Everything posted by tortron
Used a D shackle and a pin from a door hinge out of a 1930s bungalow. Will attach it with a bit of sink plug chain or something sonic doesn't get lost
Threw some brass and beeswax on the drawbar. Put some big brass screws through the 2 sections, I knew I was saving those for something. I think it looks suitably vintage
Will do some reshaping to the rimu drawbar once the glue sets, and make some kind of hook set up. I have an eye bolt mounted to the back of the trike. Also painted the tray, will probably rivet it on using the original brackets. Painted the white part just before it ruined heavily, so it's not very nice. Oops. Might line it with some wood or something nice rather than paint again
What colour code is the paint?
One dummy carb on each side. It's a street rod m9
tortron replied to yoeddynz's topic in Project Discussion
Wookies in the woods is the vr6 nats in the states
70 year old crossplys?
I got some pressed sheet metal ones off I think off summit racing a while back. Quite thick
gas-shielded flux-cored wires. https://www.thefabricator.com/thewelder/article/consumables/all-about-gas-shielded-flux-cored-arc-welding-wires
in new zealand it always needs to be licenced/rego paid to be on the road at 40 years it becomes "classic". this means a slight change to "continuous licencing" in that it takes a little longer for it to be come deregistered if you forget to put it on hold
Do they all break at the shoulder?
Silver solder if you are tour du frogs. THINK ABOUT THE GRAMS
If rego is still live you can just get a replacement plate Tick the box where it says handing 0 plates in, and reason - lost Was about 20bucks last time I got one
Latching relay might help?
Try adding some adblue to your fuel tank And then when insurance writes the car off, get something not french
Have seen this with vws with broken window switches. Just always have the laptop plugged in bro vw life
That's the shit house kiwi farm equipment spirit!
I'd imagine you would do a full under tray for hyper mileing I want to do one fory nissan (and catching drips) -
Old rubber lines swell up inside and act like a 1 way valve. I had this on the rear line on thr morrie, was letting the rears stuck on
