CPR Sierra
Everything posted by CPR Sierra
  1. Well I was super happy about having a list and I loved the excessive noise… that’s because I cut out the muffler cause it had holes in it .so I went about putting a new muffler on and adjusted lights replaced lower control arm even though it was brand new but was rubber and had excessive play which they showed me so I cut the rubber bush out of it and replaced it with a Nolythane bush out of the old one I had and that seemed to make the caster much better got a new rack end for the steering rack and finished other jobs took it for retest and pow I got a WOF and then Registration so I’m on the road for summer ……… so happy so after 3 years it’s legal again of course there’s still bits and pieces to do but in the meantime I’ll just enjoy
  2. So with all that done it was time for WOF Well driving it there I was super nervous as it had no reg or Wof or insurance first long drive for me and the car since getting it going was about 10ks to garage for inspection so I got a small toolbox packed up and a fire extinguisher just in case and this was the out come
  3. Well a lot has happened with me on this car in the last couple of months I realized that it was fast approaching 3 years since I brought it and I didn’t want it to turn into a project never finished so I made a plan I was going to finish it by Christmas so I could drive it over the holidays. so I worked out I had about 2 hours of putting the rest of the-interior in and cleaning interior also the rear side windows needed fitting and rubber and then I had the dreaded Wof to take it for!!! soooo got interior done tick … no pics now the side rear windows well I got glass ones made along time ago but they couldn’t bend the glass two ways so by the time I spent a small fortune and after they arrived they just weren’t going to work. So after contacting a local plastic company here in Nelson I made another jig and had them made out of plexi glass and with my jig were able to heat and mold them they came out ok but not perfect but they will do as I had no other option. i went about fitting them myself after talking to a few people in the know ,got some new rubber from a local glass shop which worked ok once glass was fitted the car was looking much better.
  4. Also have pulled out and learnt heaps about k-jetronic fuel injection also thanks to @kwsvery thorough description on his tvr which had the same fuel engine as my sierra I was able to take out and rebuild the warm up regulator and fuel distributor with new kits I brought off eBay. It didn’t go with out its problems but after lots of mucking around and getting frustrated it is now running better I replaced injectors with new as of what @kws did to his and also brought a fuel pressure tester as he did . He writes such a descriptive article on it that if you want to know more please look up his kws TVR build. Anyway some pics
  5. Well it’s been to long…… famously Used words on here … at least most people on here understand life gets in the way. anyhow last time I wrote on here I had replaced the rear shocks so since then have pulled out the fronts and replaced them also did bottom arms and painted all under the guards looks a lot tidier
  6. I’ve followed this build and am especially interested in your K jetronic build on the fuel injection in fact I’ve rebuilt my warm up regulator and fuel distributor with kits I’ve brought off eBay ….. now I’m at that stage where I need to tune it and because you have done such a wonderful job of explaining it I’m keen to follow that .now my next question is if you have the time could you contact me to discuss further thanks Maurice. (Hope this is allowed I’m in Nelson)
  7. I also brought some new suspension which I have fitted just the rear at the moment I hope to fit the front over the next week , also I’ve had the side glass turn up so that’s another job to do anyway that’s all for now
  8. Well it’s been a couple of months I’ve been chasing some wiring gremlins currently have the bottom of dash all pulled out ,I had the car running during lock down and found I couldn’t turn it off , I could turn ignition off and pull key out and it would still run which is not good . i still haven’t found the problem but I think it has something to do with the burnt out blinker stem which is connected to the hazard lights which continually go all the time now even when key is out …so on the lookout for mk1 Sierra blinker unit. I’ve put small bits and pieces back on like left wing mirror guard blinker light foot panels , rear wiper motor and electric aerial etc nothing exciting, but still things adding to get it on the road again. ive taken advantage of COVID and got the car registered with out having a WOF …. Thanks Jacinda
  9. Well I’ve gone the road of getting them made from a firm in Auckland I’m not getting any change from $1500 though
  10. Well not much to report can drive it up and down the rd the kjet fuel injection isn’t running to good leans out when you get to 3500rpm or it’s sucking air from some where , now I’ve just got to work out is it worth spending money on an old Fuel injection or not?? Any way been working on getting front bumper on and lights in bumper mounted managed to put plates on which makes it look more ready for the rd . I managed to make up some templates for the side glass and sent them away to Auckland to get made will be interested to see how they come out as they can only bend glass one way and I probably need 2 ways but the guy I’m dealing with said if I go on the diagonal I should be able to get glass to bend both ways……. So I made my template like this out of 4mm mdf sorry no pics of that but I can show confirmation pic from them anyway I’m hoping to take this for a wof in spring sometime if I can get the time to work on it.
  11. Got some photos of it in the garage before I took it out to my mates place , just to look at I’m still trying to get rear side windows but they are like hens teeth
  12. But who doesn’t like an nice rear end
  13. So been working on small bits and pieces like putting front door cards in ,put drivers side mirror on .haven’t put passengers one on because family will hit it when walking past in the garage. trailered it to a mates place cause he’s got a hoist managed to fit new brake discs and went through whole brake system bleed them up and they seem fine now also took fuel tank out and cleaned out inside of tank blew out fuel lines and put new fuel pump in and new filters . cut rear muffler off as it was rusted replaced with a straight bit of pipe . put new water pump in and new radiator, took out power steering as was leaking drop off to get reconditioned. Put back in with new tie rod ends and have no photos of any of it sorry ..........
  14. Managed to get it out of the garage to take radiator out and water pump off as it was stuffed couldn’t find any of these in NZ so brought new ones off eBay also started painting bits and pieces to put back in the inside. got carpets back in and seats starting to look better.
