well not much to report, except the battery is probably dead. So im on the look out for a replacement orbital exide battery, or optima if it will mount up the same.
Big thanks to my right hand man (and occassionally left hand) Malcolm, we tested the fuel pressure last night with a 14psi gauge! doh!
Put the trusty oil pressure gauge on there and it seems there is a problem.
The walbro (was sold it as genuine) seems to be really loud and we are going to test it out of the car, bypassing the factory fuel lines.
Not sure what to do if the pump proves to be ok, i guess ill have to redo all the factory lines.
If the pump is knackered ill probably opt for a bosch unit.
Im so over it, i should just put a rotor in it.
Also, thanks to Kevin for the power steering reservior of non floppyness. much better.
and because updates are gay without pics.
