Everything posted by Nominal
For each set of white/blue/yellow (I assume they are bundled together), Then if you want a 30A fused fan switch relay (#2 as per pic although you could change the fuses) Connect the fan switch/temp switch to supply + 12V to the white wire of the bundle when you want the fan on, and the fan motor to the yellow wire of the bundle. Don't use the blue wire, just wrap the end with tape or something so you don't get a short. Does that make sense?
I presume this is still correct information Captive Springs via restrictive straps | LVVTA Forum (proboards.com)
I'm surprised by what these sold for on TM. Enough for a few weeks gas money anyway. Good thing I listed them on the 0 fees day.
I take my portable bottles to this place, not sure if they do car ones though Porirua Cylinder Testing Lab (pctl.co.nz)
Welding spacers on is OK in my experience. It only becomes an issue if there are welds in the main load path between the caliper and upright.
Also this Orchid VGA card. IIRC I bought it used from someone on TheCave BBS Should have kept an old modem, all that beeping and handshaking noise
- 182 replies
There is some crazy asking prices in that section of TM.
Would look good towed behind the Chev.
Seems expensive XcelGas Co2 Cylinder Adaptor to suit Argon Regulator XG-ARCO | Trade Me Marketplace
4V Century V8 powered Dyna Camper Discussion
Nominal replied to HumberSS's topic in Project Discussion
You know it's a long weekend, right? Nice work, good to see it coming together and the tricky issues get worked out. -
Short term car storage in Welly area
Nominal replied to vivaspeed's topic in Lower North Island Region
Have space here, mostly off road. Might even be a garage slot if you don't want to go over the hill. -
Well, I’m back in NZ so I’ll be there. -
Amayama eventually delivered a genuine RHS light, which included the sub-loom and bulb holders. Quite happy with that.
- 6081 replies
- 16
Dang, when I called at his work a few months ago he was in Surfers. What a globe-trotter. -
Might be close enough to get @AllTorque down from the hills? -
Just do away with the WOF. Better living for everyone.
Probably applies to LVVTA staff too.
He does actually have a wife
He has a wife?
