Everything posted by xsspeed
Out of interest what is the sw20 rad WxL? I will likely V mount IC and rad in z31 whenever i get to spend more time on it (heeding the advice above of just get it running again of course)
^got a point, either rad mounted up right would certainly get it fired up and revving in garage to 10krpm
wondering if you do that then you could form up a reasonable sheetmetal cowl to direct/force air in the right spot if needed/get some air in from underneath
So massive then
Do you have room to angle rad fwd (move bottom edge rear wards)
because i'd love to put a p12 sr20ve and box into a p10 (one day) did this change lengths the shafts or just for compatibility at either end?
im keen to see what you do here re half shafts, its the bane of fwd engine/gearbox swaps unless you have a lego parts bin. I seem to recall something about a splice to be welded but was ages ago i looked and outside my skill level/found some lego instead. You can also employ this when you put the sr20ve 20v with sr16ve gearbox in your k11 if nissan lego doesnt work
5 wings is a lot of downforce phil
lol sheepers spends 5 mins in south auckland...
Rhyscar's Subaru Type RA of teenage dreams... where less is more
xsspeed replied to Rhyscar's topic in Other Projects
is that one of the maximas with the keypad entry on the door handle? (think it was them) i remember that being mind blowing at the time -
@Snoozin shared this with me for some fabric options to refurb https://retroautotek.com.au/product-category/fabrics/recarofabrics/
Damn that's the same fabric as in my z31 recaros that I need to get redone, didn't appreciate it would be common
HumberSS's Datsun 240c coupe of irrationality yarns
xsspeed replied to HumberSS's topic in Project Discussion
Get registered on buyee.jp i find its the easier way to search and buy thing from yahoo Japan auctions Also kiss goodbye to your play money -
Whats the welding you guys were doing to front of tray? Just repairs or something more drastic (shortening?)
lold
Phil?
id guess at fire wall stampings being fine, so long as you have japan dereg cert at least alternator charging circuit will only be mild fuckery on these mega jealous, was one of the dream cars growing up, look forward to seeing more of it
SUGGESTIONS/RECOMMENDATIONS FOR VIVA CONVERSION
xsspeed replied to La Viva 71's topic in Project Discussion
/rfb twenny debt -
Not just barra, turbo barra -
(I'm no expert but) why do you think you actually need more pressure? i thought the lifters just take out the slack so it was purely down to differential pressure being enough to keep the slack out of this system (without getting to pump up scenario) Or are you thinking existing pressure would be too low to keep lifters 'slackless' as a result of new cam/rpm or something?
Also, you sicko, but you already knew that, a+
I remember when fuel told me these had transverse engines (iirc) and for some reason that blew my mind in a wtf kind of way cos always assumed they were rwd based on 'the look' and supra/300zx vibes
Good cunts
