Dell'orto
Everything posted by Dell'orto
  1. Bloody rotary owners, always selling shady crap haha. I guess lots of that can be put down to peoples skill level - what they think is ok often turns out to be subpar at best.
  2. Buy one, grenade, claim warranty, repeat?
  3. The torch section is a bunch bigger than the factory flare, so I think it's pushing it outward a bit? I did move it for the pic though so could just be that. I do have an OE flare if you're feeling brave!
  4. I got one of these from a compliance centre customer fages back, could likely get more if you wanted one?
  5. Is this going to be a case of buying a parts car that's too good to wreck so becomes a second project car?
  6. If its auto, it might be a dick to line up the torque converter when you reinstall it (unless you're taking the box out after?). If you've got big axle stands, they'll make your life way easier than ramps!
  7. I do love how much effort you put into a door handle! I'm expecting similar amounts of OCD in the engine itself too thanks
  8. Under 10v at the battery would suggest it's shagged. Follow piazzanoobs advice too, but most likely just wang a new battery in it.
  9. Nah owned it well before the days of cheap digital cameras, let alone cell phones, but honestly nearly identical exterior-wise. From super vague memory it had conventional door mounted mirrors though.
  10. The bigger Projecta ones are good, but the little 100a version is a waste of time
  11. Ooosh, looks heaps like my old one from back in the day, though mine was 12AT and manual. Super plush car for a mid 80s sedan!
  12. It's definitely time for a 12A j port 4AGE conversion then
  13. It's a fuck up and will explode If you do not do banana aided b-0wts ASAP
  14. I found AE111 BZG springs were a nice drop for my old 4afe Corolla, way nicer rate too. Also on the KYB excel g struts
  15. Super super super excited to see how you get on with this guy!
  16. The MX5 diff would splinter behind a 3S, NA6 diffs pop with the shitty B6, the NB ones aren't heaps better. Get an RX8 and pillage it, renesis and 6 speed would go OK in a light car. Rear end is probably a bit too wide though
  17. Whispy smoke from the engine bay is normal when you've been in there tinkering, grease and oil get transferred onto hot bits. Wouldn't be worried unless its plumes.
  18. Was just going to post this - had the exact issue on a friend's KP, that old fusible link stuff turns to garbage with age.
  19. A few months pass and I finally get a chance to get away from work so I can finally get this thing on the dyno. Naturally, there are a couple of minor last minute tidy up jobs we needed to do, so ended up working until about 1 am the day of the dyno to get it all dusted. Nothing like a bit of deadline pressure to get the adrenaline going! Anyway, after what seemed like an eternity of driving, we ended up at GDS Automotive and unloaded the car. It was quite cool having a chat to one of the former top import drag racers from back in the day and I pestered him with various questions about the GTRs that he was involved with way back when, until it was finally time to get tuning. It was all pretty uneventful, the car behaved the entire time - testament to the job Jon did in building it (and me for the component selection haha). I had a fairly lofty goal of 450hp at the wheels, which I figured we'd probably have to lean on the turbo to produce. So you can imagine my surprise when we went into the dyno cell for the second to last run and seeing 345kw flash up on 18 psi! Glenn gave it one last run with 19psi (the maximum boost pressure he felt comfortable with - stock seals and undowelled) and it put down 351kw/470hp at the wheels. Pretty fucking stoked as you'd expect, and it sounded super crisp on the dyno https://imgur.com/rdeTcTW I took it for a little drive once we got back to Jon's, and couldn't stop grinning the entire time - only a little shady given the car still wasn't complied for NZ roads by this stage, but whatever, it's only illegal if you get caught right? Did the last couple of engine bay tidy up bits (ie install the FEED manifold cover and polish the strut brace) then stood back and admired 18 year old me's dream car Did one final video to keep my enthusiasm up, then had to jump on the plane to head back home again....the last time I'd see the car for several months as it would turn out. https://imgur.com/dKj7OpA
  20. Petone Radiators do chemical cleaning on fuel tanks, weren't super spendy from memory. Drop it off, pick it up, zero fucking around with trying to get chain/nuts out again.
  21. Right, so a couple of months pass with little finicky wiring stuff being done, and the last of the fab work done. A big V mount set up wasn't in the budget, so Jon made new pipework to run from the GReddy elbow to the existing GReddy cooler, and welded an elbow to the turbo outlet to make a fairly short straight shot into the cooler. Now with the power figure I had in mind, a measly 3" exhaust would never do. So we made the call to go 4" the whole way - 3.5" outlet off the turbine housing necks up to 4" as quickly as it could physically fit It runs into a 4" Adrenalin R centre muffler, then back to the existing 4" section (Which actually turned out to be like 96mm, weird) with the Apexi muffler. https://imgur.com/0i3fcX6 Nice and tucked up, heaps of clearance! Now it was ready for the first start up https://imgur.com/h0DfDBE Naturally, it fired up super easily, even with the base tune on the Link. A little more fettling and it was time to hit the dyno!
  22. Yeah I think with how mental the prices have gone I'd probably break even if I were to sell it, which is insane. I'm sad that you never got to complete your highflow twin project with it, that would have been super interesting to see. My turbo encyclopedia friend is friends with Andre too, so have been keeping tabs on it. I still cry every time they put a new video up of it though
  23. Back to the story at hand - with the motor now ported, it left me with quite a dilemma. I bought this car with a specific budget to get it all done and dusted. I procrastinated for a few months while figuring out the next step. I even debated using the stock twins and the existing bolt on stuff, but deep down I knew that the stock turbos would just end up hurting the motor. One of my other good friends is a bit of a encyclopedia for turbo knowledge so I turned to him for advice. I was after something that could flow 400-450hp without giving away too much response. The ideal turbo would have been the Borg Warner EFR8374, but I couldn't afford a $4500 turbo. So the next best option was this guy: A Borg Warner S300SX-E, sorta the poor man's EFR8374. I chose a slighter smaller than usual 1.0 AR twin scroll turbine housing in an attempt to keep the boost threshold at a reasonable point, at the expense of some top end power. Given the most powerful car I've owned before was a 220kw turbo 4age, giving away some horsepower wasn't a real concern! I made another trip up to Auckland to dress the block up and install the motor - the turbo looks fucking huge compared to a bare bones 13B! And pretty snug in an FD engine bay too Because pedantry, I replaced most of the bolts on the motor, and engine bay, with shiny new gold passivated ones. I also splashed out and bought new coolant and washer fluid bottles, as the ones in the engine bay were all fucky. I also made the unusual (apparently) call to retain the stock OMP. Everybody says they fail yada yada yada, but I've not seen any concrete evidence that the electronic ones do. And also modern ECU tech can control them, so why the hell not? Modern ECU tech also means I ditched the Power FC once again, but this time replacing it with a Link G4 plug in It also meant a decent fuel system upgrade in the form of 1050cc primary injectors and 1550cc secondaries fed by one of the other wonders of modern tech, a brushless drop in fuel pump, capable of suppling well over 500hp worth of fuel. Thank god the days of Whinebro pumps are over! With this in the hole, only minor fabrication was needed to get it ready to fire up!
