Hi mate, I just posted this in your build thread. Sorry, think this is the right place.
I also have an 18rg powered chevron that I've had for 4 years. It's a 1989 build. It seems we've come up against some of the same issues! Did you ever sort out your steering not centering properly? The previous owner of my car kept a book of notes for his 17 years of ownership, he sorted his steering not centering with an alignment. I could dig them out for you if you'd like them? My car is the same build, viva front end and holden HR/HQ rear end so the specs should be helpful.
Did you ever sort your overheating on the track? I had the same original radiator as yours (it also had the heater matrix hooked up as an additional rad) but it sprung a leak 3 years ago. I also changed to civic half rad, 48mm thick, 2 core, fan mounted to pull through and I got rid of the secondary heater matrix/rad. I did work to create a shroud at the front (between rad and nosecone) to channel air into the rad. It was fine on the street though I felt was marginal. Took it on track and got 4 sessions in before it was overheating. I don't think the gauge is very accurate. The head gasket is now blown...engine is hooked up to the hoist as we speak and engine will come out for a rebuild. If you sorted your overheating problems and could share what you did, that would be awesome!
Cheers, Dale
021645352
