Everything posted by HighLUX
Il get a couple of pics next time im at the ute showing what I have to work with. Its a bit of a tricky one as cutting out radiator support cuts most of the front panel of the body. Im limited by height because of the chassis in the way under the body the bonnet at the top and headlight supports at the sides. Going to a non electro clutch on the SC would get me alot more space but how am I supposed to have a GO BABY GO button the top of the gearstick if I loose that
Option A is a no because its not a trophy truck Option B is the next best option but still dubious of cooling capacity, I want to do skids without it turning into a kettle instantly
So yeah scratch that idea for a FC radiator working. Got the motor sitting as far back as possible and iv only got 40ish mm between the front of the 1G supercharger clutch and the the front panel of the engine bay. Lots of room for a radiator but its got to fit the drivers side of the engine bay
What sorta radiator does the 1G starlet run as this is for a 1G
Would a 13b turbo rx7 radiator be sufficient for cooling a boosted 2L engine. I'm limited for space with my engine swap but a 3 core alloy FC radiator looks like it will fit in my limited area and I know dorito motors like to run hot
Jamies 86 Hilux Sr5 bargain basment build with added boat anchor
HighLUX replied to HighLUX's topic in Projects and Build Ups
Productive day at the Powershed Got the modified sump and pickup onto the GZE, installed spigot bearing flywheel and clutch to engine and offered it up to the engine hole Much fucking around ensued because of the loooongboi crank pulley and SC clutch on the GZE making a small engine rather long so pressure plate and clutch off the engine slide the gearbag back as much as possible rotate the engine 45 degrees in the engine bay while tipping it to precarious angles then scrape swear and twist til its in there Gearbag tunnel needs a slight massage to fit one of the heater hardline/mod the hardline as the engine is sitting not quite center and on a slight angle as the photos show This is minimum clearance on the draglink for steering which I hope is certable @cletus AAAAND I have minimal room for a radiator thanks to looooongboi pulleys but I will get the engine in its final position before measuring where how much room there is to play with. The bonnet closes still which is nice but I dont wanna have to deal with putting wheelbarrow in the firewall as tunnel notch with all the bullshit of having to move everything back shorten the Dshaft etc- 58 replies
- 22
Kimjon's next money pit - BMW Airhead cafe racer build
HighLUX replied to Kimjon's topic in Two Wheels
Those grom ripoff dashes are surprisingly functional for how cheap they are. Bit of a diddle to calibrate them but do the job nicely once you get it sorted -
A 3Y filter housing looks similar to a K series. I wonder if it would have bigger oil galleries
Got it loaded on the trailer and trucked off to @MaxPowers shed this arvo. Even gave it a bath at washworld on the way to get rid of 10 years of barnfind smeg- 58 replies
- 23
Can you measure the spacing of the block engine mount studs/bolt holes for me plz @Roman
Spin the coil 180 degrees so the lead is on the trailing side and pack the plug boot with grease. Its ghetto but it works
Keen to see this offered up to the hiace engine hole and see how well its going to fit
Eastcapescapade #6 2022 November 11th, 12th, 13th
HighLUX replied to johnnyfive's topic in Upper North Island Region
Sheeeit What roads that? -
Looking like a barn find but atleast the sheds tidy. Found all the bits I need for the engine swap and its ready to get trailered off the fab mans house- 58 replies
- 26
And to answer the first question, its probably already full of oil since I splash some down the plug holes when I turn it over. Iv found a guy with skills and tools who likes to be fed PGs in return for fab services
Itl be with me on the train next time im heading to ktown during the week and il run it up to ya at work
Do you want your guard roller back? I found it today while doing some tidying up
Haha 6 years of nothing except putting the reg on hold and turning the motor over by hand every so often but plans are afoot so watch this space- 58 replies
- 23
Whats the go with the JZ intake swap are they lego spec or is a bit of fettling required?
4V Century V8 powered Dyna Camper Discussion
HighLUX replied to HumberSS's topic in Project Discussion
The dash sounds like something @h4nd would know the ins and outs of
Pics no work G
Yeah I was expecting that/want to get it hot to really bake the paint on
I wanna give my fireplace a tart up, im guessing the current coating is baked on enamel or powder coating? Whats the best way prep it before repainting with Hi temp enamel? Its only the outside panels not the firebox itself so getting hot but not direct heat hot
