Posts posted by tortron
Bolt in for all the popular classics now anyways
They want about 45k squid for a sputter in - glide away conversion from what I understand
That's converting it to automatic with a reduction box. Some places are doing bolt to morrie gearbox adaptors.
The torque is a lot more so I don't think thats a good idea, and you would want a nicer ratio diff.
People ask. But is it the same power as the original? Can I drive it in traffic.
My man an A series is like 40hp, even a light duty motor option is making 100
35 minutes ago, nzstato said:
+1 for shrinking discs. You can buy em direct from the OG, Wray
https://www.proshaper.com/product-category/shrinking-disc/Yeah that's where I got mine. Better than an old pot lid for sure
Oh another thing I picked up from one of thesw videos was finding the point in the oil can that needs addressing. Using both hands you go around the area that pops in and out. At some point you will be able to press down on one spot and the rest won't want to pop any more
Can you get fine tip for lpg? For me at least an oxy act rig is a bit much admin
Also, practice on something else first. My ute was evidently the apprentice practice rig when it was built by the workshop judging from, well everything....
The roof had been shrunk with a torch, but they fucked it up, lost most of the crown, ended up just pushing it in and carving a new one out of bog
A disk is certainly fairly amateur friendly, it doesn't shrink too much in one go sort of thing
This was a good video
https://www.ebay.co.uk/itm/322311293881
Gwan get some mitsi parts
Probably available used as they are the only part that won't rust off
I have a set of shrinking disks, they are gold, did my rooted cab roof with them and got it near perfect.
A guide coat, then zing with the disk till you see the high bits. Spray with water in a spray bottle. Hammer up low spots. Repeat
Lost about 1 minute over a week, which is about as new for one of those, certainly pretty great now that it's 75 odd years old.
Suits me, Just roll it forwards a minute at church on a sunday
- 6
I did upsidedown lawnmower and dog hair transporter wingroad seats with a water blaster and thr carpet shampooer machine, then water blast till water ran clear. Big difference
11 minutes ago, kpr said:
That honda one may work if its steel like it says. is 6 rib but can zing the side off and weld it back on.
fd rx7 is actually smaller, 120mm so aftermarket under drive probably wont get me there, if its a thing.
Try this, it's also got some fitment of you wanted to measure up at a wrwcker
https://www.amazon.com/Dorman-300-337-Power-Steering-Pulley/dp/B01M3Q2XGF
You can also put part numbers into rockauto. Try this one too 12605677
One of those speedy Honda ones maybe
https://www.speedscience.co.nz/products/tegiwa-power-steering-pulley-dc5
You shoulda said
Get some megasmoke too
Ahh, so that's where they came up with the lectron
Enough of that nonsense (press the sleeve out of a GN and run the piston in that in the standard cylinder to maintain std head)
I went and picked up 2 engines tonight. One complete and supposedly running, although backfiring (has a China pod filter on it) and a second junker parts engine.
Guy had lots of other parts, but I refused, because putting decent parts on this is a slippery slope to a 100hrs paintjob
16 hours ago, ajg193 said:
"Because I'm not posh (or rich) enough to own a surface grinder I needed to make one. Yes its a bit basic but it will work. I made this. "
Ohman I could ruin so many Chinese suzuki parts with that
I think actually something like an lt185 has 1cm less cylinder height as well. I forget if it uses a Dr200 piston tho which has a bigger pin.
But no, I'm not doing that, I just happened to have that sitting on the shelf
McKenzie Moped Melee - March 2024
in South Island Region
THEY TURNED MY BOY INTO A BOX, A BOX GODDAM YOU
