Everything posted by KKtrips
Thats class LE - a trike.
QUIT
Rules were made to be broken? I would only obey it if there was a fire ban. https://www.checkitsalright.nz/can-i-light-a-fire/campfires/@175.62021000000004,-39.91824999999994/2024-02-03
Roll in whenever you are ready, I don't think there are specific nights set aside for Allan. If there is, then park in the corner and you can watch him from afar.
You can also combine the accounts. (or I can)
I spy a Bizzo wag that is not a Mazda Tre Dos Tre with a Rota Rae. DAMN IT
I dunno, I just keep a lifetime supply on hand at all times.
Hey @Bistro, should I bring protection or are we gunna rawdog this shit?
Based on the cleanliness of Seedys cow costume and the fullness of the bottle of Grinters liquor, this is the first evening of a Wagnats.
I got a bunch at home. Perhaps start a coffee table book thread for pictures?
Looks like the hose needs to be rotated 1/4 of a turn anticlockwise (on the square), are the hoses routed correctly? Are they the correct hoses for the vehicle? You don't want to be taking any meat off the calliper, it could be tricky to prove that it has not affected the stength of the calliper, even though a finger in the air test says it will be fine, I wouldn't.
See Note 4 (or 5, I can't remember which - I looked at it earlier today), I have a stick on plate on the front of my Prius and I will be using that as an out if I get poked by my WoF inspector.
I would love it, but nah, I'm also decluttering at the moment.
They have to have an ADR compliant label on the bullbar.
A dealer would only sell factory bulbars etc which will be airbag compliant.
NZTA and sensible are mutually exclusive.
- 8973 replies
- 15
In my opinion, vehicles once they reach a certain age should be able to have all the driver assist, ABS, airbags etc removed, just because getting parts for them if they go bung will be impossible. But it probably needs to be longer than 14 years, cos my Prius is nearly 14 years old and its just broken in.
- 8973 replies
I need to do a Facebook post on LVVTA page about he Bullbars thing but I put off doing it on a Friday because I wasn't mentally prepared for the pushback over the weekend.
Yes
Sweet, they definitely did not do them when I was looking a couple years ago. Crane did them but they were well over a thousand bucks just for the cam. I wrote this response before you posted above but it might be worth saying for others knowledge, if its a cam designed for a flat tappet and you use it with roller lifters, it will fuck the roller wheel, a flat tappet cam has a very slight side to side slope on the lobe to rotate a flat tappet lifter and a roller lifter on a flat tappet profile will mean all of the valve spring pressure will be concentrated on one side of the roller wheel. It might be OK, but I would be not wanting to risk it.
