the thread was a great read. I hope you aren't going to give up on trying to get the column shifter set up to work - i get that it can be frustrating at times. am doing a very similar thing on my dodge pickup though rather than use the original shifter I was going to try and use the one from my hilux column and graft the gearlever from the dodge onto it (might need to extend the length while I'm at it) hopefully that will solve any issue of it resting in the 5/R position as the hilux looks like it uses a spring either side of the shift lever to keep it located central. either that or i might bore out the center of the original to match the hilux one
I look forward to the updates
Andrew
