent it away to a family friend to paint, along with my acid dipped gaurds, bonnet and doors. when i got it back my eyes hurt for a while, its a very bright yellow! i got it back and pretty quickly it went back together, made lexan windows all round except the windscreen, new door panelling, modified the steel dash by cutting the bottom half of it off, and rewired the whole car. at this point all it needed was running gear. So i dismantled the supposedly "rebuilt" engine to check it over and found it was pretty well fucked and needed new rings, a hone, new big ends, gudgeon bushes,main bearings and thrust washers. all 8 exhaust valve guides were well over their limit too so these were replaced. i got the engine back and re assembeld it myself to the point where i had to fit the oil pump, which also drives the dizzy. The original gears in it were so worn that they had to be replaced, problem was no new parts are available for these oil pumps and new pumps are also no longer available. so i spent around 5 months searching all over the world to find a new pump, nobody had one at any price. so i ended up pulling a second hand pump out of very late 8v 1.7 ie 33 which has the same high flow oil pump as the 16vs. and getting that as good as i could get it with out making new gears. it still wasnt the best but i wanted the car to go. as luck would have it a brand new pump that had only done 10 laps of taupo came up for sale at a rediculusly cheap price, so thats sitting on the shelf waiting to be fitted. The motor was then fully assembeld and fitted to the car And started after i replaced the seized fuel pump. Gearbox is the oringinal Sprint veloce close ratio box with 3.9 FD which was rebuilt not long before i bought the car.
while the car was away being caged (told the guy i wasnt in a hurry) i got offered this through the AROCNZ and who was i to refuse 1200 for a car that was selling for 3-4k at the time, problem was rust so i fixed the rust and got a wof and reg and drove it for 3 months then this happened.. Which made the descision pretty easy, instead of the hot 125hp 1500cc motor i planned to put in it, id take the engine, loom, factory quad throttles etc out of the 33 and fit it to the sprint and have a cheap and easy 140hp, so i did
^ i should have got a pic of the car in its DRGRCR livery haha
everybody knows Olly Yip ill be at Hampton downs for the centenery all going well, im doing serious upgrades on it at the moment. Need to do a clutch in my daily 16v 33 so my dad can take that up aswell, and build a new exhaust for my mums s1qv racecar so she can take that..... Yes my family is well and truly bitten by the bug
found some more pics from before it was caged and then it came back. full cage through to front strut towers, door bars, extra bracing etc
so it was a bit tatty when i got it as you can see, so i started fixing the minor rust which i soon found was major rust, 15mm thick bog covering newspaper filled sills. these rust out big time because the rear window drains block, and overflow into the sill cavitys. so me and my old man cut out all the rust and plated it all up. then we stripped the rest of the car to see what other rust we could find, and we found plenty more, rear of the roof, rear quaters behind wheels, around windscreen... the list goes on, so that all got fixed and we flipped it onto its side. we stripped the underseal for lightness and suprisingly the floors were mint so we painted it up and sent it away to get caged
no unluckily, just missed out on that. has the exhaust, wheels and some other small bits. had the springs but they are all gone now. Tonys motor went into Ollys car and promptly melted a piston through an air lock in the block apparently, Heads and stuf are still on it but its back down at 1712cc instead of the 18-1900 tony had it at, still does 20s or something at manfeild
oh mean. So youll know Tony too? this has heaps of the bits out of his car before it got put back to 8v and sold to Ray
if your talking bout the same Craig, he should get his 33 going it been to long
Thought it was about time i made a thread for my last project, now that it pretty much done haha. Bought this when i was 14 as something to get my licence in, but kind of got carried away and after going to a trackday at manfeild it became a out and out track car. this is it when i got it ill upload shots of whats been done when i get them onto computer
Helicoil my head please - Wgtn
Alfasprinter replied to thegreatestben's topic in Lower North Island Region
dont they teach you this at tec Ben? -
the v8 dolly race car is owned by a guy down in welly called Nigel Flemming, fucken badass car. i can probly get his number for you if you want?
yea its been pillaged pretty hard
