Everything posted by Raizer
How many lines does it have? I'm spotting 4. In from tank, out to pump/rail, overflow back to tank and return from rail/fpr.
Normally return line from fuel pressure regulator.
Raizer replied to h4nd's topic in Other Projects
This one's about 50kg of steel and however much 2mx4m of 20mm wood weighs, decent heft to it but still rolls super easy and smooth. And yes, I was rather proud of my cocoa -
Looks like I make gates now as well as mow lawns and all the other shit I find myself doing ha Chur @Geophy for the steel hook up + delivery and advice etc!- 1282 replies
- 38
Eastcapescapade #6 2022 November 11th, 12th, 13th
Raizer replied to johnnyfive's topic in Upper North Island Region
- 435 replies
Also Kapuni plant, they cut production way back while doing upgrades to the plant but should be back in full production by now.
No, boc won't touch them. Strange that a big place like CHCH doesn't have any in stock anywhere while there's 4 places here in Gisborne with them ready to go including 2 places with the E size cylinders.
Yeah but they've been building crazy Prius motors in Thailand for ages so you should just give up.
I've got that one (and the bigger belt+disc sander they do), I've used the belt for tungsten a bit in the past and it worked fine, but I've now got a green silicon carbide wheel on it that I use only for tungstens.
Peugeot 307 and 407 (maybe not all versions) Think some Nissan's like the Cube have 120A too.
It's pretty typical for these. Was told to try tilting it/lifting the back right up for a few seconds before starting when cold, might be a Barry tale but it always seemed to work for mine.
Full forwards on the throttle lever, then pull it back a bit once running to turn off.
Remove the idle mixture screw and blast out the hole it was in with carb/brake cleaner, should spray out a hole in the front of the carb as well as internally, they get blocked up a lot and give hunting idle. Linkage doesn't directly control butterfly, I've had a couple that were either idle or max nang with nothing in between thanks to fucky governor. Manual: https://drive.google.com/file/d/1wRpU92lMIv2fV60NJvffIEXbKN9gMfy7/view?usp=drivesdk
I still rate my BOC highly, it's called a 200 but it's actually 210A. https://mytools.co.nz/products/boc-smootharc-tig-200-ac-dc?pr_prod_strat=collection_fallback&pr_rec_id=26b01ce58&pr_rec_pid=4459075469347&pr_ref_pid=4516669259811&pr_seq=uniform
Take your empty to them to get it refilled rather than swapped.
They do a weldskill 135 inverter now too For the money I'm very impressed with the BOC Raptor mig I got, it's a lot more capable than I am lol. https://mytools.co.nz/products/raptor-160-mig-welder-10amp Should have got the 180 though.
Bonus with Bunnings is if you ever run out of gas on a weekend etc they are open. Also $118 for a D with trade card, $126 retail. I was with BOC on the D plan ages back, but if you don't use your 2 full bottles in 12 months you've still got to pay the full year payment etc.
MIGgas from Bunnings/other Coregas supplier imo.
Jump it, only way to know for sure the pegs are up to the task. I'm sure @64valiant will video it for us.
Going by FB the box and most of the good bits were gone before lunch
