Posts posted by Spencer
So just caught up on 10 pages of this shit. Where is the K11 slammed making dort noises?
- 6
How many holes have you started drilling in it?
- 6
I reckon a camera in there would be key to see if its engine harmonics or the belt/pulley setup harmonics causing the issue if that makes any sense.
Maybe you are in need one of the most misunderstood and popular internet shit fight topics the harmonic dampener front pulley.
Best project on oldschool
LSD is the only way with a light front tugs, will be all sorted after that.
- 6
It only took like 30 years to figure out the best 4AG combo with data haha. Turns out its a AE82 bigport of course
So basically run the A43L (or whatever the code is) if you can find it, the manual valve body with overdrive and lockup. Or if you want to step into the future (like 1991) then run a A340 which comes in many flavours and can be run by a aftermarket controller or even a mircosquirt etc now days.
Yes so a few versions of the electronics on those, the early more primitive version on early stuff (z10,x60 etc) is ghetto and using this big stepped TPS that outputs different levels to the controller. Then a more modern controller in the X70 stuff. The controller is separate from the ECU so could be standalone and if you dig hard enough you will find explanations on how in works and wiring diagrams in a mix of workshop manuals (used to always be a celica manual online etc). Have messed around with these in a attempt to use them as the cressida boxes were everywhere and the manual shift ones with overdrive were more rare. But never got that far as CBF rigging up a TPS etc.
Guess depends what paint you are wet spraying currently? I think in industry its the same as car tech, you go to two part epoxy primer and two part Urethane top coat (you can buy industrial versions of these paints from automotive places). Epoxy primer has the best adhesion and Urethane is flexible and UV resistant. Knew a dude whos whole gig was blasting and painting cranes using that process. Maybe I am off but that's what I have seen. Its the same paints for pretty much everything you want to last (2pac epoxy+urethane) factory floors, home garage floors, cars everything. Its currently the best paint tech for durability.
Its a old ECU on a lower spec car, newer ones have better systems to pick up a faulty sensor. A shitty O2 sensor also is a go for fuel usage on 4ages sometimes. You should be able to find a manual (they are bundled with the 4AG ones which exist on the net) and trouble shoot the various ECU things pretty easy, if you find a factory manual it will have some flow charts on what to check first for excessive fuel usage.
Hmm I have been in a couple 700r4's and they seem sweet as? just a 350 with a overdrive and cable control, buy the cable bracket kit for your carb set it up and off you go?
The move is probably a T400 and gear vendors overdrive box if you have the cash.
Amayama are buying/onselling off OEM's direct in their home countries. They are stuck with database updates from OEM's (who don't give a shit about old parts), I buy lots of Honda shit for the daily from them and the stock listings are mint always get what you want at 1/4 local prices.
OId mate rockauto controls the stock so they should have a tip top database.
Yup I would have a practice before doing it again on anything important. Usually it goes on pretty thick and the only thing that fucks it up is the cold/damp, anything below like 15 degrees will slow it down lots IMO. But 4 days is pretty extreme. In warm weather you should be able to sand that stuff on the same day and it should really always set hard in the pot overnight.
Yeah a few cam swaps I have messed with on bucket setups you bang them in and magically it all works out fine measurement wise. I don't know much about cams but I would guess that good aftermarket ones have base circles similar enough to stock that it stays in spec
Dunno are F1 ports dimpled? not the old ones you can see IRL. Paint/stickers were smooth also.
Im sure we will see the result on garage 4age soon, dimpled bigport owns smallports.
Strip disc and wire wheel time.
Some old paint seals up mint under epoxy primer (almost all old factory paint I have messed with is fine). If it’s real shit and reacting it probably needs to fuck off anyway. Start grinding
Yeah and after that you have to be some kind of race car engineer type to know about the flow through the ports and how that effects combustion chamber mixing and all that. In general though Yamaha tried and eneded up back at 4v per cyl with racing things probably for a reason.
A good blacktop 20v goes hard for what they are though etc.
Yes I have heard many a barry yarn that they need bigger valves, not sure but didn't think there is much room for that carry on.
Not many 80's auto hiaces around anymore. Best bet to just hit-up and call every wrecker in Australia that has old shit. All of them will have done 300,000km
Yeah what engine etc. Some will be harder to track down a bell-housing that others. People threw away the A43 etc autos like crazy but they are pretty good units, a overdrive and lockup version without computer control being the holy grail.
Yeah would be interesting, they went five stud for a reason. Not that the 4 stud setup would explode but its a step backward.
Just drop the 3k and get boss wheels the outcome will be way better.
You are not going to have a easy time finding bolt on hubs IMO. Paying the boss costs for new or used wheels from japan would be the simplest option.
You guys love doing things over and over huh, the fix is a $40 can of clear. Anything else is garbage and you will be doing it again. Nothing can hold out to UV and heat for this application like 2k urethane clear. Get a couple cans and a practice headlight if you are worried.
Someone in NZ will sell this stz. Has two chambers in the can.
Gloss Clear 2K Touch Up Paint Spray Solid DIY Automotive Top Coat 400ml | eBay
Nissan March (micra) K11 appreciation thread
in General Car Chat
Wheres the pics of one of these on axle stands with some 20v throttles mocked up never to be completed.
