Hi 98, great work, can I ask if you are using bushes or bearings to support the cams in the crankcase wall? I believe the earlier motors had bushes, and later ones bearings, not sure when they changed. Also be very interested to know the dimensions of the main bearing you are using in the timing side, I was wondering about a Harley sportster needle roller bearing, as they are fairly compact and take a one inch mainshaft. Also, do you have a source for the cams themselves, or are you going to make them? I’m in Wellington and have some crankcase castings like yours.
